Clincher tire for 75% pavement, 25% dirt fireroad?
Results 1 to 25 of 35
    Nov 2009
    Any recommendations?
    Thom H
    Aug 2009
    Ritchey Speedmax is not too bad. If you can fit bigger tires on your sled there are some 35-42mm touring tires that would also fill the bill. Speedmax also comes in a 38mm or at least it used to. I personally like the extra size more than extra treads on a bomber fireroad bike. Good cross tires are aoften too light to use as heavy road/firetrail and tend to puncture on sharp sidewall hits. That is where the the touring tires seem to shine.
    Iohannes fac totum
    Mar 2008
    Some good old touring tires fit the bill.
    Nov 2006
    What are you putting them on? Most treaded tires bigger than 30c won't clear road calipers.
    If you have some medium/long reach calipers, Kenda Small Block Eights (32c, but small) or Michelin Jet S (30c, but big)
    tires work well.
    If not, find some 28c Conti road tires.
    TWD
    TWD is offline
    Reputation: TWD's Avatar
    Quote Originally Posted by Thom H
    The wire bead Speedmax (no point in buying the $$ kevlar bead just to burn off the tread on pavement) come in both 700X35 and 700X40.
    I've got a set of each, and the 40s aren't much bigger than the 35s. Measuring both with a digital caliper on the same rim at same PSI, the casing width on the 40s measured only 1mm wider than the 35s (34mm vs 33mm). The 40s are a bit taller, so overall have a little bit more volume, but not much. The tread on the 40s was actually 1mm NARROWER than the 35s.
    All in all, at the end of the day, it is what it is....just sayin'
    Dec 2006
    I run Michelin Jets on my cross bike this time of year for the type of riding you are describing.
    Nov 2009
    Quote Originally Posted by backinthesaddle
    tires work well.
    Motobecane Fantom Cross Team with disc brakes, so clearance is no problem. I'm having a wheelset built with Stan's ZTR Crest rims, which are 24.4mm/21mm wide (OD/ID).
    Nov 2005
    schalwbe marathon extremes or XRs designed for road/gravel touring and will last way longer than cross tires
    Reputation: bluedog18's Avatar
    Aug 2006
    I'm going to 2nd the Michelin Jets, very comfortable tire to ride and will work well on the road to.
    Reputation: Quattro_Assi_07's Avatar
    Jan 2006
    Specialized Borough XC Pro 700x45...
    I run those on my BMC CrossMachine. On my rims (DT RR 1.2) they measure 43mm. Don't know if you want a tire that large. I ride mainly on roads (it's my commuter) but the roads here are horrible and the larger volumn really helps out. They are also great for going off road as well when the mood strikes...
    San Antonio, Texas
    May 2004
    You don't want "cross tires" as you don't need or want the tread and the lighter ones like ritcheys and the mich. jets puncture fairly easily. I'd pick Panaracer tour guards in 28 or 32c, which is what gets mounted on my cross bike during the "off" season, or one of the Schwalbe Marathon models. Or for more spendy (and supple) tires like Jack Browns, or Roly Polys from Rivendell.
    Jul 2008
    another one for michelin jets
    use for commuting on crappy roads here in san jose, ca and riding cross in real mountainous areas.
    ++ roll fast, corner well,can ride in the dirt without changing wheelsets, comfort
    -- can be expensive, roll slower than 28c or full volume 25c
    lots of selections
    Nov 2009
    I've never really looked at touring/trekking tires before, lots of cool tires in that genre. Here's some other contenders:
    Maxxis overdrive (700x38, 60TPI, wire, 580g)
    Contintental Top Contact (700x37, folding, 550g)
    WTB Pathway (700x38, wire, 695g)
    Good suggestion on the Schwalbe's. I like the tread design of the Schwalbe XR (700x40, wire, 750g)
    Looks like it would be relatively smooth rolling and cornering, but with some bite in the side lugs.
    I'm also liking the look of the Schwalbe Marathon Extreme (700x40c, wire, 525g), the wider lug spacing would probably be grippier off road but noisier on road:
    The Schwalbe's are pretty pricey, looks like CRC has the best prices, but you have to spend $244 to get free shipping from the UK, anyone know of other places to get good deals on them?
