• 09-11-2010
    ringmaster
    Lightest clincher rims for use w/DISCS ?
    This might be an unusual question but here goes...
    I need to build a really light clincher wheelset for my CX bike for use with disc brakes. They will be used for approx 80% pavement and 20% fireroad riding and lots of urban commuting. No heavy duty off-road abuse.
    The narrowest tire I would ever consider fitting to these rims is 25C but I likely won't run anything smaller than 28C.
    The plan is to use DT 240s or American Classic ISO disc hubs with a 28 spoke count and probably Sapim CX-Ray or Laser butted spokes, unless something better/lighter can be found.
    I would really appreciate some good rim suggestions. My goal is to keep the total wheelset cost under $1500.
    Thanks
  • 09-11-2010
    pretender
    Stan's? Velocity Aerohead?
  • 09-11-2010
    deuxdiesel
    Stan's won't safely accommodate the high pressures a narrow tire requires. Maybe an Open Pro or 719 from Mavic, or a Salsa Delgado Cross?
  • 09-11-2010
    seahuston
    I'd look into the Velocity Aerohead.
    Its pretty light and strong but the biggest advantage is that you can get it non machined.
    http://www.velocityusa.com/default.asp?contentID=581
    Having it non machined will look much better than a 700c rim with a braking surface. I have their fusion and am very impressed with it.
  • 09-11-2010
    euro-trash
    Quote:
    The OP said he wasn't likely to use anything more narrow than a 28. Also, Stans now makes a road rim.
    The Stans 340 would work, so would the Velocity. Check-out the Kinlin 270, it's not the lightest, but it's light enough, would be reliable, and with 28 cx-rays would be a stiff wheel.
  • 09-11-2010
    ringmaster
    Good point! I hadn't considered that a rim with a machined braking surface will look a bit odd in conjunction with disc brakes!
    The Aeroheads look good and they come in a great selection of colors but 425g is kinda' porky.
    The Stan's 340s are in the ideal weight range I want but I plan to run with tubes so perhaps these tubeless wheels aren't the best option?
    The Mavic Open Pro and Kinlin 270 are nice rims but both have the same problem - 435g and 430g :(
    Any suggestions for sub-400g clinchers for use with tubes?
  • 09-11-2010
    88 rex
    You can use tubes in Stans 340's.
    Also, ZTR Crests are under 400gs and wide for good cushy volume. I never tried running a 28 on it though.
    If I were you, I'd go 340's with 28 holes.
  • 09-11-2010
    blantonator
    i'd go with the crest rims if you can get them in 28h.
  • 09-11-2010
    tamjam
    Are you sure about this? I thought the PSI limits only applied when running tubeless. On a Crest rim I usually pump my Conti Speed 700x35c with tubes up to 60-65psi for pavement, which is above the recommended PSI for a 1.5" tire if tubeless.
