Stan's Iron Cross Disc or Alpha 340 Disc for crossbike
View Poll Results: Which Wheelset?
Voters
11. You may not vote on this poll
  • Iron Cross Disc
    8 72.73%
  • Alpha 340 Disc
    3 27.27%
Results 1 to 9 of 9
    Dec 2011
    Just picked up a Trek Crossrip Elite and am debating between the Stan's Iron Cross Disc or Alpha 340 Disc. I do not plan racing it but right now I can get an amazing discount on either set of rims. Price from my LBS would be $440 for the Iron cross and $550 for the Alpha's. HAs anyone experienced these wheelsets and if so any thoughts/opinions. I ride 90% road and 10% gravel/fireroad. I like the capability to fit 28c road tires and 32+ cross tires if needed during the winter. Here are the links: Iron Cross Wheelset and Alpha 340 Disc Wheelset 24/28. Please let me know what you think?
    Carbon Fiber = Explode!
    Reputation: CleavesF's Avatar
    Dec 2007
    You'll probably be happy with either. I'd go Iron Cross and then use the money you saved on something else for the bike.
    '09 Voodoo Wazoo
    '08 Pedal Force RS2
    '06 Raleigh Cadent 5.0
    '01 Trek 4300 MTB
    '93 Norco Nitro MTB Touring
    '88 Schwinn Prelude Fixie
    1 hour of running = 1 hour of wasted time when you could have been riding. - Alaska Mike
    Sep 2007
    I've seen too many people have troubles with those alpha rims. I'd go for the Iron Cross.
    Cranky Old Bastard
    Reputation: Randy99CL's Avatar
    Mar 2013
    Of those two choices I'd go with the Iron Cross. The rims are a little wider and would probably work well with 28mm road tires. I don't see anything that would make the others worth the extra money.
    I also have a CrossRip and am building some road wheels for 25s that will be on the bike most of the time. I'll keep good cross tires on the stock wheels and switch them out for riding off-road or gravel rail-trails and rough surfaces.
    I'm not predicting problems but I wonder how those light wheels will last over time. The fronts have 24 Supercomp (14-17-15) spokes with alloy nips and are 2x.
    I haven't experienced it yet but expect disc braking (with 25s) on the road to be much more powerful than anything off-road.
    These are the fifth set of prebuilt wheels that I've seen advertised with only 24 spokes in the front so they must be strong enough; that many companies can't be wrong; surely they've tested them extensively.
    Edit: For that price those wheels are a really great deal. Most of the less-expensive sets I've seen weigh 1800-2200 grams.
    I'm building a set that will weight a little over 1500g like those, and the parts alone are just under $400, so $440 for that set is great!
    "When you know absolutely nothing, anyone who knows 1% more than nothing sounds like an expert."
    Jun 2008
    The Iron Cross may be too wide for 28s. it says right in the description that they are only suitable low pressure cx tires. I don't have any experience with either rim tho: I use the Crests with Ravens and Serfas Vidas commuter tires and love them. Plan to try them next with Ritchey Speedmax 32s, tubeless hopefully.
    Master debator.
    Reputation: nOOky's Avatar
    Mar 2009
    Iron Cross, unless you plan to try road tires tubeless or need the rim brake tracks on the 340's. I have been meaning to buy a set from performancebike when they have them at 20% off ($440 also) and have them in stock.
    Idiot at large
    Apr 2010
    Quote Originally Posted by ncruz408 View Post
    A quick search on Notube's messageboard forum:
    View topic - Iron cross wheels ? Messageboard.NoTubes.com
    Iron cross is designed to run tubeless at low pressure. Most road tubeless tires will not fit. Many road tires with a tube will not fit. Running it at higher pressure is not recommened and may shorten the life span of the rim. Alpha 340 disc is the best solution if you want to run a tire at high pressure.
    I would rather get a set of Alpha 400 built up with disc hubs.
    2010 Specialized Secteur Elite with the RBR not-approved Mavic Ksyrium Elite wheelset
    2009 Specialized Rockhopper Comp 29er upgraded to SRAM X9 with 1x10 and Stan's Arch EX rims and tubeless.
    2013 Cannondale CAADX-6 Tiagra with 9-speed SLX RD to run 11-32T cassette and Stan's Alpha 400 rims and tubeless
    and
    Some Burton snowboard setups, one with stiff ol' Camber and one with Rocker-Camber-Rocker
    Sep 2008
    not on your shortlist, but: Velocity A23s run tubeless:
    Velocity Wheels
    Long Term Review: Velocity A23 Wheelset ? Comp Build
    Dec 2011
    Thanks everyone for the comments =) sale is now over I didn't purchase any wheel sets yet but still researching... was also thinking about ztr crests not sure if the rear will fit my 13 Trek Crossrip
  1. Replies: 0
    Last Post: 09-12-2012, 07:48 PM
  2. Disc Wheels for 2012 Specialized CruX Apex Disc
    By Merc in forum Wheels and Tires
    Last Post: 01-22-2012, 11:57 AM
  3. Vicious Cycle Disc vs Winwood Muddy Disc
    By crank it in forum Cyclocross
    Last Post: 06-22-2010, 11:47 PM
  4. xlab disc and shimano Pro disc used in the Tour de France
    By stussy1035 in forum Wheels and Tires
    Last Post: 04-04-2006, 04:53 PM
  5. Cannondale Cyclocross Disc or Redline Conquest Disc R?
    By theraindog in forum Cyclocross
    Last Post: 09-18-2004, 05:36 AM
