Crankset for a Fixed Gear - Any recommendations
Results 1 to 6 of 6
    Sep 2003
    Any recommendations for a crankset for a fixie? I'll trying to spend as little as possible. thanks!
    Old and Fixed, Moderator
    Jan 2002
    Quote Originally Posted by mexican-JUMPING-frijoles
    Any standard road crankset will work. Just use 1 chainring on either the inner or outer postion. The only thing you need to buy is short stack BMX chainring bolts. They are usually $5-10 at an LBS. I prefer using a standard road crankarms because it's easier to get a good chain line with the two ring postions.
    Dave Hickey/ Fort Worth
    Game on, b*tches!
    Reputation: Kram's Avatar
    I used whatever happened to be lying around.
    Cheap is good. Mine has a cheap Sakae (sp?) 165m crank. Works fine.
    Originally Posted by tetter
    'Pain is temporary, and there might be beer at the finish line'
    "Karma is spread in lots of different ways. You know, like herpes."
    catzilla
    "I'm an American male. This is pizza. Leave me alone!"
    Alton Brown
    ohnoIaintsuckingnomore.blogspot.com
    Game on, b*tches!
    If you don't want top spend the $$ on chainring bolts,
    just file some regular ones down or use spacers, if you have them.
    catzilla
    Alton Brown
    Jul 2002
    bmx cranks
    Visit Danscomp.com and check out Dotek cranks. Any size from 145-175 for 30 bucks.
    Slow-poke
    Reputation: PaulNYC's Avatar
    Jun 2002
    I ditto what others have said and add that you should select one with sufficient BB choices to get a good chainline. I got brand new tiagra for $30 dollars. You Do not have to spend alot of $$
