Anyone using tubeless on non-tubeless rims (Stan's)
Results 1 to 10 of 10
    May 2002
    I currently have a Campy Shamal Ultra two-way wheelset and really like riding them with tubeless tires. I'm looking at some carbon clinchers and none (other than Corima's Aero+Tubeless which no one seems to sell) are tubeless, so I'm wondering about buying a standard clincher set and running them tubeless. Apparently it works so long as you use tubeless specific tires (e.g., Hutchinson) and some Stan's. Anyone doing this?
    Info on Stan's:
    http://www.notubes.com/Road-Tubeless-C78.aspx
    Road: Fondriest TF1 / Campy Super Record / Zipp 404 / Garmin Vector / Antares / 3T bars, stem & post
    MTB: Intense Spider / XTR disc / Fox TALAS / XTR tubeless / Time ATAC / Aliante / Thomsonn post / IRC Serac XC tubeless / Syntace stem and bar
    Favorite road: "Seven Sisters" on Mt. Tamalpais
    Favorite trail: Tahoe Rim Trail's "Kingsbury Grade to the Bench"
    'brifter' is f'ing stupid
    i've set up numerous alloy wheels w/ the stans kit and it always works great. both of the times i've tried w/ carbon clincher rims (edge/enve) it's doable, but a major pain. not sure why, maybe the sharper edge of the hook on the carbon rim makes it harder for the tire to bead up...but it's definitely a pain. ymmv...
    #promechaniclife
    Get me to In&Out
    Reputation: spookyload's Avatar
    Question for you cxwrench. How is Stans with Michelin cross tires? I have a new set of green sprint tires o would love to use tubeless on a commuter. I looked into it a few years back and they didn't recommend using them with cross tires.
    Cyclists really need to learn a little Rule #5.
    pmt
    pmt is offline
    Aug 2009
    Lots of us are; just use the correct search term "Road Tubeless" and search the forums.
    Get me to In&Out
    Adding another kink to the plan...it is on Ksryiums. I haven't heard good things about Ksyriums with tubeless.
    Reputation: pdainsworth's Avatar
    Jun 2004
    I ran Ksyrium SL's tubeless with Specialized Turbo TL tires for over a year with no issues. Great ride.
    -2014 Roubaix Expert with 2014 Roval CLX40 wheels
    -2013 Stumpjumper Elite FSR 29er
    -Funner ORRB (Off Road Road Bike) with whatever we had around the shop
    Quote Originally Posted by spookyload
    i have no idea about the michelins. a guy i work w/ runs hutchinsons and has had good luck w/ that, so it seems like it works.
    #promechaniclife
    Jul 2003
    I used Mud2's on Alpha 340 rims this season. I have my tubulars up for sale.
    Mar 2007
    Quote Originally Posted by cxwrench
    Wait a second...
    Using non-tubeless-specific tires in a tubeless setup? I thought that was a huge no-no?
    Similarly, if you use a tubeless-specific tire on a regular/converted rim, does the bead lock in to the rim as well as a tubeless-designed setup (7850's, for example) should you get a flat? The safety of the "ride-flat" aspect is a selling point, and I'm wondering if it's valid and/or retained with Stan's.
    downhill quickly
    May 2007
    Quote Originally Posted by brians647
    Wait a second...
    Well it is for me and for those IMO 170 lbs or more flying down a mountain sweeper so fast that cars can’t catch you. To me a shaped carbon bead snapping squarely into a TL rim is safer at the margin than steel or a Kevlar cord. Granted I’m not happy with the lack of tire options out there…but anything “conversion” is half measure. Otherwise slap on your light tube and favorite rubber if you’re opposed to riding tubular until options for TL tires improve.
