Knobbies safe for twisty paved road descents?
Results 1 to 14 of 14
    Mar 2004
    Here's the short version of my question: Can I safely go as fast on a CX bike with knobby tires on a fast 40+ paved twisty downhills, as I can on my road race bike?
    Here's my plan:
    I plan to do this steep 9-mile, 4000-foot elevation gain climb on a dirt fireroad (Mt. Wilson Toll Road for you L.A. locals) and come down on a paved twisty road descent. My tires are knobbies up front (28?) and semi-slicks (30?) in back.
    I've used my CX only for commuting and a few fireroad rides. On my roadbike I've gone down the mountain road at 45 mph, slowing down a bit on the twisties. I've gone above 30 mph on the CX, but never on curves.
    I would think that even with the knobs, the CX would have better grip on the curves b/c of what seems to be a larger contact patch area. Am I wrong?
    kam
    kam is offline
    Sep 2004
    good question, i was thinking of doing the same kind of thing. i am working on a ss/fixed cx. i am going to run 35 kenda kwiks. i was hoping i can do a road climb, single track decent, and maybe mix it up the other way around.
    i am also a so cal'er, i ride the turnbull canyon area alot.
    sorry i can't help, but hopefully, we get some answers/opinion.
    Reputation: wunlap togo's Avatar
    Oct 2004
    NO. Road tires are for pavement, the contact patch of the smooth tire will be bigger than the tips of your knobbies. Do the ride but DON'T push it in corners at 40+ mph on your knobbies. Even at lower speeds you can become familiar with the sensation of "knob squirm". Learn it, know it, and avoid it because it means you are about to crash.
    Reputation: Henry Chinaski's Avatar
    Quote Originally Posted by wunlap togo
    Yep. Get some different tires.
    Reputation: oldskoolboarder's Avatar
    Apr 2004
    I've done about 35 MPH down a paved road on my IF w/ Ritchey Speedmax 30's. Bike was stable, but I wouldn't recommend it if you have to do ANY turns, no matter how slight.
    It ain't worth the risk.
    Dec 2002
    Danger WIll Robinson.
    If you really like the feeling of a two wheel drift at high speed then go for it. Otherwise it's a really bad idea.
    Reputation: the_dude's Avatar
    Jun 2004
    'safe' is in the eye of the beholder. i've ridden decents that exceeded 40mph on mtb knobbies on a windy paved access road. it may not have been the most 'safe' thing that i've ever done, but i stayed upright. road tires are obviously going to be better in this situation, but don't avoid the ride or the speed because of it. but please do excercise caution.
    the_dude
    Oct 2004
    Quote Originally Posted by the_dude
    the_dude
    I concur. Don't push it in the corners, going straight is no different than with slicks.
    Dec 2002
    Except the original question was:
    "Can I safely go as fast on a CX bike with knobby tires on a fast 40+ paved twisty downhills, as I can on my road race bike?"
    But then again, we don't know how fast he's going on the road race bike to begin with. Suffice to say that if the slicks are barely hanging on, then the knobbies would have slid out several mph earlier.
    Mar 2004
    Thanks all. I'll take it easy on the turns.
    From the above responses, it looks like I shouldn't go stupid fast on the downhill turns.
    I think I can still make this a fun ride.
    pi makes wheels go round
    Reputation: damon's Avatar
    Dec 2001
    Quote Originally Posted by NoMSG
    Out of curiosity, why do you need knobs at all? Wouldn't slicks be fine for a dirt road climb? Assuming reasonably dry soil and not horrendously steep (although that isn't even a problem). I used to make a 45-ish mile commute that was 90% road (twisty back country roads) and 10% fire road with some rough washboard sections and pretty darn steep climbs. My little 23c vredesteins did pretty darn well for that 10%! Admittedly, i didn't go very fast around the dirt corners, and i only took this route when dry, but it was a lot of fun to do it that way...
    I guess my point is it sounds like slicks would suit your ride plan better than knobbies.
    -Damon
    Reputation: pauly's Avatar
    Knobbies are overrated
    Quote Originally Posted by damon
    I agree 100%. Get some cushy 32mm slicks and have a blast.
    Mar 2004
    Don't think I could do it on slicks.
    -Damon
    I've done this particular fire road about a dozen times on a mountain bike with standard knobbies and there are some sections that were difficult with that setup. Super steep sections with fist-sized rocks, sandy sections on the uphill, etc. And were talking a 2+ hour uphill climb with practically no breaks. I think the elevation gain may be closer to 4500 feet during these 9 miles.
    May 2002
    Lightbulb all tires are not created equal
    There are knobbies that squirm a lot on pavement (i.e. conti twister pro) because the knobs are tall and they have a squarish profile. Then there are ok tires for pavement cornering (bontrager & other shorter knobs) then there are tires that bomb pavement and are a bit of a compromise for dirt.
    The tires that will allow you to careen downhill while successfully summitting the dirt are Continental Contact tires. They're listed as touring/city/safety but they're quite light and nimble for what they are. They could market them as more of a performance tire versus utilitarian.
    http://www.conti-online.com/generato...ontact_en.html
    I may not have ever pushed my road tires to their max so don't just trust them blindly. In short, don't take my word for it and experiment for yourself.
    When I ride, I tend to corner aggressively on tighter corners at lower speeds. Once I hit 30+ I get a bit more cautious.
    The bigger question is whether they'll be enough for the dirt section. In SoCal sand I'm thinking if these tires can't do it, you'll be carrying anyway. oh.. get the 32's
    good luck
    Chaz
  1. whooo are you? who who, who who?
    By haiku d'etat in forum General Cycling Discussion
    Last Post: 01-18-2005, 05:24 AM
  2. Replies: 4
    Last Post: 09-14-2004, 02:28 PM
  3. Ride Report: Sierra Century (Long)
    By parkmeister in forum General Cycling Discussion
    Last Post: 06-30-2004, 11:26 AM
  4. mySierraCentury.2004 (hecka long)
    Last Post: 06-09-2004, 04:58 PM
  5. New to road cycling, frame questions
    By rotary16 in forum General Cycling Discussion
    Last Post: 04-19-2004, 11:10 AM
