Is there a trick for mounting bullhorn bars to stem?
Results 1 to 13 of 13
    i like whiskey
    Reputation: innergel's Avatar
    Jun 2002
    I have a set of Tsunami bullhorn bars from Chuck's (similar to the Syntace bars below) I'm trying to mount to an old Cinelli quill stem. The bars have a slight bend in them just on either side of flat section where the stem clamps. For the life of me, I cannot get the stem past this bend. It just sticks right at that spot, almost like a car would be "high-centered". There is no problem getting around the bend at the corners of the bars, but it is a little tight.
    Am I missing a trick that would get me past this point and allow me to mount the bars, or do I have a mismatch between the stem and bar size? From what I can gather, the bars are 26.0 bars.
    Old and Fixed, Moderator
    Jan 2002
    Quote Originally Posted by innergel
    You might need an open face quill stem. Some bars won't work with an older style closed stem.
    Is the stem mounted on the bike? Sometimes the bar has to be spun in a lot of different directions to get it through the stem. Having a stem already mounted on the bike can prevent this.
    Dave Hickey/ Fort Worth
    i like whiskey
    Jun 2002
    Please don't tell me that!
    Quote Originally Posted by Dave Hickey
    I've tried mounting it with the stem on and off the bike. I've tried every twisting/spinning motion I can think of. I've tried to wedge open the stem a little more. Nothing works. I was hoping there was a trick I was missing.
    If I have to find an open faced quill stem that fits, I'll commit hare-carey (sp?). The steerer tube has a 21.15 inside diameter, which is an old standard and nearly impossible to find.
    It looks like I might have to go to plan B. Using a threadless stem adaptor and a threadless stem. I wanted to keep this old school looking with the quill stem, but it's looking more and more like I'm going to have to go the Frankenbike route.
    Jan 2002
    Did you try removing the bolt from the stem and prying open the clamp a little?
    Plan B-2?
    Can you make cow horns by taking a hack saw to some drop bars that work with the stem you have?
    We have nothing to lube but our chains.
    i like whiskey
    Jun 2002
    I did, but...
    I didn't really crank on it. I'll give that another try tonight. It only needs to be opened maybe 0.6mm. If I trash the stem, it's no big deal. It was not expensive.
    Plan B-2 below is a good idea too. I've got an old set of drop bars that fit the stem.
    Dang it! This bike build is fighting me with EVERY part I try and put on. I noticed last night that the centerpull calipers are too short too. I should have just spent the cash on a custom built Mercian frame and been done with it!
    May 2004
    grease it a bit
    when you try to pry the stem open a bit, grease the bend with either soap or chainlube to aide in sliding it through.
    good luck!
    Dec 2001
    It's probably your stem...
    It's probably your stem. You said it's an older stem/ fork? So it's not a 1 inch fork? If it's not a 1 inch fork then its almost certainly a 25.8 stem clamp. You *might* be able to pry the thing open enough to mount the bars, but it's probably not a good idea.
    Don't know what to say...
    --timfire
    Chicago
    i like whiskey
    Jun 2002
    Quote Originally Posted by timfire
    It is a 1" fork but it has a 21.15mm inside diameter instead of the current 22.2mm standard. It's almost certainly a too small stem clamp. I was just hoping there might be a trick that I was missing to get it around that small bend.
    Jun 2004
    If you take the stem bolt out and thread it in from the other side and put a penny in the clamp gap and tighten the bolt the clamp will open more. The bolt will push on the penny opening the clamp evenly so that you can hopefully get your bars on. I've done this on an old Syncros Altura stem back in the day. It had a wide clamp that made it impossible to put any bars into it and the boys at Syncros told me about this little trick.
    Jan 2002
    Quote Originally Posted by wrench
    That is a great idea. I'll try that next time I have a problem
    i like whiskey
    Jun 2002
    This board never ceases to amaze me!
    The depth of knowledge in here is huge! I knew there would be plenty of ideas on things to try. If I can get the stem bolt out, I'll try this tonight. I've tried to take it out before, but I couldn't do it. It appears that the nut is somehow fixed to the bolt. We'll see how this works.
    Arrogant roadie.....
    Reputation: Dave_Stohler's Avatar
    Take it to a machinist and have him ream it out to 22.2?
    We are the 801
    We are the central shaft
  1. Brake levers for bullhorn bars .. ?
    By Steve Young in forum Fixed/Single Speed
    Last Post: 06-11-2004, 05:43 PM
  2. Carbon bars slipping in stem ... what's wrong?
    By Tahoe Gator in forum General Cycling Discussion
    Last Post: 05-14-2004, 12:47 PM
  3. stem rise & length
    By C-40 in forum General Cycling Discussion
    Last Post: 03-22-2004, 07:33 AM
  4. Best stem for carbon bars
    By saab2000 in forum Components, Wrenching
    Last Post: 03-21-2004, 07:24 PM
  5. Ritchey WCS 31.8 bars/ stem
    By my327vette in forum Components, Wrenching
    Last Post: 02-14-2004, 12:29 PM
