Results 1 to 25 of 35
    Jan 2009
    Why are my disc brakes so bad?
    Summary: even after several months, the mechanical disc brakes are very ineffective.
    Their braking behaviour is "on par" with something I last experienced about 15 years
    ago with "single pivot" rim brakes.
    Details: Fuji Tread 1.0, Shimano 105, mechanical TRP Spyre disc brakes.
    The brakes were really bad at the beginning and I was told they need some time to work well.
    However, that never happened. I still can't get the bike to stop without braking from the drops
    (in contrast to my rim brakes where I only need one or two fingers applied from the top of the shifters).
    Is that problem just "inherent" in this disc brake model?
    Based on "reviews" I found online these TRP Spyre disc brakes are supposed to be "good".
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by Got Time View Post
    Ineffective, as in they will not lock your wheel?
    No, they don't. Sounds like they need adjusted, and probably did originally.
    Jan 2009
    "ineffective" as in "they require a lot of force on the lever to work",
    i.e., way more than I need for my other brakes.
    Reputation: nova_rider's Avatar
    Sep 2005
    Sounds like these are either:
    1) Improperly installed
    2) Improperly adjusted
    3) Improperly maintained
    Are the calipers properly aligned? Are the pad/rotor gaps correct? Are the rotors properly maintained? Is compressionless brake cable housing used?
    Also, mechanical disc brakes require more adjustments as they wear, is this being done?
    Small adjustments can make a big difference with disc brakes, much more so than rim brakes, IMO.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    The Spyres are probably the best road disc mechanical brake on the market right now. So I doubt it's the actual brake.
    My guess is that the pads and rotors are glazed. The front brake is probably not going to lock up with a 140mm rotor, but the rear should get close to lock up when panic braking.
    Pull the pads a take a picture. Post it up and lets take a gander.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    'brifter' is a lame word.
    I'm betting someone 'adjusted' them by pulling the cable tighter. This reduces the leverage that the actuating arm develops to basically zero. You have to adjust mechanic disc brakes by moving the pads closer to the rotor NOT pulling the cable.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2007
    what size rotor?
    Quote Originally Posted by reptilezs View Post
    what size rotor?
    That would be absolutely the last thing that could be the OP's problem.
    Russian Troll Farmer
    Sep 2016
    I'm wondering if pad material might be part of the problem? Good metallic pads give great grip, but wear rotors out quicker. Softer pads don't wear rotors as quickly (and also don't squeal as much), but kinda suck at braking.
    Also, there was some bonehead who had this same problem because.......after every wet ride, he used to spray his rotors with WD-40!
    "L'enfer, c'est les autres"
    Funny...Shimano and SRAM supply pretty much all of their disc brake systems w/ resin (organic) pads.
    Jan 2009
    Thanks for the comments, based on this feedback I took the bike to the store and the mechanic told me there seems to be some "glazing" and he fixed that -- now the braking is "acceptable".
    The brakes are barely used, so there shouldn't be any "glazing" from braking (no real descending, no prolonged braking), correct?
    Maybe the rotor/pads have been that way from the start when I bought it new from a Performance store and the "braking in" period didn't change that? (which would explain why braking never got better)
    Oct 2013
    Disk brakes have to be 'used' to effective. New disk brake pads are not very good until seated in. If you get a disk bike, and just tool around the compound, they will never seat in.
    BANNED
    Jan 2009
    How much do they "have to be 'used' to effective"?
    I rode probably 200-300km with the bike.
    Moreover, back when I bought it I also rode a few kms while slightly pulling the brakes (nice workout :-) because the sales guy told me it would take only about 20 minutes of braking to get things settled.
    Sep 2005
    >>I also rode a few kms while slightly pulling the brakes...
    This may explain the glazing, avoid "dragging" the brakes, especially on long descents. I typically seat new pads with few good hard but controlled tug on the levers. Also, I recommend routinely clean the rotors with isopropyl alcohol.
    Oct 2013
    There are video's, I usually go to a 'hill' and do a few repeats. It's more than just dragging your brake.
