Cadence, Power, and Speed
Results 1 to 20 of 20
    Jun 2005
    I used to ride with a cadence of around 60-80 rpm. Then, after doing some reading, I upped that to 80-100 to protect my knees and improve efficiency. I generally ride at around 82-85 rpm.
    Then I did a little experiment.
    I did a ride (Alpine Splash) on the Expresso bike at my gym - 2.93 mi
    The first time, I did it in 11:41, and put out about 164 watts
    Second time: 11:18, 190W
    Third time: 11:06, 196W
    at this point, I noticed that the guys on the leaderboard who were just a little faster than me (1-3 sec) generally put out 10-20 fewer watts.
    The fourth time, I really kept an eye on the wattage, and tried to keep a constant effort of 190W. I ended up with 187W and 10:57. My PR.
    The fifth time, I focused on cadence. I kept my cadence to 90rpm. I put out 209W, which was my highest power output, but my time was 11:19. My second slowest time.
    I don't know what my average RPM was on any of the other ride. I do know that it was significantly lower. Probably in the 60s or 70s. I just seem to pedal slower on the stationary bike.
    So here are a few possible conclusions:
    1. I would be faster on the road with a lower cadence.
    2. Expresso's calculations should not be trusted, and will not translate to the road.
    3. I am missing other variables including the fact that I used two different Expresso bikes, time of day, how well rested I was, etc.
    What do you guys think?
    Also, would this thread be better suited to the Training/Racing forum?
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by TiCoyote View Post
    I put out 209W,.... my time was 11:19.
    So you put out 22 more watts but were 22 sec slower. That's a 12% increase in power. Pretty significant.
    Whatever this Expresso thing is.... it should not be trusted. On the road... or in the gym.
    Reputation: taodemon's Avatar
    Mar 2014
    I am not familiar with expresso bikes but most likely just the two different bikes are causing the differences. I'm pretty sure that x amount of watts over y distance should result in z time regardless of the rpm used to achieve it. These bikes don't factor in rider weight or have some place where that can be set do they? I guess something like that would also affect the results.
    Apr 2015
    Your FTP is based only on power. FTP is a representation of your cycling fitness. I would go with power.
    Sep 2011
    more power should always be done at higher cadence. Virtually no one wants to generate higher power at a lower cadence (other then done so for training purposes, but not for racing).
    Speed is variable, not a dependable measurement of fitness.
    Jun 2008
    On most long steep climbs it's not possible to carry a high cadence with a conventional cassette. It's important to train to what you expect to be riding (both gradient and cog maximums). Sometimes developing high power at a low cadence is what gets the job done.
    Reputation: Fredrico's Avatar
    Jun 2002
    Quote Originally Posted by SwiftSolo View Post
    True.
    Most riders used to walking or running find maximum aerobic efficiency around 70-80 rpm. Faster cadences require more energy just to turn the crank around. But if the heart, lungs, and cardio system delivers, faster cadences won't trash out the legs like slower cadences would, working at the same high wattages. Eddy said, "To go fast, pedal fast," 90-95 rpm tempo, 110 rpm or faster in sprints. Train up the cardio system, increase VO2 max., save the legs. OP's stats above might indicate a need to train the legs at higher cadences they can't quite handle yet.
    Quite amazing pedaling fast, "out of breath," also increases strength when working the crank at lower cadences, such as climbing or time trialing. Hinault pointed this out years ago. All a function of aerobic conditioning, training the slow twitch muscle fibers.
    Reputation: Srode's Avatar
    Aug 2012
    If this machine is intended to replicate a hilly course, it may matter where in the course you put out the watts too. Differences vs other riders may be weight related if you put that in as a variable before starting. Other than that, it sounds like you are enjoying playing around with it and you are pushing yourself on it so you are getting a good workout which is all that matters.
    The results from a machine like that aren't necessarily going to transfer to the road. In the real world, watts is watts and it doesn't matter what cadence you are riding at when it comes to the speed.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Nov 2014
    I think your equipment choice rendered your "test" invalid and fairly pointless aside from a decent workout.
    I wouldn't take anything away from those numbers.
    Oct 2013
    Does the 'expresso' bike serve coffee, that would help me a lot. I assume you had more power with expresso, it is a proven fact that wheels turn faster with caffeine.
