Wrong cassette size - will a new size chain also be required?
Results 1 to 4 of 4
    Hey gang -
    I just picked up my new bike yesterday - Problem is that it was shipped with an 11/23 cassette and I requested a 12/25. My LBS is trying to correct the problem but reading the thread below, it dawned on me - will I need to re-size/exchange the chain or the one that came with the bike do?
    The setup is a DA 10 speed.
    Much thx's
    Wile
    Every little counts...
    Reputation: Spunout's Avatar
    Aug 2002
    Nope. It will be fine. Double check the 53/25 combo so that it doesn't rip your derailleur off, and the small combo for slack, but it should all go fine.
    thanks for the reply Spunout
    Quote Originally Posted by Spunout
    I'll make sure I do
    Thx
    Wild
    Feb 2002
    Not likely, and here's why
    At any given time, only half of the teeth on a cog are engaged with the chain. Therefore, a 4 tooth difference equals one new link in the chain (two half links = one link, and two half links engage the 4/2 teeth). So your two tooth increase means only one half link additional is engaged. Unless the original chain length was right at the limit of shortness, you won't need any more. As suggested by others, it's always a good idea to be sure that the large/large combo won't damage things.
  1. proper chain length for an 11x 23 cassette
    By kenyonCycleist in forum Components, Wrenching
    Last Post: 04-16-2004, 11:05 AM
  2. Is a 9 speed chain compatible with 8 speed cassette?
    By mdevos in forum Components, Wrenching
    Last Post: 04-15-2004, 11:32 AM
  3. cassette, Rd and chain length ??
    By fasteddie in forum Components, Wrenching
    Last Post: 03-29-2004, 08:41 AM
  4. Will a Dura-Ace 10-speed chain work with a Campy-10 cassette?
    By yzfrr11 in forum Components, Wrenching
    Last Post: 03-18-2004, 08:00 AM
