PSI in your cross tires?
Results 1 to 9 of 9
    Question PSI in your cross tires?
    At this point, going to be running my CX tires (Hutchinson Pro Series, 700 x 30c) mainly for commuting... noticed that the tire says the mx PSI is 70 and min is 40.... wondeirng what people would run with these tires... used to my road (110psi) and mtn (35), but no idea what people run their cross tires at...
    also, for off-road/cross rides, what would you run them at...i'll be doing a bit of that as well..
    thanks for the help..
    Reputation: euro-trash's Avatar
    May 2004
    Quote Originally Posted by bikerboy337
    There is no one answer, it vaires on the terrain. You will get as many answers as there are posters on this board. Check the archives, we've gone through this several times in the past. Also, check the tech section of cyclocrossworld.com There is an article on this subject.
    'brifter' is a lame word.
    depends on how much you weigh...
    and how you ride. i would say conclusively 1psi over what ever pressure you would pinch flat at. just keep dropping the pressure 'til you pinch, then go 1 over. and you're gonna commute on cross tires? on pavement? go easy on the corners...
    More Cowbell!
    Reputation: Gripped's Avatar
    Nov 2002
    Quote Originally Posted by cxwrench
    Pressure in 'cross is alchemy. No right answer really. I like to say go as low as you can for racing. And that's going to depend on course layout, your weight, your riding style, etc.
    I don't recommend commuting on 'cross tires since you will be spending $$$ to replace them all the time. Those nubs wear down fast on pavement. At least go with a semi-slick like Michelin Jets ...
    Pro rep, yo!
    Okay, so I think I've got it. Put a lot of air in the tires. Then let some out and try it, and let some more out and try it, rinse and repeat until you get a flat. Then put in a couple more pounds and you're all set.
    Just like my method of tightening bolts, torque it until it strips and then back off a little.
    Not Banned
    Reputation: atpjunkie's Avatar
    Mar 2002
    all by the seat of your pants
    depends on rider weight, riding style, course, etc... in a World Cup race Sven Nys was yelling tyre type and pressure to his pitcrew as he went by and they changed accordingly
    Dec 2002
    Commuting on pavement: 70psi
    Off-road - depends on terrain.
    --lots of rocks to cause pinch-flats: 60-65
    --more buff: 55-60
    --soft: 50-55
    Lower if you're light on your wheels. More if you're above 160lbs.
    Mar 2004
    My numbers
    I'm 160 and use my CX for a steep fireroad climbs/descents. For traction and control I run them about 40-45 psi, of just enough to keep them from pinch flatting. At first, I ran higher pressures but traction was signficantly compromised. I run 28 mm in front and 30 mm in rear (but only because that's what my used bike came with).
    AJS
    AJS is offline
    Reputation: AJS's Avatar
    Aug 2003
    All depends. On my CXer on-road I ran about 90 psi on 28c Vred Campos, my weight being 195-205 lbs.
  1. Tufo Tubular Tape for Cross tires?
    By cbass in forum Cyclocross
    Last Post: 10-29-2004, 08:37 AM
  2. Cross tires for the muddy Northwest winter
    By Vanilla Gorilla in forum Cyclocross
    Last Post: 09-23-2004, 07:54 AM
  3. Replies: 9
    Last Post: 09-11-2004, 06:16 PM
  4. what size tires for turnint cross bike into pseudo-road
    By ritjobbie in forum Components, Wrenching
    Last Post: 09-02-2004, 06:48 AM
  5. mounting cross tires
    By noavg55 in forum Cyclocross
    Last Post: 03-02-2004, 04:29 PM
