Budget trainer
Results 1 to 18 of 18
Thread: Budget trainer
    Mar 2015
    Budget trainer
    Anyone recommend a budget trainer? Something $200 or under I don't compete I just ride for fitness and with the days getting shorter and colder I won't be able to ride as much and would like to keep up my current fitness level for spring
    Dec 2015
    I use an Elite Qubo fluid trainer which you can find for $150. The resistance is a bit inconsistent for the first few minutes until it warms up. Since it doesn't have a flywheel there's no feel of momentum like you get actually riding.
    It's mind numbingly boring until I started using Zwift too. Just need a speed sensor and a device to run any training app on.
    Rollers are more entertaining to ride but the cheap ones don't offer much resistance for high wattage intervals.
    gazing from the shadows
    Jan 2003
    I recommend one with a remote resistance adjustment. You don't want to have to get off the bike to change resistance.
    For me, budget would be $100 or less. That would be tricky to pick out, as would be finding one curbside as I did once, that cost me $0 to fix.
    Pretty much anything with solid reviews in the $150-200 range should do the trick for you. Having used fans (way back in the day we called them wind trainers), mag, and fluid, I prefer fluid by far... fwiw.
    Mar 2015
    I have never used one to be honest . What kind of resistance is it? Similar to hill climbing?
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by Tradarcher View Post
    Here ya go. You really can't beat this. It's a fluid trainer. Provides pretty good and consistent resistance. I can't out spin it.
    Extra 20% off right now making it $112.
    https://www.performancebike.com/shop...0-5839-whi-non
    Quote Originally Posted by Fajita Dave View Post
    It's a nice trainer but I hated it and returned in after one use. There's no mechanism to hold the wheel to the roller, just your body weight. So the resistance varies if you shift weight or stand, and can slip.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    The Travel Trac fluid trainer that tlg linked is a good budget trainer. I used one years ago and it provided ample resistance to stay in shape.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Jan 2003
    I would call it more like a headwind for lower settings, and a hill on higher settings. Mostly based on how fast the wheel spins down when you stop pedaling, and the effort to spin it back up to pace.
    It's not actually like either, but that's the best I can do to give you an idea. A locked in place bike + a steady resistance means it feels different from a real ride on any terrain.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    CycleOps Fluid 2... maybe a little out of your price range new but easy to find used in great condition.
    Once you set it up properly, your bike's gears let you adjust resistance.
    Jan 2003
    Quote Originally Posted by jetdog9 View Post
    All trainers do that, faster wheel speed = more resistance.
    Adjustable resistance for me is worth it, since I do like to use darn near zero resistance @90rpm during early warm up, as well as interval work where I can go from min to max (or vice versa) instantly. Winding up a bigger gear takes more time. Not a real problem for longer intervals, but for super short ones it can be. For example, sometimes I do 20 or 30 seconds, which happens to replicate most of the short efforts on the MTB trail closest to me.
    YMMV, but I found being able to adjust from the bars makes it easier to do what I want.
    Ok, easier to do what I am willing to do. Because like does not enter into the trainer equation.
    Neophyte
    Jul 2007
    All trainers at Nashbar 20% off thru this weekend.
    Aug 2012
    I've had this one for a couple of years. It's only $59!!! I've never been on a premium trainer, but for what i need it for it works fine. I'm not big on indoor riding, but I use it about a dozen times each winter. Note: you don't need to get off it to adjust resistance.
    Search Amazon
    BestMassage Bike trainer stand bicycle trainers road bike trainer for indoor riding magnetic bike trainer with 5 Levels Resistance
    Dec 2006
    If I've got your location correctly, I check craigslist and see some Cyclops fluid trainers, and a Blackburn mag trainer, and a Kurt Kinetic, all for sale. Get the Kurt if you can.
    Reputation: Srode's Avatar
    Aug 2012
    I see Cyclops and Kurt Kinetic fluid trainers regularly for $150 and under on Craigs list and our local Facebook cycling stuff for sale page. Both are very good trainers
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Dec 2015
    I never had problem with wheel slip unless I tried. Starting a sprint it takes a second for the resistance to turn up but it doesn't feel the same as wheel slip. Either way I wouldn't buy this one again. Something with more reliable resistance and a flywheel to get the feeling of some momentum would be way better.
    I like the look of that travel trac for a budget trainer.
    .je
    .je is online now
    Reputation: .je's Avatar
    Aug 2012
    I had that trainer in my garage last winter, in below freezing temps, and it made a horrible ratchety clicking noise at low temps. Nashbar said it wasn't meant to be used in cold temperatures like that. So maybe there's that to consider.
    I couldn't figure out why it made that noise. Anyone know?
    Jul 2007
    Did you make a choice yet? I am looking for a trainer that will increase the difficulty when going up hills. It seems like they will be in the mid 300 range but I am hoping I can find a black friday deal!
    Mar 2015
    I found a really good deal on an cycleops fluid 1 so I picked it up to try out and I will get a better one later if need be.
    I want to warn people about the ELITE QUBO trainers.
    I had one - not the Smart trainer variety - the regular fluid trainer. At first I liked it because its already assembled sort of. However, over time, the trainer became increasingly noisy,
    I was about to take it apart, but ran out of motivation. Finally, out of desperation I bought a CyclOps Fluid (also not smart) trainer which has a fixed rear wheel support system. Its a little more work to assemble out of the box, but its worth it - Quiet as a Kitten. It too has a roller, but the entire weight of the rider is distributed better. As for the old Elite Qubo, its in my garage awaiting the next trip to the dump.
    I was very disappointed with Elite, and their web site - complete lack of support. The only thing they said was to contact the seller. (no help whatsoever). Its their website and their reputation. I would not recommend any of their products in the future. The best I can say is it USED TO work well, for about 2 years. But it was noisy even then.
    Please see message on the Elite Forum about my noisy roller (Quno Fluid + noisy roller - Elite forum).
  1. A Retro/Modern SS Conversion Budget/Blown Budget Build
    By Opus51569 in forum Fixed/Single Speed
    Last Post: 07-27-2013, 05:18 PM
  2. Good budget Trainer
    By ACTIVATEnow in forum General Cycling Discussion
    Last Post: 06-03-2013, 03:55 AM
  3. Help... Trainer on a budget
    By El Caballito in forum General Cycling Discussion
    Last Post: 02-09-2009, 04:40 PM
  4. How much difference in trainer-to-trainer resistance?
    By lnd in forum Racing, Training, Nutrition, Triathlons
    Last Post: 02-12-2006, 12:00 AM
  5. Trainer - limited budget
    By snoword in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-09-2005, 06:15 PM
