Are cleat shims for a longer or a shorter leg?
Results 1 to 25 of 27
    Aug 2015
    I'm having difficulty visualizing whether a shim that goes between the cleat and the shoe would to correct a leg that is shorter or longer.
    If your right leg is longer than your left, would you shim your right or left shoe? I'm at a point where at one saddle height I get minor pain behind my right knee and 1mm lower makes that pain go away but introduces frontal left knee pain.
    I'm thinking I need to commit to one height but shim one of my shoes.
    Reputation: 9W9W's Avatar
    Apr 2012
    I went through this. I eventually threw out shims, contraptions, insole platforms, etc... and just stretched to release my tilted pelvis. Is your perceived LLD - leg length differential - structural or functional?
    I spent a good deal of money on shim kits, Hogg's stuff, etc.. in the end all I had to do was to be honest with myself and work on the cause.
    The one thing I did take away from Hogg, or rather what my fitter agreed on, was to set the seat height so there is no rocking; which coincidentally will probably put you somewhere between the two leg lengths probably towards the shorter.
    Stand straight on a wooden floor, do your toes on the shorter leg point outwards (away from body center) more than the longer leg? If so, you may have a tilted pelvis caused by a tight psoas muscle on one side. I can cause both of my toes to point straight with 5 -7 minutes of stretches.
    Also, I tried to self-fit myself for ever. I read and threw myself into everything, in the end, the resulting fit was a) incredibly more comfortable and b) way, way off from where I had it set.
    For what it's worth, I was also in a "if I move if 1/2 mm this way I get pain, but I swear this must be right" spot before seeing the fitter. The resulting change was like night and day.
    "That pretty much sums it up. I'm 43 and my max is ~178-180. If that HR chart was mine or Froome's, we'd be on the verge of death. But for you it probably looks like a normal workout." -TLG
    LOLOLOL
    Pack Fodder.
    Reputation: Alaska Mike's Avatar
    Sep 2008
    I have shims (between cleat and shoe) and orthotics for pronation. I don't have any significant leg length discrepancies. However, I do have a lot of back issues and other weird stuff, partially caused by tight hamstrings and years of a desk-bound career. I've recently tried to make more of an effort to stretch frequently, and it does help quite a bit.
    To echo what 9W9W said, before seeking mechanical fixes, I would make sure the problem isn't caused by a physical imbalance that can be somewhat easily addressed. For me, adding a device to mask a particular deficiency always "enabled" that issue, and often made things worse. The human body is an amazingly adaptable structure- when it's functioning correctly.
    Sep 2011
    shim the shorter leg
    What he said. The BikeFit site has a lot of info on how to use their wedges, and is worth checking out. I use them for pronation; seems to help
    Feb 2010
    Agree, but only if the LLD is tibial.
    Apr 2012
    Quote Originally Posted by masont View Post
    assuming it's structural to begin with. $5 says the guy has a tilted pelvis
    LOLOLOL
    Aug 2015
    Quote Originally Posted by 9W9W View Post
    I actually went to a fitter, the local university cycling teams fitter (i.e. not some 18 year old kid at Performance Bike). I went in for right knee pain and they gave me a 3mm left shoe shim and 1mm right shoe shim. My right knee pain went away but I got left knee pain so I took the shims out (after easing into the new fit and waiting several weeks). Now, with 41mm seatpost exposed, I have posterior right pain but if I go to 40mm exposed my right posterior pain goes away but left anterior pain shows up.
    The fitter said one of my legs was longer but I can't recall which. They also said I have "insufficiently flexible hamstrings" so I've been doing ~3 min holds of hamstring stretches in the evening every night. I do have a desk job but try to keep my legs fully extended as often as possible, not sure what would cause a tilted pelvis or how to fix it.
    Apr 2012
    Quote Originally Posted by thisisthebeave View Post
    I guess I was wrong then.
    I presume the shims were there for over/under pronation and not simply platform shims? Otherwise, why not just shim 2mm on one side.