    Your bike, probably never had the disks cleaned with alcohol before riding, probably got some oil or grease on the pads. Once that is done, new pads are required or they may be saved if the oil didn't get too deep into the pad.
    BANNED
    Rub it............
    Nov 2007
    Quote Originally Posted by nova_rider View Post
    Frequent cleaning of the rotors with alcohol starts the removal process of the brake pad material that you worked to get bedded into the rotor. The only time you should use alcohol on your rotor is if they are contaminated, glazed or brand new.
    I'm still thinking that they're not adjusted properly. It's very easy to screw up cable operated discs. There are hundreds and hundreds of mechanics out there that have no idea how to do it properly, I know because I have to fix them all the time. If the arm that the cable pulls is rotated forward by simply pushing it and then attaching the cable OR using the barrel adjuster to 'tighten the brakes' they won't work. It's entirely possible to move that arm enough that the brakes won't create any power at all...zero. You have to attach the cable w/ the arm as it sits w/ no tension at all and then adjust the pads w/ their adjusting screws. Those brakes should feel just as powerful as any hydraulic system when adjusted properly.
    Sep 2005
    Routine does not mean frequent. Perhaps I could have said rotors need to be routinely checked and cleaned, if needed. But a complete rotor strip-down is a must when replacing pads.
    Jan 2014
    Yes, this is how you ended up glazing the original pads.
    The proper brake-in procedure is sort of the opposite of what you did. You actually want to brake VERY hard, from a fairly fast speed (but NOT all the way to a stop). Do that at least half a dozen times and the brakes will work great.
    Quote Originally Posted by fronesis View Post
    The proper brake-in procedure is sort of the opposite of what you did. You actually want to brake VERY hard, from a fairly fast speed all the way to a stop. Do that at least half a dozen times and the brakes will work great.
    NO! All brake pad manufacturers...be it bicycle, car, moto...state specifically do NOT brake to a full stop. Brake hard as you said but let off just before coming to a stop. Never stop fully when bedding pads. Also, you need more than 6 times, I believe Shimano says 15 or 20, can't remember. You'll be able to feel when the pads come in pretty easily.
    Sep 2016
    This is pretty the similar to the bed-in procedure for just about every 'metallic' automotive brake pad. Specifically, they usually call for 5-6 HARD stops, followed by 5-6 Medium 'slow-downs' NOT ending in a stop, followed by a 5 minute cool-down with no brake usage at all.
    Sep 2005
    Let's be real, nearly every car on the road has disc brakes, yet how many motorist even know what bed-in is? Is this any better with cyclists on a disc bike? I think not. The point is most expect disc brakes to work regardless of whether or not they have been properly bedded-in. I suspect component makers have already factored this into their design.
    While glazing might be a contributor, it is not the root cause with OP's issue.
    Jan 2014
    I stand corrected.
    And now that cxwrench mentions it, I realize I didn't come to a stop when I bedded in those brakes just hard braking.
    Apologies for any added confusion...
    Reputation: Srode's Avatar
    Aug 2012
    Most motorists don't service their own brakes, and the mechanic who installs them (if a decent mechanic) will do the bedding on a test drive after the installation.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Jan 2009
    Oh well, that's what I got for "believing" what the sales guy(s) told me.
    Too bad the information how to "bed-in" the brakes isn't in the manual I got with the bike.
  1. Replies: 5
    Last Post: 05-23-2018, 10:49 AM
  2. Replies: 5
    Last Post: 05-16-2018, 04:43 PM
  3. New bike: disc brakes or rim brakes. Can't decide.
    By Tim Mailloux in forum General Cycling Discussion
    Last Post: 04-12-2016, 03:39 PM
  4. Replies: 4
    Last Post: 06-09-2013, 07:09 AM
  5. Disc brakes are awesome!!! / Disc brakes are Awesome???
    By metoou2 in forum Components, Wrenching
    Last Post: 01-18-2013, 04:28 PM
