frame for a single-speed?
Results 1 to 4 of 4
    Nov 2003
    Question frame for a single-speed?
    Does a single-speeder's frame differs in any way from an ordinary road bike with mulitple gears?
    Overequipped, underlegged
    Reputation: Kaboom's Avatar
    Jul 2003
    Some will say that geometry can vary, but the only real difference between a multi-speed and a ss/fixie is that the rear dropouts are horizontal instead of vertical. this is what allows you to adjust the chain tension moving the wheel backwards or forwards since the ir no derailer to take up the slack, while a normal speed bike has vertcal "slot in" dropouts which make alignement MUCH easier, but dont allow the wheel to move backwards or forwards relative to the frame. Hope this is heplful
    Any day is a good day to take care of one of your vehicles!
    Old and Fixed, Moderator
    Jan 2002
    Kaboom's got it.........
    Whether your building a fixed gear(the cranks always turn, you cannot freewheel) or a single speed(uses a BMX freewheel. it allows you to coast), keeping the chain tight is most important. There are many ways to keep the chain tight but the easiest method is to use a bike with horizontal dropouts. Horizontal dropouts allow you to slide the rear wheel back to get good chain tension.
    Most older steel frames used horizontal dropouts. That is why you see so many converted to fixed/SS.
    There are other ways of getting chain tension but first you need to decide on whether you what a fixed or SS and how you're going to use the bike.
    Here is more reading on the subject:
    http://www.sheldonbrown.com/singlespeed.html
    http://www.sheldonbrown.com/fixed.html
    Dave Hickey/ Fort Worth
    Apr 2004
    brakes
    Some track frames will not have brake mounts either. If you want to use brakes on your fixie, make sure you get a frame with brake mounts.
  1. Litespeed Choice - better frame, lower wheels or lower frame better wheels
    By Cool Roadie nom de Plume in forum Bikes, Frames and Forks
    Last Post: 04-15-2004, 10:29 PM
  2. Athena RD 8pd
    By rfrancisco in forum Campagnolo
    Last Post: 04-08-2004, 07:36 AM
  3. Single Speed Sentury May 8 or 9.
    By MB1 in forum General Cycling Discussion
    Last Post: 03-22-2004, 03:01 PM
  4. ebay fetish speed series frame just walked in
    By haiku d'etat in forum General Cycling Discussion
    Last Post: 03-15-2004, 12:38 PM
  5. Questions about an older OCLV frame
    By ks1g in forum Trek
    Last Post: 02-11-2004, 03:04 PM
