Mavic CXP-22 rims OK with tires wider than 28mm?
Results 1 to 7 of 7
    Dec 2004
    I am renovating a Bridgestone X0-4, which has 700c rims with a 135mm hub. I found some clearance wheels (Deore hubs with Mavic CXP-22 rims) that I thought would work with 700x35 tires, but when delivered, I noticed that the rims were only rated for 19-28 mm tires. When I checked the Mavic website, I found that all the Mavic road rims (including MA-3s and CXP-33s) were rated in the same 19-28 mm range.
    Since I know CX bikes can use MA-3 rims and CXP-33 rims, I wonder if anyone has had good experience with CXP-22s on a CX bike?
    Oct 2002
    no experience with CXP-22 rims, but since they have the same width and a similar (if not equal rim profile) that shouldnt be much of a problem. i know people riding Ksyriums on 29ers.
    Strained coccyx etc etc
    Reputation: haiku d'etat's Avatar
    Apr 2001
    no experience with the cxp22s, but i've run 700x38 'cross tires on open pro rims and cxp33 rims. if they're all rated the same on the mavic website, i'd figure they'd all work...
    One morning I shot an elephant in my pajamas. How he got into my pajamas I'll never know.
    Aug 2002
    I've used
    29'er mtb tires on a CXP 10,which is the same profile if I remember correctly.Its a semi aero road rim and no problem with 77x52's.
    Dan Cas
    Apr 2000
    Sure hope it's O.K....
    ...because I've been running 30s and 35s for about 5 years on mine. (I've got a set of 40C All Terrainasaurus tires on CXP 33s, and those are fine, too.)
    wil
    wil is offline
    Aug 2004
    I have the same rims, and they work fine.
    I've got the same hub/rim combo (Deore/Mavic cxp22), on my Kona Jake, that you have, and I've run 23mm slicks, all the way up to 35mm knobbies, on the same rim. You shouldn't have any problems at all.
    Dec 2004
    Cool! Thanks to all!
  1. Should I get wider, treadier tires for winter commute?
    By NeedhamDave in forum Components, Wrenching
    Last Post: 11-22-2004, 08:53 AM
  2. Semi-aero rims - FiR, Ambrosio, Velocity, Mavic
    By MichaelC in forum Components, Wrenching
    Last Post: 10-04-2004, 02:40 PM
  3. Mavic CXP 14 front wheel and hub
    By mdevos in forum Components, Wrenching
    Last Post: 04-16-2004, 02:24 PM
  4. DT RR 1.1 rims vs Mavic Open Pro
    By charlieboy in forum Components, Wrenching
    Last Post: 03-18-2004, 12:06 PM
