Who sells Torx bolts for wheel skewers ?
Results 1 to 5 of 5
    Tourist
    Reputation: Pierre's Avatar
    Was talking to a LBS this evening about bolts with allen wrench end (to discourage wheel theft a little bit). He told me to look on the web for bolts that require a Torx wrench. Even better against wheel thieves, but where do I get that ???
    Actually when I think of it, I need a whole skewer set, not only bolts...
    Thanks,
    Pierre
    Nov 2002
    Probably won't find them
    I have a set of the skewers Mudman posted. They take a hex wrench, but Torx is different -- it's a star-shaped head.
    The rod looks like a long bolt that is threaded only at the end. It has a standard head (the flared-out grippy part is essentially a washer), but it's hard to see that from the pictures supplied. I think replacing it with a regular Torx bolt would work, except that Torx bolts are very hard to find in metric.
    But if you want the best security for your wheels, you should get the kryptonite or pitlock locking skewers.
    Diesel Engine
    Reputation: Mike Prince's Avatar
    McMaster Carr (I think its www.mcmastercarr.com or www.mcmaster.com - a Google search will find it). Has just about every fastener known to man. English, Metric, whatever. Give them a try. Shipping is usually pretty quick and you can order from the web.
    Mike
    Apr 2006
    I've just imported a shipment of PITLOCK skewers from Europe. The manufacturer doesn't accept credit cards (only wire transfer $$$) and the retail prices in Europe are super high. I signed with the manufacturer as a dealer so that I could at least get shipments here at a reasonable price. My URL is in my profile and signature.
    North America's only authorized PITLOCK dealer http://www.urbanbiketech.com
