Shimano single speed freewheel, removal tool?...
Results 1 to 9 of 9
    Riding towards Delmarva.
    Reputation: RedRex's Avatar
    Oct 2004
    Okay, the excitement is mounting. Almost finished building up my new Steamroller.
    Surly flip/flop hub came with a Surly fixed 16t cog.
    I ordered a Shimano 16t single speed freewheel, and spun it on the other side, great.
    OOps, I forgot to put some grease on the threads.......so.....two questions....
    I see many tools on Sheldon's site for removing this.....what is a good, inexpensive wrench to remove the freewheel?
    And......is there some sort of 'cap' that needs to go on the black, grooved, outer edge of the Shimano freewheel, or do you leave it as-is?
    Done with winter.
    Reputation: asterisk's Avatar
    Oct 2003
    Park FR-6 should work but really just head on over to your LBS and ask for a cheap BMX freewheel tool. You probably won't be taking it off and on a lot so any compatible tool will work. Also for greasing the threads I'd use anti-seize grease.
    There's no cap that I know of... some AC Racing freewheels come with one but I doubt you can buy them seperately.
    Oct 2004
    Thanks.
    I have this "thing" for shiny cassettes (I ride too much), so I suspect I might pull the cogs in the winter to make them shine again.
    Is removal similar to a cassette; chainwhip + freewheel tool?
    Done with winter.
    Oct 2003
    Quote Originally Posted by RedRex
    Easier, just the freewheel tool.
    Oct 2004
    Which way to loosen? With freewheel tool in place and handle up at 12 o'clock, loosen to front or rear of bike?
    Done with winter.
    Oct 2003
    Normal... left->loosen, right->tighten.
    Old and Fixed, Moderator
    Jan 2002
    Once you put the tool on, thread the axle nut back on to hold it in place. It will save your knuckles...trust me on this......the voice of exerience...ouch
    When you thread the nut back on, don't tighten it all the way. Leave a little room for the freewheel to loosen
    Dave Hickey/ Fort Worth
    Reputation: ukiahb's Avatar
    Jan 2003
    a crescent wrench works well to turn the freewheel remover (CCW), or an alternative is to install the remover w/ the nut as was said, clamp the remover in a bench vice w/ the wheel up, then grab the wheel with both hands and turn it CCW, (as if you were steering left)....this will usually break loose even the most stubborn freewheels
    Mar 2005
    acs freewheel spanner tool
    I use the acs freewheel spanner tool, basicly the freewheel tool that is welded onto a metal handel, works much better then a large cresent whench on a regular tool and I find it eiser then using the vise also. Put tool on thread nut onto tool to keep it in place put wheel upright between your legs with tool on right side and push down, if the freewheel has been ridden a lot use a rubber mallet and give the end of the tool one or two decent blows and it will drop loose. If sheldon doesn't sell this tool, dans comp bmx mailorder sells it for $20, but well worth it
