BRIFTER-and other lame cycling terms - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 56
  1. #26
    Russian Troll Farmer
    Sep 2016
    Quote Originally Posted by OldZaskar View Post
    Nope. "Brifter" is a coined word. A compound word is an established combined word. Think "daybreak" or "tombstone" - two words in their entirety combined into a single word. "Website" is an example of a combined term that's since been adopted... it's now a compound word.
    From a linguistic standpoint, that is one of the defining features of Germanic languages. For anybody who is fluent in modern German, there are countless examples of combined words that are an amalgam of 4 or 5 separate words, even. Some are rather long.
    "L'enfer, c'est les autres"
  2. #27
    Slowski
    Reputation: eboos's Avatar
    Mar 2011
    Bidon - I get it, it's French , but it does sound like a word for a baby bottle.
  3. #28
    Reputation: velodog's Avatar
    Sep 2007
    23c, 25c, 28c, etc. etc. etc.
    The wheel is 700[c, the tires are mm's.
    Too old to ride plastic
  4. #29
    'brifter' is f'ing stupid
    ^This^
    #promechaniclife
  5. #30
    Reputation: OldZaskar's Avatar
    Jul 2009
    But more common is the evolution of the named thing with no evolution of the name. When we started using the word "phone" (after dropping "tele-", it had one function. We've added functions - first a few (recording, autodialing) then millions (apps) and still, we call it a phone.
    Of course both arguments are correct... I just don't like the word "brifter" ;-)
  6. #31
    Reputation: ogre's Avatar
    Dec 2005
    What comes to me with my crude knowledge of Deutsch is typewriter = Schriebmaschine, or literally 'writing machine'. I suppose 'typewriter' is just as much crudely thrown together, or neologistic I suppose.
    Best one from the link below is #9 - Fingerspitengefuhl, or 'finger feeling'. (The u should have an umlaut)
    https://www.babbel.com/en/magazine/t...w-to-use-them/
    NTT, got any mega-multi-syllabic-germanic combined words you can share?
  7. #32
    Sep 2016
    Quote Originally Posted by ogre View Post
    Donaudampfschiffahrtsgesellschaftskapitän?
  8. #33
    Never Give Up!
    Mar 2009
    I don't study words, I just have opinions. You old enough to every have a work provided pager? And end up running around looking for a pay phone when you boss messaged '911'?
    Lol... I do! I use to manage them for a team of software engineers and cryptographers
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
  9. #34
    Sep 2016
    Quote Originally Posted by kiwisimon View Post
    How about a system of pedal interface where you clip in, called clipless?
    Good example; it made sense 40+ years ago, but hardly anybody still uses toe clips today. Should call them "cleat pedals" or even "click-in pedals".
  10. #35
    Reputation: Fredrico's Avatar
    Jun 2002
    Then your standards for "stupid", need adjusted.
    "Brifter" is a compound word that tells you what you're talking about, and saves time talking/typing in doing so. As such it is automatically superior to "bottom bracket" that is not only wordy--but fails spectacularly at clarifying exactly what the item in question is (it is neither at the bottom nor are there any brackets involved).
    Thats it! The support for the crank bearings is bracketed between the bottom of the downtube and seatpost, hence "bottom bracket." 19th Century lingo.
  11. #36
    Jun 2002
    Using inches to measure wheel diameters and millimeters for crank lengths.
    brifter worked really well but they are so ubiquitous now brake lever usually means brifter
    Fugly is a great adjective which works really well, it's a neologism. That's for you Mapei
    I heard the Japanese and British introduced 27" tires. Millimeters would be small enough to accurately measure smaller differences in crank lengths. And yeah, clip in to clipless pedals doesn't make an ounce of sense.
    Original users were referring to toe clips and straps. Riders just jammed their feet down on those Look pedals, no toe clip to navigate, no strap to pull--clipless!
  12. #37
    Jun 2002
    Well, some of us thought of "C," albeit abstractly, as "circumference." The height and width of the tire would deform depending on tread and rim width.
    What's the functional difference between a 25mm tire and a "26mm" tire? Who knows? Same height but slightly wider? On my bikes, the "25mm" Conti measures 23mm width and 25mm height from the rim. The "28mm" Gatorskin measures 27mm width and 25mm height.
    I've measured other tires on rims and found these numbers 25mm, 28mm aren't always the actual width or height of the tire. But they do identify girth, circumference bead to bead, and give you an idea of how they'll ride.
  13. #38
    Sep 2007
    Quote Originally Posted by Fredrico View Post
    In the French sizing system, tires are designated by a three-digit number, which may be followed by a letter. The number is the nominal outside diameter of the tire the rim was originally designed for. The absence of a letter indicated a narrow tire; "A", "B" and "C" indicated increasingly wider tires."A" was originally a tire about 30 mm wide, so the 650A rim is pretty large, 590 mm. If you add the top and bottom 30 mm tire thickness to 590, you wind up with the 650 mm tire diameter.
