Cannot remove back tire after opening brake release lever?
Results 1 to 13 of 13
    Jul 2018
    I followed the instructions here to remove the back tire: https://www.chainwheeldrive.com/arti...asy-pg1442.htm
    The problem is that even with the brake release open, there isnt enough space between the pads to pull the tire.
    Somebody told me that after opening the brake release, to unscrew the barrel adjuster to increase space between the two pads. My concern is that once I reinstall the tire, Iíll have to mess around with the barrel adjuster so that the brakes work.
    The other alternative is to let some air out of the tire and then refill when i put the tire back.
    Any help is appreciated.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by rbtwenty View Post
    Yup. Really not that complicated. If you unscrew it 4 turns, you just screw it back in.... 4 turns.
    Yup.
    The other alternative is narrower tires. Or wider rims.
    Banned forever.....or not
    Aug 2002
    What size tire are you using?
    Dogbert.
    I>U
    Oct 2013
    I see cantilever brakes in your future.
    ... or just don't air your tires up until they are on.
    ... you seem to have a lot of problems, maybe you need a car.
    BANNED
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    If you spray your WD40 on the sides of the tires, it might allow the wheel to slip out easier.
    This is not as fun as ASFOS.
    Reputation: Oxtox's Avatar
    Aug 2006
    Quote Originally Posted by jetdog9 View Post
    yeah, that guy was a pro...
    Reputation: velodog's Avatar
    Sep 2007
    If you rode a fixie with no brakes you wouldn't have these problems.
    Too old to ride plastic
    'brifter' is a lame word.
    OP you seem familiar...
    I work for some bike racers
    and a bunch of skateboards
    Russian Troll Farmer
    Sep 2016
    It's 11sp trolling under his latest troll persona. I mean, is ANYBODY so dumb as to not know how to deflate their tire?
    "L'enfer, c'est les autres"
    Aug 2006
    don't think it's 11sp...the writing style is not sufficiently pedantic or condescending.
    Neophyte
    Jul 2007
    You know, I almost wish the trolling threads, instead of getting locked and deleted when they get really crazy... were moved into a sub-forum so we could go back to them for laughs. The sub-forum name would HAVE to be ASFOS.
    If I ride 15 mph for 60 minutes, now far have I gone? That wasn't even the best one.
    Reputation: 4slomo's Avatar
    Feb 2008
    If you need to remove your rear wheel, just deflate the tire.
    Reputation: Srode's Avatar
    Aug 2012
    you are putting your Jack in the wrong place, put it under the bottom bracket and the tire will come out easily.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
  1. Shimano 5800 quick release on front brake not opening
    By lights10 in forum Components, Wrenching
    Last Post: 11-28-2018, 10:00 PM
  2. Ultrashift vs 1st generation ergo brake lever & release
    By Drew Eckhardt in forum Campagnolo
    Last Post: 06-25-2012, 04:44 PM
  3. Campy brake lever quick release options?
    By Keepthemdead in forum Components, Wrenching
    Last Post: 04-24-2009, 05:22 PM
  4. help!! jammed ultegra brake quick release lever
    By krafty27 in forum Components, Wrenching
    Last Post: 10-11-2005, 07:54 PM
  5. Replies: 2
    Last Post: 04-14-2005, 08:54 PM
