Chronic foot pain on long rides
Results 1 to 20 of 20
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Anyone else suffer from this?
    Just my right foot, middle of the foot, and to the outside.
    Are there any specialists that will work with you like ski bootfitters, and guarantee a pain free solution?
    I get Giro at cost, so I would be looking for someone who would do custom insoles and the like. No one locally does it, so I am seeking some help online.
    Any suggestions?
    Jul 2008
    I had a similar issue with two different brands. I ended up going to a podiatrist and x-rays showed an inflamed joint in that area. Some steroids later, not as bad. This doc is also a cyclist and recommended creating a dent in the insole (whatever insole) where this issue is. To simulate this until I could narrow the spot, he gave me these pads. Once the pad was in the right place, trace the cut out and make the dent there (he had a medieval looking tool for this).
    I ended up just putting the pad under the insole and no issues since.
    I have plenty of pads I can send if you want to try this and pics of my set up if that will help.
    Feb 2005
    Sure! I’m open to anything. I ordered some off the shelf “better” footbeds for $25 that offered a satisfaction guarantee, so I will start there and get progressively more aggressive. If you could send me pics that would be great.
    Jul 2008
    Sure thing. I will send pics tomorrow. PM me your email.
    すし + Sweet Potato Kugel
    Jul 2012
    Quote Originally Posted by rideit View Post
    Buzzer.
    Many athletic running stores ad a 3D scan that can give you the differences in size between each foot and the, "thicknesses" of ankel too. At that point your right foot is actually a size 12 E and your left is an 11 D. Fleet in Syracuse cured my issues.
    Feb 2005
    My parents live a few miles from that store...however, the nearest one to me is 350 miles away.
    Jul 2008
    For the good of the order: this is what helped me (and some anti-inflammatories...).
    Attachment 325837
    Attachment 325839
    Feb 2005
    Thanks...but the attachments didn’t work.
    Russian Troll Farmer
    Sep 2016
    It sounds like perhaps your shoe isn't wide enough; I had the same problem with my Lake MTB shoes that I use on my 'gravel' bike. I took them down to my local orthopedic shoe store (Foot Performance Center in Rochester) to have them stretched on the outside metatarsils. Took a couple days for them to do it, but I no longer get pain on the outsides of my feet.
    "L'enfer, c'est les autres"
    Jul 2012
    Any suggestions?
    I had issues with the outside of my feet suffering from pain and burning sensation during rides. Supination was my diagnosis, where all the stresses were to the outside of my foot. Check your normal shoe heal wear, if it's to the outside, then you are Supination (under pronation)(see link below). Using cleats without wedges forced my feet to be flat on the pedal. The inside of my feet wants to point upward (to demonstrate take both hands like you are covering your mouth and noise when about to sneeze) in it's natural state, but the pedals, without wedges, were trying to force my feet flat and they were not happy. This caused severe pain and a burning sensation on the outside of my feet (my rides were uncomfortable and short). When I did some research and found the BikeFit website this helped me narrow down the problem. I installed wedges under my cleats so that my feet were in their normal position while clipped in. I also had to install a shim for my left leg (shorter than right leg). After making those adjustment, I never had any issues again.
    I purchased all that I needed (fitting tool, wedges and shims) from BikeFit
    https://www.verywellfit.com/pronatio...underpronation
    Apr 2013
    Any suggestions?
    i had this. it went away. for me it was the result of applying too much pressure while riding. i altered my habits and the issue went away.
    Nov 2013
    I've noticed that for some odd reason I have a tendency to put a lot of pressure on the outside of my feet for no good reason. If I consciously focus on my feet, I catch myself doing this and force myself to relax my feet and the pressure I'm putting on my outer edge of my feet goes away. If I don't consciously think about my feet, they often do ache after a long ride. (I hope that makes sense to someone other than me.)
    I get Giro at cost...
    I hate you. (Just kidding!) I've owned a lot of shoes and I think Giro makes the best shoe for the buck... although I wish they catered to freaks-of-nature with wide feet like me
    Oct 2003
    Several years ago I almost gave up riding...after thirty years. For some reason the outside of my left foot just started to kill me with a burning sensation after only four or five miles. After changing shoes and footbeds the problem was totally solved by using foot wedges between the cleat and the shoe. I mean totally disappeared over night. You may want to check this out. Good luck.
    Jul 2012
    Quote Originally Posted by hawker12 View Post
    Several years ago I almost gave up riding...after thirty years. For some reason the outside of my left foot just starting to kill me with a burning sensation after only four or five miles. After chasing shoes and footbeds the probably was totally solved by using foot wedges between the cleat and the shoe. I mean totally disappeared over night. You may want to check this out. Good luck.
    Same here. That's what I posted earlier (wedges) because the OP's symptoms sounded similar to mine.
    Feb 2005
    Did you need longer cleat bolts or some other modifications?
    Jul 2012
    Just longer cleat bolts. I posted a link earlier to Bikefit.com, who sells all that you will need.
    Feb 2005
    So, how did you know which direction to cant the cleat?
    Thanks.
    Oct 2003
    It's been a while, I can't remember. But you can start here.
    https://www.youtube.com/watch?v=az24WHp25Kg&t=272s
    Jul 2012
    Thanks.
    https://www.bikefit.com/p-28-forefoo...ng-device.aspx
    Feb 2005
    There HAS to be a $5.00 DIY solution for that...
  1. Foot Pain - No weight on ball of foot
    By funktekk in forum General Cycling Discussion
    Last Post: 03-22-2009, 06:05 PM
  2. Chronic Back Pain Anyone?
    By BentChainring in forum The Lounge
    Last Post: 11-18-2007, 06:55 AM
  3. Update on my foot pain/calf pain...
    By bismo37 in forum General Cycling Discussion
    Last Post: 09-03-2007, 08:15 AM
  4. Chronic knee pain
    By shamilton in forum Racing, Training, Nutrition, Triathlons
    Last Post: 12-13-2006, 10:56 AM
  5. need help with foot pain, hot spot and toe pain,
    By jiggs in forum General Cycling Discussion
    Last Post: 07-20-2004, 08:53 AM