    The 650C size was originally intended for a quite wide tire, about 40 mm wide. Top and bottom 40 mm tire plus the 571 mm rim size again bring you to a 650 mm outside diameter, even though the rim was smaller.
    With time, however, evolutionary processes have led to different widths of tires being applied to the rim, so the nominal 650 mm designation is now more theoretical than practical.
    from
    https://sheldonbrown.com/650b.html
    As can be seen reading this, the number\letter designation(700c, 650a, 650b etc) represents the dimension of the diameter of the wheel with the tire mounted on the rim. The "c" of a 700c wheel has nothing to do with the tire alone.
    Originally smaller rims were made for larger diameter tires to keep the same wheel height across the board, hence the A, B, C designations.
  14. #39
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Or do like Homer:
    https://www.youtube.com/watch?v=TINdNEMhga4
    "With
    -- DCGriz, RBR.
  15. #40
    Banned Sock Puppet
    May 2014
    No, the wheel is 622.
    "With
    -- DCGriz, RBR.
  16. #41
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by SPlKE View Post
    Slow day at the Russian Troll Farm?
    You must spread some Reputation around before giving it to SPlKE again.
    "With
    -- DCGriz, RBR.
  17. #42
    Banned Sock Puppet
    May 2014
    You know what I think is really lame? The term HTFU.....even though I struggle to resist using it with some people on these forums.
    It's usually just a chest bumping, boner wagging display of faux manliness. You are better off just burping, farting and grunting.
    "With
    -- DCGriz, RBR.
  18. #43
    What the what???
    Jul 2009
    You mean burfarunting, right?
    Sent from my iPad using Tapatalk
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    I was "social distancing" before it was cool.
  19. #44
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Opus51569 View Post
    Exactly!
    You must spread some Reputation around before giving it to Opus51569 again.
    "With
    -- DCGriz, RBR.
  20. #45
    Sep 2007
    Right, but the tire mounted on the rim is 700, as noted in my post from earlier today. The original 700c measurement comes from the tire\rim combination which necessitated a tire of a certain width measured in mm's.
    I should have written the tire mounted on the rim constitutes the wheel, which is700c.
  21. #46
    Banned Sock Puppet
    May 2014
    700c is nothing more than an arbitrary designation. As you said, for this to be a true measurement, it would be required to be a specific width. But we all know that all widths of road tires mountable to 622mm rims are designated 700c, while all widths of mountain tires mountable to 622mm rims are designated 29.
    Bike tire sizing systems are more of a cluster f*ck than car tire sizing systems.
    "With
    -- DCGriz, RBR.
  22. #47
    Sep 2007
    It's not arbitrary, but it's true worth is lost in the annals of time. At one time there was a 700c tire a 650b tire a 650a tire, but there was never a 25c tire.
  23. #48
    Jun 2002
    The Continental Ultra 2000 tires I have are printed on the sidewall, "700 x 25C." They're about 5 years old. The Gatorskins are marked "700 x 28C." WTF?
    Which leads to the question: is the size designation 25C or mm, 28C or mm, a measure of height or width?
    My measurements above seem to indicate height, and of course width would vary according to height, but not necessarily as much, depending on casing and rim width. Larger clincher road tires generally seem to be elongated in height but not equally in width. Tubular tires would stay round in height and width.
    Also, 650B et. al. are followed by another number referring to tire size. It will be larger than 25 or 28 mm, although the total diameter of the wheel with tire mounted would be the same or very close.
    IOW, I find the new insistence on millimeters just as misleading or possibly more so than the old C designations.
  24. #49
    Banned Sock Puppet
    May 2014
    It's meant to be confusing. That's what marketing is all about.
    "With
    -- DCGriz, RBR.
  25. #50
    Sep 2007
    Originally there was one tire size that in combination with a 622 diameter rim made up a 700c wheel. That was then, now there are many different width tires that fit a 622 rim, from as small or smaller than 20mm on up thru 40mm or larger. The wheel has stayed the same since its inception, but the tire has changed, and the tires change is measured in mm's. It doesn't matter that the manufacturer calls the tire size 25c, they may not care or know the history and are just printing what they think is right or what they think that the market understands.
    Why would a nominal 28mm tire be called 28c? A mm is a known, whether they hit the mark, or miss, so why settle for a "c" that means nothing unless measured in conjunction with a 622 rim, and then is only, in reality, one tire size?
  1. NNC Brifter - Lame or not
    By frdfandc in forum The Lounge
    Last Post: 04-24-2019, 07:18 AM
  2. What is the most polarizing topic in terms of cycling?
    By pittcanna in forum General Cycling Discussion
    Last Post: 09-09-2015, 02:24 PM
  3. How much is modern cycling tech really worth in terms of speed?
    By slegros in forum General Cycling Discussion
    Last Post: 04-20-2011, 04:41 PM
  4. Other Elitist Cycling Terms
    By Tschai in forum General Cycling Discussion
    Last Post: 08-17-2008, 06:24 PM
  5. terms for "the other kind of bike"?
    By DougSloan in forum Fixed/Single Speed
    Last Post: 05-10-2004, 02:57 PM
