do Vittoria and Vredestein tubulars have removable valve cores?
Results 1 to 5 of 5
    I bought a used set of tubular wheels, with one Corsa Evo CX and one Fortezza Pro tubular. the guy didn't (and I do not know why) supply valve extenders. so, the valves are unreachable (this is a deep section rim). and I tried the screw-on extender, but he obviously didn't teflon tape the threads. heaven knows how he got his tires inflated, but do the above tubulars have removable valve cores? I'm probably going to have to remove tires, fit the valve extenders (the remove core, screw on valve extender, reinsert core type, not the screw on to valve type). it would help if I didn't remove the tires, and then find that the valve cores couldn't be removed. the last time I mounted tubulars, there was some off-color language.
    Banned forever.....or not
    Aug 2002
    Vittoria's have removeable valve cores.
    If you can find some old Spinergy valve extenders, your problem will be solved without removing the tires. The spinergy valve extenders had a threadded insert that gripped the presta head. When you twisted it counter-clockwise, it would open the valve.
    Dogbert.
    I>U
    gracias, senor Grumpy (nm)
    Quote Originally Posted by MR_GRUMPY
    Arrogant roadie.....
    Reputation: Dave_Stohler's Avatar
    Not quite....
    Only Vittoria Corsas have removable cores. The cheaper Vittorias (Rally, Formula 1) don't.
    We are the 801
    We are the central shaft
    Sometimes some heavy saliva in the extender will help seal it if you don't have tape- but this won't be a long-term fix
