down sizing the chain rings?
Results 1 to 2 of 2
    Aug 2009
    I recently bought a Langster with 42/16 gearing which seems sufficient for now as I'm using it to lose some weight and recover from some back issues. I found myself really liking it as a single speed and being addicted to the N+1 disease, I've also acquired a Cinelli Tutto with bigger tires (38mm) and bigger gears, 46/16...
    So my question is ..Will I find a significant difference with a 46 tooth chain ring over the 42 ?..if so, and I downsize to a 42 (or ?), do I shorten the chain (like a road bike)...
    Forgive my newbie-ism, as I'm a long time roadie and we've recently moved to Arizona and my road bikes haven't arrived yet...(I wonder if I'll like on/off road capability of the Tutto over my road bikes?..hmmm)
    Reputation: OldZaskar's Avatar
    Jul 2009
    You will definitely feel that drop from a 46t to a 42t. The math works out to 70 gear inches vs 77 gear inches. But it will feel like more than a 10% change. I run a pretty big gear 53-15; 95 gear inches) in a moderately hilly area (Atlanta) and love it. But lots of guys would consider even a 46-16 leaning toward the big side. This is really dependent on your terrain, your fitness and what you're doing with the bike.
    And you're correct - to drop to a 42t, you'll need to shorten the chain. It might be better to get a new chain and size it to the new gear - keep the other chain for swapping back to the 46t.
  1. Replies: 2
    Last Post: 09-12-2013, 11:35 PM
  2. Replies: 2
    Last Post: 02-24-2012, 06:32 AM
  3. Chain length and chain rings
    By merlinluvr in forum Components, Wrenching
    Last Post: 03-29-2010, 05:32 AM
  4. chain rings 7 speed chain
    By koepsel in forum Components, Wrenching
    Last Post: 07-30-2009, 04:36 PM
  5. Chain and chain rings
    By Dank in forum Components, Wrenching
    Last Post: 09-12-2008, 04:13 PM
