HELP! Fixie Conversion on a 130mm RD frame?
Results 1 to 9 of 9
    Apr 2002
    Hi,
    I'm going to purchase a friends' steel frame to replace the old Peugeot i'm currently riding.
    I want to use my 120mm Suzue flipflop wheels on the New frame, it has 130mm rear dropout spacing, I can space out my rear hub to accomodate 130mm but i'm concerned about getting proper chain alignment with the new frame.
    Does anyone have any experience with converting a 130mm bike to fixed gear?
    what problems will I encounter? any help would be apreciated,
    thanks
    Jomas
    Tomas, You will have no problem with chainline. Chainline is nesured from the center of the seatpost to the center of the chainring. If you respace the hub it doesn't chainge the chainring on the hub. Most track hubs have a chainline of 42 mm and most road bikes have a chainline for the center ring of 43.5 mm close enough for fixed. 1.5 mm won't matter much.
    Mark
    Old and Fixed, Moderator
    Jan 2002
    Axle length might be a concern
    I've done it with Dura Ace track hubs. They have plenty of room for a couple of 5mm spacers on each side and the track nuts still get a good "bite" on the axle.. I can't speak for the length of the Suzue axle but Dura Ace works fine. Sheldon Brown sells longer axles if the Suzue is not long enough. I'll let some Suzue owners comment on the axle length..
    As Mark said, chain line is no problem as long as you use the same width spacer on each side.
    Dave Hickey/ Fort Worth
    Jun 1999
    just did it
    rebuild the rear wheel with an ENO hub, which comes in 130
    http://www.midcalracing.com/fixed/fixed.htm
    http://www.sheldonbrown.com/harris/fixed-hubs.html
    Quote Originally Posted by JOMAS
    Hi,
    thanks
    Jomas
    ENO Hub ?
    Why would he switch to an ENO hub when for $5.00 he could respace the axle ?
    Mark
    Jun 1999
    track ends? nm
    nmnmnm
    Quote Originally Posted by Mark_fixie
    Mark
    Mar 2003
    Steel? Tweak the chainstay...
    Hi,
    thanks
    Jomas
    I woudln't recommend doing it yourself unless you're particularly mechanically adept, but if you know of a bike shop that does frame straightening and similar adjustments, or maybe a local framebuilder, you should be able to take it to them and have the chainstay adjusted. It's only and adjustment of 5mm per side. Should be able to tweak a steel frame that much w/o weakening it too much, if at all.
    -Trevor
    Apr 2002
    Thanks for all of the Advice!
    I think i've got enough axle on my Suzue to stretch it to 130mm, if not i'll be talking to harris cyclery!
    thanks,
    JOMAS
    Non non normal
    Reputation: bigrider's Avatar
    Jun 2002
    How much slack will the ENO hub take up on your chain? I know it says something like 20mms but that doesn't seem like enough to tighten an entire links worth of chain and make the hub usable with any ring/tooth combo.
    Quote Originally Posted by DougSloan
    "There are only two ways to live your life. One is as though nothing is a miracle. The other is as though everything is a miracle." --A. Einstein
  1. Used frame pricing - determining fair value Blue Book!
    By 52-16SS in forum General Cycling Discussion
    Last Post: 03-17-2004, 08:48 AM
  2. Help me put a year/model to this frame!
    By Auriaprottu in forum Other Builders
    Last Post: 03-09-2004, 01:38 PM
  3. Looking for a new frame...
    By TACSTS in forum Hot Deals
    Last Post: 03-02-2004, 06:03 AM
  4. Semi-vertical dropouts OK for a fixie frame?
    By lml1x in forum Fixed/Single Speed
    Last Post: 02-25-2004, 12:54 AM
  5. Questions about an older OCLV frame
    By ks1g in forum Trek
    Last Post: 02-11-2004, 03:04 PM
