Wobbly cassette?
Results 1 to 13 of 13
    Reputation: CLTRD's Avatar
    May 2004
    Wobbly cassette?
    When I had my bike on the stand a few minutes ago I noticed that when the rear wheel spins (freely, with and without pedalling), my cassette sways minutely to and fro; about 1-2mm. Is this normal? Any obvious adjustments to be made? It's Sora 8spd on my OCR3.
    I've heard enough "wtf dude obviously it's shi*t why are you even wondering go buy ultegra now" so spare it please
    May 2002
    I wouldn't consider it normal. It's however quite common. If your hub is still functioning properly I wouldn't worry about it.
    Dec 2004
    I am not going to tell you to run out and buy Ultegra.
    I've heard enough "wtf dude obviously it's shi*t why are you even wondering go buy ultegra now" so spare it please [/QUOTE]
    Because you already know.
    I would not worry about its performance on a bike stand up close.
    I would just ride it.
    I have seen lots of cassettes wobble, I have even seen top line stuff do it.
    Old and Fixed, Moderator
    Jan 2002
    Quote Originally Posted by CLTRD
    It could be an illusion. The ramps on Shimano cogs can make the cassette appear to wobble...
    Dave Hickey/ Fort Worth
    Game on, b*tches!
    Reputation: Kram's Avatar
    That, or...
    Quote Originally Posted by Dave Hickey
    Your free-hub could be loose. Not a huge problem. My old Ksyriums do this (I will replace that free-hub soon, but it worked fine for many years) Like the others said, if it works fine, just ride.
    Originally Posted by tetter
    'Pain is temporary, and there might be beer at the finish line'
    "Karma is spread in lots of different ways. You know, like herpes."
    catzilla
    "I'm an American male. This is pizza. Leave me alone!"
    Alton Brown
    ohnoIaintsuckingnomore.blogspot.com
    Apr 2005
    They do wobble a bit, but only if you spend time staring at it. So don't.
    wim
    wim is offline
    Feb 2005
    It's normal. The hub body spins only when it's NOT under load, allowing the use of a mid-grade bearing with less than super-tight tolerances. Once you apply power to the pedal, that bearing stops turning and the engaging pawls center the hub body perfectly. For what it's worth, even Dura-Ace hub bodies wobble when not under load.
    wim
    wim is offline
    Feb 2005
    It's normal.
    The cassette body spins only when it's NOT under load, allowing the use of a mid-grade bearing with less than super-tight tolerances. Once you apply power to the pedal, that bearing stops turning and the engaging pawls center the hub body perfectly. For what it's worth, even Dura-Ace cassette bodies wobble when not under load.
    Apr 2004
    Make sure your cassette and lockring are clean before you install them. If there is any grit in there, the cogs or lockring may not seat properly, causing wobble.
    Rain Man
    Dec 2002
    Normal
    Overweight, aging athlete
    Reputation: Geezer's Avatar
    The Wobbles
    I had a similar problem when I swapped my cassette to another wheel. After a lot of head scratching I found a very small ring on the old wheel that seemed to have been between the cassette and the hub. As soon as I put the ring on the wobbling stopped.
    On a side note I'm not sold on the Ultegra 10. I went from a very crisp DA 9 to the Ultegra 10 and the crisp feel is not there. I get a slightly vague shift compared to the old 9 speed.
    May 2004
    okay cool just one of those things that makes you ponder; I haven't seen anything about these before, so I figured I'd keep being a sponge and take in as much info as possible
    thanks for the replies
    AJS
    AJS is offline
    Reputation: AJS's Avatar
    Aug 2003
    Lightbulb
    There's this stuff called "Wobble Nought". Get a can of it and spray directly on the cogset and freehub, and it'll straighten everything right out pronto.
  1. making a 6sp. cassette work with modern levers
    By moschika in forum Components, Wrenching
    Last Post: 03-08-2005, 06:31 AM
  2. cassette rattle/wear & chain wear
    By the flying bean in forum Components, Wrenching
    Last Post: 02-23-2005, 05:13 AM
  3. How to check cassette wear?
    By JTS628 in forum Components, Wrenching
    Last Post: 01-13-2005, 09:53 PM
  4. Wobbly cassette
    By smolenice in forum Components, Wrenching
    Last Post: 07-28-2004, 07:58 AM
  5. time to replace chain and cassette?
    By tarwheel in forum Components, Wrenching
    Last Post: 06-04-2004, 03:59 AM
