Campagnolo 10 Speed with Shimano Spline
Results 1 to 18 of 18
    Sswitzky
    Sep 2018
    I run Campy 10 speed, but want to buy a KICKR Core smart trainer. The current models do not have a Campy adaptor. Wahoo referred me to RSI cycles in the UK, but they no longer carry the Ambrosio cassette that would work. Does anyone have a suggestion on finding a Campy 10 speed cassette with a Shimano spline?
    Thanks
    Quote Originally Posted by sswitzky View Post
    Thanks
    Wheels Manufacturing used to make a conversion cassette but no longer do. Might be able to find one on ebay. Another option would be to take a Shimano cassette and alter the spacers to get the right width.
    May 2012
    IRD has one-not cheap though.
    https://store.somafab.com/ird10cacoca.html
    Feb 2002
    Thanks
    Is this not a question for the Components and Wrenching sub forum?
    Banned forever.....or not
    Aug 2002
    Dogbert.
    I>U
    you can run a 10-speed shimano cassette on a 10-speed campagnolo drivetrain.
    what you will need is a small length of derailleur cable.
    you place that length of cable inbetween the binder bolt and the rear derailleur cable, like so:
    works flawlessly
    My friend broke a spoke in a race and was given a shimano 10 speed wheel (hub and cassette) from support and he said it worked okay with his Campy 10 speed.
    I wouldn't invest a lot in planning on the same experience but if you can try that for free it's probably worth a try. Even if the shifting sucks who cares for the trainer as long as you can switch gears.
    Reputation: Ab24029's Avatar
    Feb 2006
    Quote Originally Posted by Speed_Metal View Post
    works flawlessly
    Interesting. Is is a Campy or Shimano derailleur?
    "Beer is proof that God loves us and wants us to be happy."
    ~ Benjamin Franklin
    Thanks
    I know this wasn't what you arked but I believe TACX smart trainers support Campy. If you are taking your bike on and off the trainer, having to constantly fiddle with derailleur adjustments to make a Shimano cassette halfway work sounds very frustrating
    Quote Originally Posted by Ab24029 View Post
    full campy 10-speed group. well, except for the cassette
    you can also spend about $50 on a jtek shiftmate if you want. but i would suspect it doesn't work any better
    Sswitzky
    Sep 2018
    Quote Originally Posted by DaveG View Post
    Yes, I know Tacx is an option as they have a Campy adaptor. Just thought the Kickr Core was a great value. Bacically, last yearís Kickr with less noise and no leg adjustment for $899. I might try the Stac Zero Halcyon (Smart Trainer) and see how it feels. 30 day return policy if needed.
    I agree that the Core may be the best smart trainer value out there but to use it you either need to find a conversion cassette or upgrade your drivetrain to 11 speed. I still have one Campy 10sp bike in my stable
    Sswitzky
    Sep 2018
    I find it hard to justify spending $800 to upgrade my drivetrain, just so I can put the bike on a $900 trainer. Iím 55 and not a racer. That extra gear has little benefit for me.
    Understood. Maybe your best option is to "downgrade" to the Snap. You save $400 and it works with any drive train. The downside is lower power accuracy, more noise, and more calibration hassles
    Jul 2019
    hello Speed_Metal, what exactly does the length of cable inside the binding bolt do that makes the campy drivetrain compatible with the shimano cassette?
    I'm facing the same issue.
    Jul 2019
    10sp campa drive train and 10sp shimano cassette discussion
    this is the photo and post you submitted:
    works flawlessly
    Reputation: Mackers's Avatar
    Dec 2009
    It slightly alters the pull ratio, just like a Shiftmate.
    Alleged "Campy fanboy" and "Einstein".
    Jul 2019
    nice! I'm giving it a try.
    thanks!
  1. Shimano Cassette Spline Height Compatibility
    By FozzieBearCa in forum Shimano
    Last Post: 03-17-2011, 05:43 PM
  2. Replies: 2
    Last Post: 09-15-2009, 02:09 PM
  3. Replies: 5
    Last Post: 09-30-2006, 05:55 AM
  4. Chainring or spline bent or is this normal?
    By baturjan in forum Beginner's Corner
    Last Post: 06-21-2005, 08:14 PM
  5. Replies: 3
    Last Post: 03-14-2004, 07:25 PM