    If you have tight hams, and tight psoas, your pelvis may tilt slightly causing one leg to become shorter. However, this is not because your bones are shorter, but because of the pelvic tilt effectively pulling one leg up into your torso.
    Both of your toes pointing straight out when you stand barefoot?
    LOLOLOL
    Nov 2013
    Curious... why not 2mm on the left and no shim on the right?
    .je
    .je is offline
    Reputation: .je's Avatar
    Aug 2012
    Can you instead use a negative shim on the longer leg?
    Apr 2012
    Quote Originally Posted by PoorInRichfield View Post
    not all shims are platform type, some wedge the foot to correct over/under pronation. This can also be done via foot bed, to a certain extent.
    LOLOLOL
    Reputation: George M's Avatar
    Sep 2008
    I put shims in both of my shoes to correct for Vargas and I was wondering if I really need them. I got my legs X-ray and thereís only .04 mm different. What do you guys think?
    Thanks.
    Quote Originally Posted by George M View Post
    Thanks.
    I think "Vargas" is a place in Venezuela. You can use angled shims to correct for varus or valgus which are an angle in the foot. That has nothing to do with leg length. Did the shims help your condition?
    Feb 2010
    If someone has a LLD, it is by definition structural.
    Sep 2008
    I have a slight rub on the left side of my saddle so I really don't know what's going on. After getting my legs xray I would say its not LLD. Cheap black tights and expensive red saddle helped me find that. I think it may be a matter of just playing with the shims again. How do I start?
    Reputation: velodog's Avatar
    Sep 2007
    Do your knees track straight up and down, or is one knee nearer the top tube than the other? You may be able to just twist your saddle a bit to the right.
    Too old to ride plastic
    Sep 2007
    Quote Originally Posted by .je View Post
    Either that or just file off a bit of the sole of the shoe of the longer leg.
    Feb 2010
    You go get a bike fit
    Reputation: GlobalGuy's Avatar
    Jun 2015
    Want to stabilize a foot that may be causing you problems on the bike than one reasonable possibility is to consider orthotics.
    As for leg length discrepancy, I could write an article but for the sake of brevity, I will just say that nine times out of ten leave it alone. The odds are it will cause more problems than it solves.
    If you absolutely positively can't help yourself in wanting a shim than get less than what you think it indicated.
    By the way, there are anatomical LLD and functional LLD and a combination of both.
    Sep 2008
    I've got a few bike fits already.
    Sep 2007
    Uneven saddle wear is typically a sign you have a strength or flexibility imbalance that is causing you to pedal slightly askew, rather than an indicator of an anatomically asymmetrical pelvis. However, saddle wear most commonly indicates that a rider is on the wrong width or shape saddle. The wrong saddle wonít support both sit bones and can often cause a rider to pick their favorite side, leaving the other unsupported and hanging off in space.
    copied from
    https://roadbikeaction.com/3-overloo...ed-a-bike-fit/
    Sep 2008
    Thatís the best answer Iíve ever heard. Iím ok with the width,but the power in my right leg could be part of the problem. Thanks.
    copied from
    Feb 2010
    Then go back to your fitter if it's been remotely recent and tell them what's going on. Or has it been years?
    Sep 2008
    Itís been a while and he moved to Florida anyhow. Thanks.
  1. anyone using leg shims?
    By PoorCyclist in forum Racing, Training, Nutrition, Triathlons
    Last Post: 05-30-2012, 10:47 AM
  2. Longer top tube/shorter stem or shorter top tube longer stem
    By Ranger Pride in forum Beginner's Corner
    Last Post: 01-15-2011, 09:50 PM
  3. Speedplay cleat shims and big shoes
    By ari in forum Components, Wrenching
    Last Post: 11-10-2005, 07:42 PM
  4. Cleat Shims - What to Do?
    By il sogno in forum General Cycling Discussion
    Last Post: 06-21-2005, 09:33 PM
  5. Cleat Shims
    By mimyann in forum General Cycling Discussion
    Last Post: 05-24-2004, 03:32 PM
