Chain lube below freeezing.
Results 1 to 25 of 36
    Master debator.
    Reputation: nOOky's Avatar
    Mar 2009
    Just curious what others use. I use White Lightening all year round, but I've noticed when it's really cold out the chain gets very stiff. Riding when it's say, 15F, the shifting is a bit klunkier It works, but I'm wondering if I should switch to a different lube. It's got to handle rain and snow also.
    Feb 2002
    Oils
    Quote Originally Posted by nOOky View Post
    Unless you live in a dry and dusty climate, White Lightning is not a very good lube, and it certainly is a terrible lube when things get wet because it will quickly disappear. ProLink is an oil in solvent lube - you apply the lube and the solvent evaporates leaving an oil behind. It doesn't get stiff. You can make your own with 3-4 parts odorless mineral spirits mixed with the oil of your choice (gear lube, motor oil, etc.). Others like Rock & Roll, Dumonde Tech, and even Boeshield. Do a search on "chain lube" and you will find literally 100s of comments.
    Anphaque II
    Reputation: cda 455's Avatar
    Aug 2010
    During the Winter months I clean and lube my chain daily with kerosene.
    America's greatest threat: Congressional liberal Democrats
    Crimes Against Humanity: The History of The Democrat Party
    Bikes make girls hotter!
    Oct 2011
    I mostly make my own lubricants, Tri-Flow however is my fav but I mainly just use it on cleats.For shatty weather riding I use my normal mix of charcoal fluid and wax chain lube mixed 50/50 with motor oil. It is runny enough to get into the rollers and leaves that wet membrane feel to everything so you know it's not washing out from just road water etc.. .
    It is pretty much safe to assume I have no idea what I'm doing and that I need more fixing than my bike!
    Hai.
    Reputation: erik1245's Avatar
    Jan 2012
    Rock and Roll (blue) or Boeshield for me. That's for both the road bikes and the mountain bikes during the winter. I like them equally -- the only real deciding factor is which shop I'm heading to when I need more.
    My bikes see snow, slush, road salt, and, of course, cold. I think last winter I was riding down to about 15F.
    Man up, dumb down, and do one gear.
    /AYHSMB
    Railing the Berm of Life
    Reputation: Sheepo's Avatar
    Nov 2011
    Here is an idea, when its 15* F, stay indoors.
    Dirt is good for the soul
    Aug 2008
    Quote Originally Posted by Sheepo View Post
    Rule #8
    Master debator.
    Mar 2009
    I've had the opposite experience in the rain and during muddy mountain bike races. I use paraffin because it sticks so well and doesn't attract as much dirt.
    Reputation: Dave Cutter's Avatar
    Sep 2012
    .... I've noticed when it's really cold out the chain gets very stiff. Riding when it's say, 15F, the shifting is a bit klunkier It works, but I'm wondering if I should switch to a different lube.
    I've noticed when it's really cold out my joints get stiff. I would guess if I tried cycling when it's say, 15F, the knees and hip would be a bit clunkier but hopefully... they'd still work.
    It seems every cyclist has their own ideas about chains and lubes. I've settled on a light bicycle oil on a clean chain. Since it's the dirt and grit that [I believe] wears away at the parts... keeping the chain clean is my number one concern. A light oil applied and the [clean] chain wiped nearly dry so as not to attract debris and dirt.... works well for me.
    To clean the chain... I spray on a little simple green. Then wash with warm soapy water and allow the chain to dry completely before oiling. I sometimes use compressed air to blow dry the chain in cold weather.
    Anphaque II
    Aug 2010
    Quote Originally Posted by JoelS View Post
    Rule #8
    And rule #5 and rule #9 .
    Reputation: looigi's Avatar
    Nov 2010
    Is there a "Rule" # for using only wet/oily lubes?
    IMO, dry and solid lubes (paraffin) might be OK as long they're in the joint, but after pressure and movement force it out from between the surfaces where it's needed, it can't run back in. Wet lubes continue to wick back into the joint and provide lubrication.
