Front light under stem?
Results 1 to 6 of 6
    Sol
    Sol is offline
    Jan 2020
    Are there any lights or tweaks, that would allow the front light to mount under the stem?
    Dec 2015
    Bontrager blendr
    https://www.trekbikes.com/us/en_US/b...blendr_how_to/
    Sent from my SM-N950U using Tapatalk
    dcb
    dcb is offline
    Jul 2008
    I've got a Cygolite that could be mounted under the stem. The mount is adjustable.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    If you use a light that has similar mount to GoPro (ex: Garmin UT800), there are adapters and mounts you can use to at least mount the light centrally under the Garmin head unit.
    Depending on what Garmin mount you have, you could either use Garmin's quarter-turn mount meant for VIRB and UT800... or you might just need a small 3rd party adapter that screws on to Garmin mounts that don't have quarter-turn flange on the bottom. Ex: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Reputation: BCSaltchucker's Avatar
    Jul 2011
    could use one of those mount-relocation adaptors. I've got one I am not using. It puts a bar-diameter cylinder in front or below the stem, attached with a clamp around the bars. But very bulky (albeit plastic and not heavy)
    Faith is pretending to know things you don't know
    Never Give Up!
    Mar 2009
    You can do what Jetdog9 suggested, it works for me and I have never had any problems...
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
  1. Mount Bontrager ION R Light Under Stem?
    By PoorInRichfield in forum Trek
    Last Post: 01-16-2016, 05:36 PM
  2. Battery-powered front light that mounts on front fork like a Dynamo light?
    By Greg Smalter in forum Commuting, Touring and Ride Reports
    Last Post: 07-19-2013, 04:05 AM
  3. high gas prices under Bush = bad, under Obama = good
    By Andy69 in forum Politics Only
    Last Post: 06-26-2012, 10:49 AM
  4. Flashing tail light as front warning light, OK?
    By Otago in forum General Cycling Discussion
    Last Post: 11-14-2006, 07:33 AM
  5. who sells strong,light wheelsets for under $200.00?
    By oldbikes in forum General Cycling Discussion
    Last Post: 06-22-2004, 07:05 PM
