Who's running tubeless road?
Results 1 to 25 of 28
    Jul 2018
    Been running tubeless for mountain and gravel for years now. Time to give it a shot on the road bike.
    Haven't pulled the old tires off yet, not sure if the stock wheels come with tubeless ready rim strips or if I need to get some gorilla tape.
    I don't know if these are 30 or 32c tires, or 31's and Specialized just wants to feel special, but it should be really nice to have the ability to run them down to 40psi if we do a dirt day.
    Pack Fodder.
    Reputation: Alaska Mike's Avatar
    Sep 2008
    At that width, with the air volume involved, I don't see a problem. At a higher pressure and lower volume tire, I question the application unless you're dealing with a lot of thorns and other small punctures that sealant can quickly fix.
    Most of my tires are in the 25c range (rim brake), and most of my flats are large enough I would lose too much air before the sealant plugged the hole for them to be ride-able. Then I would have to fight the tire off the rim, deal with the goop, and install a tube. At this point, the downsides for me outweigh the positives.
    I have run sealant in tubulars with mixed success.
    Jul 2018
    These are pretty large tires, the bike has 28's on it now. Hopefully the larger tires don't make it handle funky.
    'brifter' is a lame word.
    Quote Originally Posted by BlackSquirrel View Post
    Why would they?
    I work for some bike racers
    and a bunch of skateboards
    Reputation: velodog's Avatar
    Sep 2007
    Why would they?
    Because aclinjury says so.
    Too old to ride plastic
    Ahhhhh...I'm guessing based on 'feelz'?
    Feb 2010
    He can totally feel the trail difference between a 28 and a 32, I'm sure
    Feb 2010
    They're a 32, and they're great tires, especially for the price. The naming convention comes from back when we thought wider tires offered more rolling resistance, so it was smaller number tread, larger number casing. Comfort of a bigger tire, speed of a smaller tire type thing.
    No idea why they still stick with the naming convention. It's dumb.
    Jul 2018
    Thanks for the feedback.
    I am not concerned about trail changes, but I am guessing that's an inside joke on the forum.
    As far as handling differences, I have never used a tire this large. The majority of my road riding was in the early 2000's. On 23c tires at about 1 million psi.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    6500 mi on my predominantly winter/rain bike. Schwalbe Pro One's 25mm wide using Orange Seal. No flats yet. When replacing tires I've seen sealed pin holes but they sealed without me ever knowing it.
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Yep, lots of inside jokes here. You're on the inside now, welcome to the forum!
    Wider tires will not change your handling unless they are too large for your frame, then the frame rub will gave you a super workout. Seriously, use the widest tires you can fit and don't look back. I went to 28mm tires on both my road bikes and will never go back.
    Oct 2013
    Who is running 32's on their 'road' bike? Seriously, on the road?
    BANNED
    [REDACTED]
    May 2014
    I would if I could fit them. The newest Cannondale Synapse Disc models have room for 32mm tires. Try it, you may like it.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    (raises hand).
    Unlike the UCI peloton that only races on the smoothest fresh paved roads imaginable...I ride on real life "roads"...which less resemble a mirror-finish smooth ribbon of fresh cured asphalt, and more resemble the the cratered moon.
    And the roads aren't getting better....this winter did even more damage to them and the City is too broke to repair them. They're wanting to add a $0.25 sales tax to fund road repair. They need fixed and the city/state is broke--there really isn't a choice. They're a hazard to navigation even in a car at this point--not residentials but arterials as well. And then there's all the flooding damage here in Nebraska that basically destroyed all the county highways that were paved.
    Sep 2007
    42's here, seriously, on the road.
    40mm on the road.
    JSR
    JSR is offline
    Feb 2006
    Trek supplies 32s OEM on the Domane disc.
    Russian Troll Farmer
    Sep 2016
    I'm riding 42's on my gravel/touring bike, and they are pretty 'road-ish' tires...
    "L'enfer, c'est les autres"
    Quote Originally Posted by JSR View Post
    Yep, and they look small to me at this point. I've really gotten used to seeing big tires on road bikes.
    Not a climber
    Reputation: dcorn's Avatar
    Sep 2011
    I have 32mm Hutchinson Sectors on my Aeroad disc. I'm a heavy dude at 200lbs, but they ride like a dream with 80psi. Raced on em too, so they are plenty fast still. Put probably 1000 miles on them so far, no issues and no flats.
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Anyone want some lightly used Giant 25’s?
    Cheap...
    Sep 2007
    Well, yeah. And something about what the pros ride.
    Sep 2011
    Almost the entire peloton were on 25c tires during Strade Bianchi race, which had 65km of white gravel. Besides the gravel, there were also plenty of bad backcountry roads. A few riders were running 28c's, but those that mattered, were all on 25c.
    And tire size does affect trail, thus affecting handling. This is physics, yall need to... look.it.up..
    oh tell me, why do motorcycles not run the front tires the same size as the rear tires? I mean, wouldn't this make the front tire last longer? let that sink in
    Jul 2018
    Ready for tomorrow's warm(er) weather. I was half tempted to swap some lighter wheels..... but, these roll fine for now.
    Oct 2013
    Both my motos are running bigger front wheels, I don't think it is to make the tire last longer. My take is that it aides in turn in, don't think I need more turn-in on the pedal bike, it's quick enough the way it is!
    BANNED
  1. Road tubeless on non-tubeless wheels
    By SwiftSolo in forum General Cycling Discussion
    Last Post: 05-11-2015, 10:20 AM
  2. How about running tubeless for your road bikes?
    By q2cycling in forum Wheels and Tires
    Last Post: 03-24-2015, 07:56 AM
  3. Experienced Cyclists adding running to do Tri's - Hip muscle pain when running?
    By JoePAz in forum Racing, Training, Nutrition, Triathlons
    Last Post: 04-19-2013, 09:09 PM
  4. Replies: 15
    Last Post: 07-22-2010, 09:40 AM
  5. Replies: 15
    Last Post: 02-21-2007, 10:41 AM