    Also, dry lubes are worn into fine particles that are easily washed out by water. Wet lubes will continue to stick to surfaces.
    ... 'cuz that's how I roll.
    A wheelist
    Winter, summer, indoors, outdoors - Homebrew mixed 50/50. There are no negatives. Backpedaling the chain through WD-40 on a rag every time the bike is up on the stand keeps the chain clean and excess lube off the outside. Re-lube as needed. Job done.
    CX'er
    Reputation: bikerector's Avatar
    Oct 2012
    I've had pretty good luck the past 2 years using finish line wet lube with ceramic. It's messy as heck but keeps the rust at bay and things working. Only so much you can do against road salt in Michigan. Any dry or wax lube I've tried turns to paste and is a PITA to apply, I don't have a heated garage.
    Low rep power
    Reputation: saf-t's Avatar
    Sep 2008
    Chain-L Has worked really well for me during the past few winters here in New England, where it's consistently below freezing during the winter.
    And no, I wasn't paid for the endorsement
    We'll be back soon, there will be more of us, and next time we won't be dropping leaflets.
    “The problem with quotes on the internet is that it’s hard to verify their authenticity” – Abraham Lincoln
    Roadbike Rider
    Reputation: Chainstay's Avatar
    Mar 2004
    Viscosity increase at lower Temp
    The reason there might be an effect with temperature is the chain lube will become more viscous at lower temperatures, which might effect the ability of a wet lube to wick into the high wear areas.
    Viscosity index - Wikipedia, the free encyclopedia
    That's as far as I can take it since I have no idea how a 20 degrees C change will affect the viscosity. I am going to put some Pro Link outside as soon as it gets to freezing, (this weekend) and then I will provide a qualitative comparison.
    "It's supposed to be automatic, but actually you have to push this button. "
    — John Brunner (Stand on Zanzibar)
    Reputation: GRAVELBIKE's Avatar
    Sep 2011
    Dumonde Tech (regular and lite). Zero problems in sub-freezing weather.
    GRAVELBIKE.COM - ride everything
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by Chainstay View Post
    That might not be a very informative test, since it will only tell you how the full-strength liquid behaves. In use, the more volatile solvents evaporate, leaving the heavier oils behind as lube. If you want to really test it, I'd think you'd have to put some in an open container and leave it out long enough for full evaporation, then put the resulting residue out in the cold, and compare with a similar sample kept warm. To have enough left over to tell the difference, you might have to waste a lot of lube.
    But I don't think it makes much difference, really. Any oil-type lube is probably thin enough at the temperatures we're talking about.
    Reputation: ddimick's Avatar
    Aug 2011
    Chain-L. The end.
    Roadbike Rider
    Mar 2004
    Quote Originally Posted by JCavilia View Post
    OK I won't do it with Pro-Link, too expensive to waste on an experiment.
    I'm thinking that any difference in shifting could be related to stiffer housing. When I ride in the cold I'm just happy to stay warm and enjoy the ride.
    Pathlete and Pedalphile
    Reputation: redondoaveb's Avatar
    Jan 2011
    Quote Originally Posted by ddimick View Post
    Chain-L. The end.
    +1. The 60 degree cold winters in So. Cal. really wreck havoc on my chain.
    If you try to fail, and succeed, which have you done?
    Sep 2008
    Chain-L.
    Sep 2005
    I agree that differences in shifting are probably largely cable-related -- both stiffer housing and more drag from any lubricant on the cable inside the housing. On integrated shift/brake levers stiffer grease in the guts can also slow things.
    Reputation: Waxbytes's Avatar
    Sep 2004
    Quote Originally Posted by Dave Cutter View Post
    I find a hot rum tottie with cinnamon to work well to lubricate the joints.
    For chains any oil that stays liquid to 0 F should be good.
    Aug 2011
    Quote Originally Posted by redondoaveb View Post
    Sometimes it drops below 50 and we have to burn the furniture to survive.
    Anphaque II
    Aug 2010
    Yeah; I used to live in San Diego and when the temps dropped below 60*F we'd have to put on the Arctic down jacket and pants !
