Track Forks vs Road Forks
Results 1 to 7 of 7
    Jan 2009
    Whats the advantage of having a 28 degree offset track fork over having a 44 degree offset road fork besides the track fork being overly twitchy? Im looking into getting a carbon fork for my new Leader frame but I dont know what to buy.
    duh...
    Jan 2005
    rake is in mm... aside from less rake, track forks are often shorter, and might not be drilled for a brake. get the one that the frame was designed for, or handling might be affected
    Dec 2004
    Given the same length (headset race to dropout)-- the track fork will actually be more stable than a road fork. Some track forks these days are drilled for a brake, but tire clearance can still be an issue.
    For sixth place, he was invincible.
    Flat Track Racer!
    Jun 2006
    I'm using a Tange track-fork on a road-frame on my commuter.
    It's no less comfortable than my road-bike, in a straight line and over surface bumps etc. It's noticeably 'more maneuverable' or 'twitchier' at low speeds (take your pick), the upshot is a combination that works well for me.
    Probably best to buy something specifically designed for the job if you're unsure
    Reputation: akatsuki's Avatar
    Aug 2005
    Sorry to hijack this thread, but I am thinking about switching out the fork on my Anchor so I can put in a brake. I don't really want to drill it. Any recommendations for something cheap with the right amount of rake?
    Miyata 1000
    duh...
    Jan 2005
    Quote Originally Posted by akatsuki
    no idea what rake or length you need, but spicercycles has a bunch of track forks. also pake, soma, steamroller, all make track forks, and iro is has a lot of forks in their bargain bin sale
    tell me, is your name your name?
    Oct 2007
    there is no advantage (actually significant disadvantage) to using a rake around which your frame was not designed. figure out what the OEM spec is and don't stray. if you absolutely *must*...no more than 5mm.
