Disk Wheel Change
Results 1 to 11 of 11
    Oct 2013
    Disk Wheel Change
    So it looks like I'm going to be changing flats on my disk bike eventually.
    With rim brakes I just popped the lever, dropped the wheel, & layed the bike on the non-RD side. Re-inserting the rear wheel while holding the bike up by the seat was a piece of cake.
    While riding lately, I have seen others that just turn their bikes over upside down on the handlebars, which previously I considered gauche.
    Is it easier doing the upside down route with disks as inserting the disk & chain into the RD while holding the bike up by the seat seems a bit too much for me now?
    BANNED
    Reputation: nova_rider's Avatar
    Sep 2005
    I always flip the bike and shift to the large chainring and 2nd smallest cassette before removal. Install when upside down ensures proper wheel alignment and pre-shifting just makes for quicker/easier reinstall.
    'brifter' is a lame word.
    Upside down is just wrong. I can't understand why anyone would say it 'ensures proper wheel alignment' especially w/ disc brakes, that's just not true. You either get the wheel in the dropout or you don't. You risk messing up your hoods, or maybe your computer. Just pick the bike up and drop it over the wheel. If it's difficult you're doing it wrong.
    I work for some bike racers
    and a bunch of skateboards
    Reputation: Srode's Avatar
    Aug 2012
    I don't have any problems putting the bike on the wheel front or back with my disc brake bike. Takes a bit more to align the rotor to the caliper but it's certainly not difficult. If you are having problems with it, practice it a few times and you'll get the hang of it.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    BH G7 Disc
    Trek Crockett
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    Unless someone volunteers to hold the bike upright I lay it on the non-rd side, and when re-installing I always ensure the weight of the frame/fork is on the axle, front or rear, rim brake or disc, to make sure the rim and disc are centered. A little more time-consuming with thru-axles of course.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    Sep 2005
    I've seen plenty of crookly installed QR wheels, allbeit mostly rear ones. Yes, one should not need to turn the bike over, but as someone that marshals many rides and assist with repairs, it never ceases to amaze me on what I find. QR, particularly rear ones, are not nearly as binary as you think for many riders.
    Quote Originally Posted by nova_rider View Post
    I'm pretty sure I've got orders of magnitude more experience than you do. Right side up is the correct way. If you have a q/r bike you are much more likely to get the wheels in straight w/ some weight on the bike which can't do w/ it upside down. Put the axle in the dropout, put weight on the bike seat, tighten q/r. As I said previously, thru axle wheels will always be correctly aligned if the axle is installed.
    Oct 2013
    With disks, I have a hard time coordinating the chain above RD AND alignment of disk at the same time..... but that is just me!
    BANNED
    Don't worry about the chain, just get it close to the correct cog. It doesn't have to land on the exact cog when you put the wheel in. Always shift to the small cog when taking the wheel off the bike, if you get it on the 11, 12, or even 13 when you reinstall it you're good. Pedal the bike by hand to get it where it wants to be.
    Reputation: OldZaskar's Avatar
    Jul 2009
    Upside-down is just wrong - for lots of reasons. As CX said - damaging hoods, saddle, maybe other stuff.
    But, think about working on the bike at home - in a stand. Would you ever work on it upside-down? The more you work on your bike - the proper way - the easier it is to do it in the field.
    Once you have the wheel in the drops - chain and disc obviously correctly located - the weight of the bike on the wheels will work with you to ensure the wheel is seated and straight.
    If you don't believe my 45 years of playing with bikes or CX's extensive experience and expertise, watch the TdF or any pro race. If you see even one wheel swap done with the bike upside-down, I'll never argue the point again.
    This really isn't one of those "we're both right, it's just preference" things. It'd be like a new horse owner telling a 5th generation cowboy "I mount my horse from the bottom, and pull myself to the top between his hind legs by his tail."
    Feb 2002
    This. If I had a $$ for every time a wheel was slightly off because the bike wasn't allowed to "settle" on the axle with the QR open, . . . .
  1. Poal: Change name, change profession, change both?
    By mickey-mac in forum The Lounge
    Last Post: 06-11-2007, 12:07 PM
  2. Question about the black disk on my rear wheel?
    By Elfstone in forum Beginner's Corner
    Last Post: 06-29-2006, 10:50 AM
  3. Disk Wheel 130 or 135 spacing?
    By 1Fliprider in forum Cyclocross
    Last Post: 12-05-2005, 04:16 PM
  4. best buy on clincher 700c aero rear wheel (non disk)?
    By haiku d'etat in forum Hot Deals
    Last Post: 12-22-2004, 09:38 AM
  5. pump adapter for disk wheel?
    By BenR in forum Components, Wrenching
    Last Post: 09-20-2004, 07:55 AM
