Ultegra rear derailleur 6700 max cog 1x set up
Results 1 to 2 of 2
    Jan 2011
    I am trying to figure out if I can use a short cage ultegra rear derailleur on my gravel bike. I'd like to run a cassette range of at least 11-32 if not a but bigger. I would be running either 38t or 40t up front. From the tooth calc equation it shouldnt be an issue but I am not sure. Also since it is not clutched will I have to worry about chain drop?
    Apr 2012
    Checkout Wolftooth's road link. It will allow a mid-cage 6700 handle up to a 42t cassette if I recall correctly. Definitely go with a narrow wide front ring - Wolftooth, Race Face, etc which will help with chain drop. If you plan on doing rough gravel or mtb you will probably need a clutch derailleur, else the 6700 with B screw tightened and narrow/wide front ring should be good enough.
  1. Looking to upgrade a Ultegra 6700 rear derailleur.
    By y2kota in forum Components, Wrenching
    Last Post: 10-16-2013, 11:09 AM
  2. Ultegra 6700 Rear Derailleur and Crank....
    By Tri Slow Poke in forum Components, Wrenching
    Last Post: 08-10-2012, 06:23 AM
  3. Ultegra 6700 vs. 105 5700 rear derailleur - performance and longevity?
    By AndrwSwitch in forum Components, Wrenching
    Last Post: 07-04-2011, 08:13 AM
  4. Replies: 20
    Last Post: 06-21-2011, 08:24 PM
  5. Replies: 5
    Last Post: 07-10-2010, 12:17 PM
