Carbon bars slipping in stem ... what's wrong?
Results 1 to 4 of 4
    May 2002
    I have a 31 mm Stella Azurra Vice Versa stem and I can't seem to keep carbon bars from slipping at the prescribed 5 N*m of bolt torque. I am careful to tighten them in small amounts alternatively and sequentially to the desired torque, e.g., top right bolt a quarter turn, then bottom left quarter turn, etc., etc.
    They stay snug until I hit the occassional unseen bump and then, with a loud noise, twist just enough to piss me off. Enough bumps and they need readjustment. When I examine the bars, I note that some of the clear cote on the bars has come off and you can see where the stem has ever so slightly squeezed the carbon a bit. This was the case with my prior Modolos and is now the case with my Kestrels, so I don't think it's the bar.
    What adivce to keep em from slipping? Thanks.
    May 2002
    It sounds obvious but you should tighten it until the bar is secure. Bike component manufacturer torque specs are notorious for being incorrect.
    Aug 2003
    chalk?
    I don't own carbon road bars but I know chalk will work on carbon seatposts. I had a carbon seatpost on an MTB that refused to stay put. I rubbed sidewalk chalk on the post and it never slipped again.
    Apr 2004
    put a small piece of cardboard, like from a cereal box, around the bar, once piece, but not all the way around the bar, cut it to size so it fits concealed by the handlebar clamp.
    I used this trick with Easton carbon bars and a Easton Mag stem and the bars never slipped.
    Tighten the stem bolts until they are snug and tight. Use a little grease on the threads to prevent them from stripping.
    "...makes you strong like Ox!"
  1. stem rise & length
    By C-40 in forum General Cycling Discussion
    Last Post: 03-22-2004, 07:33 AM
  2. Best stem for carbon bars
    By saab2000 in forum Components, Wrenching
    Last Post: 03-21-2004, 07:24 PM
  3. Easton EC90 Carbon bars...longevity?...
    By Ricko in forum General Cycling Discussion
    Last Post: 03-15-2004, 12:28 PM
  4. syncros stem on carbon steerer ?
    By dirt_diggler_1 in forum General Cycling Discussion
    Last Post: 03-10-2004, 03:10 PM
  5. Ritchey WCS 31.8 bars/ stem
    By my327vette in forum Components, Wrenching
    Last Post: 02-14-2004, 12:29 PM
