14-32t 11-Speed Custom Cassette: STILL TRYIN'
Results 1 to 4 of 4
    Apr 2012
    A while back, I posted about changing from an 11-32 11-speed Shimano 105-compatible cassette to a more practical 14-32. Nobody makes this stock as most of you probably know.
    I built a Miche 14-32, but that didn't work out so well. The cassette ended up being about a millimeter too wide and was quite noisy, noise not due to improper indexing. My LBS said the Miche wasn't such a great fit, something I'd read around the Internet as well.
    I then tried using two Shimano Ultegra CS-R8000 cassettes, a 14-28 and an 11-32 to get the desired 14-32 combination. The fit is good, but there are still issues.
    With the 50t chainring, the cog fifth down from the largest is noisy. This is the transition cog from one cassette to the other.
    With the 34t chainring, many of the middle cogs are noisy. The chain has minimal wear, and this does not sound like an indexing issue.
    I love this cassette combination, with some nicely articulated gearing, particularly in the mid-range, but the noise is really annoying, and I worry about excessive chain wear.
    Any thoughts on this? Thanks for any input.
    Russian Troll Farmer
    Sep 2016
    Sounds like a spacer isn't properly compressed, or is the wrong thickness.
    "L'enfer, c'est les autres"
    'brifter' is a lame word.
    Components/Wrenching. Not GD.
    I work for some bike racers
    and a bunch of skateboards
    Jan 2005
    I am interested in this also! Can you measure the spacing at the transition gap?
    I canít think of anything else that cause problems. Please post if you figure it out
    Thanks
  1. Can I run Ultegra R-8000 Short Cage Derailleur with a 11-32T Cassette
    By jsebastianorozco in forum Components, Wrenching
    Last Post: 05-31-2019, 04:43 AM
  2. Replies: 7
    Last Post: 06-01-2013, 12:19 PM
  3. Swapping SRAM APEX 11-32t cassette for something more conventional
    By bryan.gurc in forum General Cycling Discussion
    Last Post: 05-26-2013, 04:30 PM
  4. Cassette change to 11-32t
    By PlatyPius in forum Components, Wrenching
    Last Post: 05-01-2011, 09:23 AM
  5. Rear derailer for a 12-32t 10 speed cassette
    By soulknight in forum Cyclocross
    Last Post: 02-05-2007, 12:16 PM