    PT
    PT is offline
    All-purpose bike...
    Reputation: PT's Avatar
    Mar 2002
    Quote Originally Posted by ZenNMotion
    ...I'd pick Panaracer tour guards in 28 or 32c, which is what gets mounted on my cross bike during the "off" season, ...
    +1 for Panaracer touring tires. My current favorite -- roll well, wear like iron -- is the Urban Max. I ride 70% dirt/gravel, 30% road in the hills/mountains of southern Wyoming/Northern Colorado. I use to think for my dirt and gravel road expeditions that I needed "knobs", but found the Panaracer Pasela or Urban Max tires in 32c to perform exceptionally well. Using those tires I've done a number of dirt centuries as well as paved centuries.
    Hmm... Can I think about that?
    TWD
    TWD is offline
    Also check out the Schwalbe Marathon Cross (700x38). It's got more aggressive cornering knobs so it's a little more capable off-pavement. Center tread is still pretty smooth, so they roll pretty well.
    These types of trekking tires wear like iron, but unfortunately weigh like iron and ride like iron too.
    You can only soften the ride so much by dropping pressure.
    Nov 2009
    Quote Originally Posted by TWD
    Another intriguing possibility - and that tire is $39 (630g) versus $66 for the Marathon XR
    (750g!) or $78 for the Marathon Extreme (525g).
    TWD
    TWD is offline
    One thing to note with the marathon cross, is that they run on the big side. I measured them with a digital caliper at 39mm wide at the outside of the cornering knobs.
    Most of the of the cross tires I've owned (with the exception of Mich Muds) have measured a couple mm narrower than the spec. So if you think you've got plenty of clearance for a 700x35, realize that these tires may be 6 or 7 mm wider than the 700x35 you're used to.
    Oct 2008
    Continental Ultra GatorSkin 28 mm width
    Fat aging guy on a bike..
    Reputation: cyklopath's Avatar
    Feb 2007
    I'd suggest the Vredistein Premiato.
    It runs much narrower than its stated measurement, but the compound is rather hard, and the tread pattern rolls well on pavement while also cornering well.
    I ran one on my front this season and had good luck with it.
    ......._: )
    My Crappy Blog
    Apr 2008
    Want uber Cheap? Kenda Kross Plus from Nashbar. $7 a tire is hard to beat.
    I have a set of 42s. They feel like a (heavy) road tire on straight pavement, but if you turn/lean, the knobs let you know they're there. They aren't soft or plush by any means, but, unless you have thorns locally, I don't think you'll ever have a problem with getting a flat. Main drawback is weight.
    Reputation: BrianN's Avatar
    Feb 2008
    Just took the new Continental Cyclocross Speed out for a test ride-
    Tall - measured circumfrence - 2150mm
    Narrow-ish - 700 x 35 measured 31.7mm on a 23mm rim
    Durable - Classic conti tire, takes a beating well
    A fast roller that corners well on dirt. My test track has pavement, compacted and loose sand, rocks, gravel and clay. I did get a bit of front slide under the hard braking sharp corner combo on pavement, but overall my new favorite combo tire. I have always been surprised by the long wear of Continental tires, so I expect these will last quite a while. Local terrain is typically dry and fast (I'm in the desert) so I plan to race these come October.
    http://www.conti-online.com/generato..._speed_en.html
    -B
    What the hell do I know?
    changingleaf
    Aug 2009
    75% Road 25% dirt
    The WTB Pathway Flatguard is the way to go.
    700x38 or 700x32
    It is a folding cable bead tires. $35 MSRP
    Jan 2006
    Still loving my Spec Borough XC...
    Quote Originally Posted by mtbpete
    700x38 or 700x32
    They just soak up the bumps and keep rolling. And at 700X45 and 425gms, they are bigger and lighter than the Pathway Flatguards.
    San Antonio, Texas
    Nov 2007
    Jack Brown Blues - :2cents:
    Mar 2005
    Sorry for the bump but this is a great thread and I have the same tire needs!
    The only difference is that I want to keep the tire under 400g.
    So far the best options seem to be:
    Ritchey Speedmax 700x32 358g
    Kenda Small Block 700x32 330g
    Michelin JET S 700x30 340g
    Are there other good options that I am overlooking?
