WM Outboard PF30 install lube
Results 1 to 5 of 5
    Reputation: Srode's Avatar
    Aug 2012
    Wheels manufacturing Outboard PF30 installation in carbon fiber frame - Phil wood grease or Teflon paste to lube the contact area between it and the frame - or doesn't matter?
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
    'brifter' is a lame word.
    Coulda sworn I replied right after you posted...you've probably installed it by now but any grease is fine.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2012
    Thanks, I haven't installed it yet but only due to lack of time, its just loosely dry fitted - I have both paste and grease available just need to get out there and do it now.
    Gravel Rocks
    Trek Domane
    BH G7 Disc
    Trek Crockett
    Feb 2002
    Assembly paste is just grease with some grit in it. You need the grit when things are slipping with regular grease. Otherwise, grease is just fine.
    Aug 2012
    its not assembly paste I was talking about, although i have that also (not something for a bottom bracket like this one of course)- it's teflon paste often used by plumbers. I'll end up using grease, easier to clean up off my hands when done!
    Gravel Rocks
    Trek Domane
    BH G7 Disc
    Trek Crockett
  1. Replies: 1
    Last Post: 10-26-2014, 01:26 PM
  2. RIP Wm. F. Buckley
    By Creakyknees in forum Politics Only
    Last Post: 02-28-2008, 11:28 AM
  3. Wm. Faulkner text correction?
    By Argentius in forum The Lounge
    Last Post: 09-30-2007, 03:36 PM
  4. Lube- that is, chain lube
    By filtersweep in forum Fixed/Single Speed
    Last Post: 06-03-2005, 04:17 PM
  5. Derrailer jockey pulleys, to lube or not to lube?
    By TACSTS in forum Components, Wrenching
    Last Post: 05-12-2004, 11:54 AM
