Will a SRAM x9 rear derailleur work in place of a SRAM Force rear derailleur?
Results 1 to 11 of 11
    Reputation: multirider's Avatar
    Nov 2007
    I have a cyclocross bike with SRAM Double Tap from 2013 on it -- 2x10.
    The stock Force rear derailleur is rated for up to a 28t cassette. I want to run a 32t. I put a 32t on it and it works, but shifting to the 32 and back down is always tentative and the pulley grinds just a bit even with the B screw all the way in.
    In addition, I'd really like a clutch on it to reduce chain slap and chain drops. CX in Colorado is extremely bumpy and my chain has come off a few times in spite of having a chain catcher.
    Would it work to replace the Force rear derailleur with a x7 or x9 rear derailleur? Is the cable pull the same? Would it shift properly?
    While I'm at it, what does "Type 2" signify? It appears all the SRAM rear derailleurs come in regular and "Type 2", but they don't explain what Type 2 means. Is it the addition of the clutch and the cage lock?
    Any thoughts on what level derailleur for cx? x7? x9? XO? Like everyone, I'm looking for light, durable, and reasonably priced.
    Idiot at large
    Apr 2010
    Type 2 is a clutch type rear derailleur, which is what you're looking for.
    Unlike shimano, you can use a 10-speed MTB rear derailleur with SRAM road shifters
    2010 Specialized Secteur Elite with the RBR not-approved Mavic Ksyrium Elite wheelset
    2009 Specialized Rockhopper Comp 29er upgraded to SRAM X9 with 1x10 and Stan's Arch EX rims and tubeless.
    2013 Cannondale CAADX-6 Tiagra with 9-speed SLX RD to run 11-32T cassette and Stan's Alpha 400 rims and tubeless
    and
    Some Burton snowboard setups, one with stiff ol' Camber and one with Rocker-Camber-Rocker
    Sep 2011
    Agreeing with Ted. Type 2 is the clutch type.
    I've run x9 shifters with a red rear derailleur so I'm sure the reverse is possible.
    You could also get a Force CX1 rear derailleur, it's the only road derailleur with a clutch. However it appears heavier (261g) than the X7 (239g). Not sure if it's actually on the market yet.
    2013 Salsa Colossal Steel
    2013 Salsa Beargrease
    2012 Giant Defy Composite
    2010 Trek Fuel EX
    2010 Specialized Allez
    2000 Trek 4500
    1995 Nashbar 5000R
    1991 Trek 750
    CX'er
    Reputation: bikerector's Avatar
    Oct 2012
    Same as above, many people are using the type 2 (clutch) derailleurs with sram road shifters for 1x setups with good success. You shouldn't have any issues.
    I would go with the x7 or x9. I think they are priced about the same and functionality is probably pretty close. Probably less machining somewhere or more stamped vs cast/forged aluminum. x7 is like apex, x9 is like rival, or at least that's how I think of it. Pretty close in price and functionality.
    I wouldn't get the force cx1 rear derailleur simply because of the cost. Also, not running 1x the horizontal swing feature that it has would not be beneficial at all, might be a hindrance even.
    Aug 2004
    Hijacking this thread a bit. Same boat, I have Red Brifters, and going to go X9 for the derailleur, was trying to decide between PG-1070 at 11-32 or go Ultegra and go 12-30 with Shimano chain. Any suggestions? The Ultegra would work right? Seems like my Sram stuff is much loader than my Ultegra stuff, but I like the shifting of Sram better.
    Thanks.
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    I use the SRAM PG series cassettes with KMC chains and they're very quiet.
    Trying to cram the rest of my life into the rest of my life!
    CX'er
    Oct 2012
    I'm running an 11-32 XT cassette since I wanted more favor to the big cogs than the little cogs for CX racing with my new 1x10 setup.
    dcb
    dcb is offline
    Jul 2008
    yes it will work. I'm running a rival right shifter with an X0 rd on a 1x10 set-up. 11-32 Sram cassette.
    'brifter' is f'ing stupid
    Quote Originally Posted by piercebrew View Post
    Hijacking this thread a bit. Same boat, I have Red SHIFTERS, and going to go X9 for the derailleur, was trying to decide between PG-1070 at 11-32 or go Ultegra and go 12-30 with Shimano chain. Any suggestions? The Ultegra would work right? Seems like my Sram stuff is much loader than my Ultegra stuff, but I like the shifting of Sram better.
    Thanks.
    FTFY. Yes, it will work just fine.
    #promechaniclife
    Sep 2011
    Yet one more reason I love Sram
    Reputation: GRAVELBIKE's Avatar
    Sep 2011
    SRAM's road and mtb shifty bits are compatible. My Specialized AWOL has Apex levers shifting an X9 Type-2 rear mech, and it works great.
    GRAVELBIKE.COM - ride everything
  1. Replies: 10
    Last Post: 04-23-2014, 03:08 AM
  2. SRAM Force WiFLi Rear Derailleur
    By JRock457 in forum SRAM
    Last Post: 10-05-2012, 08:23 AM
  3. SRAM Red Rear Derailleur v. Force
    By woodys737 in forum Components, Wrenching
    Last Post: 10-04-2012, 05:46 AM
  4. SRAM Force Rear Derailleur Play
    By minez01 in forum Components, Wrenching
    Last Post: 03-02-2012, 01:37 PM
  5. Play in SRAM Force Rear Derailleur
    By dirtspin in forum Components, Wrenching
    Last Post: 07-16-2007, 10:55 AM
