• 03-20-2019
    BlackSquirrel
    Got in a ride today. Tires are great, very fast, and smooth.
    Need to play with pressure a bit, I just set them at 60 for today.
    Next ride I will try somewhere around 55 up front and 65 in the back.
  • 03-20-2019
    Alaska Mike
    All of my current bikes can't quite squeeze in 28s, but I try to add a little volume by running 25c tires on 23mm or 25mm rims. It's usually an issue with the brake bridge being slightly too low (rim brakes). If I could, I certainly would.
    That said, the market for rim brake bikes has hit such a slump that I can now own framesets that were once out of my league. When magnetic braking becomes all of the rage, I'll take another swipe at the disc market.
  • 03-21-2019
    bvber
    Quote:
    But wouldn't that give you the light bulb shape cross section thus less aero?
    Then the industry will go back to rim braking except using magnetic force.
