Cleat Shims
Results 1 to 3 of 3
Thread: Cleat Shims
    Cleat Shims
    My PT recommended I try boosting the height of my left leg and the only cleat shim I can find is the LeWedge by LeMond Fitness - it has proven impossible to find the shim in stock anywhere. I don't actually need the 'wedge' feature, simply a 1/8-1/4 boost in height. Has anybody used these or found an alternative option that's cheaper? $25 for some plastic shims seems a bit pricey . . . looking for a creative suggestion.
    n00bsauce
    Reputation: Mel Erickson's Avatar
    Go to a place that sells gas powered model airplanes. They have platic wedges designed to put behind the engine so the plane flys straight. They should have a variety of sizes. Otherwise your local hardware or craft store should have plastic sheets of various thicknesses and you can cut out a piece to fit your shoe/cleat.
    "Those who can make you believe absurdities can make you commit atrocities." Voltaire
    There are your fog people & your sun people, he said. I said I wasn't sure which kind I was. He nodded. Fog'll do that to you, he said.
    "We are all ignorant about most things."
    Mel Erickson
    Feb 2002
    Just get some sheet stock
    Any plastics supply house, and probably your local craft store or hardware store will have something like polyethylene sheet stock in various thicknesses. You can cut it to shape, drill & slot it for the cleat bolts, and you're good to go.
  1. SPD Cleat covers
    By HOOKEM in forum General Cycling Discussion
    Last Post: 05-17-2004, 11:20 AM
  2. do all Time pedals use the same cleat? nm
    By haiku d'etat in forum General Cycling Discussion
    Last Post: 04-26-2004, 12:17 PM
  3. m2 for easy cleat screw removal
    By coonass in forum General Cycling Discussion
    Last Post: 04-17-2004, 08:54 AM
  4. Look Cleat Alignment
    By lexington476 in forum General Cycling Discussion
    Last Post: 03-26-2004, 06:58 AM
  5. cleat placement
    By coperam in forum General Cycling Discussion
    Last Post: 03-14-2004, 04:45 PM