    BANNED
    Jun 2005
    The coffee is spelled "espresso" the bike is spelled "Expresso."
    ngl
    ngl is offline
    Jan 2002
    Two things to remember:
    1. As a general rule the more consistent you keep your wattage; the more efficient you will be.
    2. As Fredrico stated, you will need to train at higher cadences for you to be efficient at higher cadences. This doesn't happen overnight.
    Oct 2013
    When commenting on Fred's posts, please quote so everyone can evaluate the discussion.
    BANNED
    Aug 2012
    Quote Originally Posted by Fredrico View Post
    Slow twitch muscles have nothing to do with cadence you know, right? Wasn't sure exactly what you meant by this comment though, maybe I miss interpreted it?
    Gravel Rocks
    Trek Domane
    Trek Crockett
    Nov 2013
    When riding on Zwift, it seems that if I'm too tired-out to maintain the desired watts by spinning, I'm also getting to tired to hold the desired watts by grinding away, but is usually what I end-up defaulting to before I pass-out I'm starting to have knee issues in my middle age, so spinning is sounding more-and-more like the desired pedal technique.
    For instant speed, like in a sprint, I'd say most humans would do better with high RPMs. Take a look at this video of Anna Meares vs a Porsche Boxster... I think she's spinning at 500 RPM
    Oct 2013
    Those porches are anemic, anyone could beat them off the line!
    BANNED
    Jun 2002
    True. Still, cranking 95 rpm is easier on the knees, and except in an all-out sprint, the legs could deliver the same power as they would geared up and pushing the same watts at 70 rpm, except the faster cadence could be just below anaerobic threshold and rider could keep going for as long as the carbs and water holds out. Sure, the climbs drive the fast twitch into play, but easing back below AT removes the lactic acid, relaxes the legs, and speeds up recovery, so the fast twitch can be used again. Spinning looks easy, but the power possible is awesome. And if rider can keep it up, there ya go.
    It's the heart and lungs that keep rider going, not the legs. The legs respond. If they purposely push on each stroke, that's deadly. The muscles never recover during the ride, and end up stiff and sore afterwards. Ride below AT the whole time, and see how easily the legs recover. Go into AT on a hill at 70 rpm and notice the burn seems to have dissipated. You're not crying in pain from the legs. It's spread out more evenly. You find your sweet spot and always make it.
    Yes, AT is the point the muscles get ahead of the heart and lungs. That happens at any speed and any cadence.
    Feb 2002
    Quote Originally Posted by PoorInRichfield View Post
    Or you could just recognize that essentially all world hour record rides for the past century or more have been at right around 100 rpm.
    Jun 2002
    Did an experiment on the stairs at work, about two stories high. I usually walk up carrying the full weight of the body up one step at a time. By the top, the calves and the quads were burning, and I was breathing heavily, thinking, "Wow, that was hard!"
    Then a couple of times I hopped up the stairs in full isometric tension, like a cyclist or runner, got to the top about 3 times faster, and easily continued the pace, no pain in the legs, just an elevated heart rate. So there's the difference, right there. 3 times faster! No pain in the legs! Slightly elevated HR that calmed right down. How about that?
    I'll credit the slow twitch spinning muscles, aerobic the whole way, not enough time for lactic acid to build up and send the alarm, "Slow down."
    ncr
    ncr is offline
    Apr 2014
    Interesting Fact: When pedalling, all cyclists leave one of the most powerful and most fatigue resistant muscles in the leg (with in some cases up to 100% slow twitch fiber content) lying idle when it could be applying maximal torque at TDC. Runners and walkers make maximal use of it.
  1. Speed vs. Cadence. Vs. Power
    By bgit in forum Beginner's Corner
    Last Post: 06-22-2018, 05:02 AM
  2. Maximum cadence and preferred cadence
    By Warrior in forum General Cycling Discussion
    Last Post: 10-15-2014, 06:41 PM
  3. Replies: 6
    Last Post: 02-04-2012, 08:38 PM
  4. Power, power and more power
    By uzziefly in forum Racing, Training, Nutrition, Triathlons
    Last Post: 04-07-2007, 11:13 AM
  5. Q's about Cadence Aero/Cadence VSR rims
    By Mike Prince in forum Wheels and Tires
    Last Post: 01-26-2007, 12:59 PM
