Front vs Rear Brake... Which Do You Use Most? - Page 3
View Poll Results: Which Brake Do You Use Most?
Voters
56. You may not vote on this poll
  • Front Brake
    28 50.00%
  • Rear Brake
    11 19.64%
  • Both Evenly
    17 30.36%
Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 94
  1. #51
    Reputation: BigTex91's Avatar
    Nov 2013
    You don't understand weight transfer like you think you do.
    Then feel free to enlighten me.
    What part of what I said do you disagree with? I assume it's the part you put in bold, all of which is correct - most cars (not all) are heavier at the front, and there is significant weight transfer under braking. Hence larger, vented discs and more powerful calipers on the front in most cars.
    I look forward to your response. Otherwise, just saying, effectively, “you're wrong." without elaboration give the appearance of being an ignorant douchebag. I'll assume you were just short on time.
  2. #52
    'brifter' is a lame word.
    Quote Originally Posted by BigTex91 View Post
    You're correct about the 911 and other rear engine cars having more weight at the rear of the car. If that's the extent of what you were saying I stand corrected. If you meant that they don't need larger brakes at the front because of the rear engine layout and it's weight bias, that would be incorrect. The car would still experience enough weight shift to the front under hard braking to take advantage of a larger brake on the front wheels, that explains why Porsche uses 6 piston calipers on the front and 4 piston on the rear of the 911. The rotor sizes are generally the same.
    I work for some bike racers
    and a bunch of skateboards
  3. #53
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    The GT and Turbo models have the larger front rotors
  4. #54
    Nov 2013
    Then we're in agreement. I was only citing the 911 as one example of a car that was not front heavy in static conditions. The contact patch on the front tires of a 911 still grows significantly under braking.
  5. #55
    Reputation: siclmn's Avatar
    Cars and motorcycles have shock absorbers which allow the body to shift forward and put more weight on the front wheels. That is why the front brakes are bigger. I always use both brakes because there is always some weight on the rear and I am going to stop better because of that weight on the rear wheel. It is just common sense.
  6. #56
    Quote Originally Posted by siclmn View Post
    You're kidding, right? Tell me you're kidding...
  7. #57
    Jun 2008
    Seems like we learn something new everyday here on RBR.
  8. #58
    Quote Originally Posted by SwiftSolo View Post
    I can read that as 'the laws of physics changes daily here on RBR?
  9. #59
    Mar 2004
    It's funny, you read something, you think you know what they've asked and you answer. Then you read commentary and realize your an idiot as you in no way understood what the question was.
    When ever I brake i'm always using the front and rear brake. I'm alway squeezing the front more. This is the case even on my cross bike on a 20% decline single track. Thus I answered I use my front brake the most. It would appear maybe that was incorrect, but I'm sticking with it.
  10. #60
    Oct 2013
    Smart people stay out of these discussions.... they are more entertainment!
    BANNED
  11. #61
    Quote Originally Posted by mackgoo View Post
    No, you're definitely correct. There a very few times when using the rear brake alone can be beneficial but it's definitely not necessary to do it that way. If you're 'doing it the right way' you can pretty use only the front brake.
  12. #62
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    Exactly as I said:
    Rear brake only when you're laying rubber to impress the ladies, or your buddies, or just to impress yourself.
    Extra points if you can do a side-slide and still come halting to a stop without doing something stupid.
  13. #63
    Oct 2013
    I use both.
    The only time I use just the rear is coming into a corner and need to bleed some speed, kinda just drag brake style. You need to do this before the corner is on. I don't like using the front brake on turn in, it just can go so wrong.
    ... and just rolling along and need to slow a little.
    BANNED
  14. #64
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    It's you're as in you are, not your. Speaking of idiots.
  15. #65
    It truly boggles my mind that so many people can't get that figured out. There/they're/their...were/we're...people that randomly insert apostrophes. And many of them get all pissy when you call them out on it. C'mon people, you should have that mastered in 4th grade. How are we supposed to take you seriously when you can't handle basic grammar?
  16. #66
    [REDACTED]
    May 2014
    And let's not forget to/too/two. What's more mind boggling is there are people with much higher formal education than me who make all the errors stated above. And they don't even have the excuse of English being a second language.
  17. #67
    Reputation: MaxKatt's Avatar
    May 2015
    Bravo. Could either you or cxwrench visit "Cycling Cleanest Sport" thread currently up. Thanks. OP "could care less."
  18. #68
    Mar 2004
    I grew up on the South Shore, you shood heah me tock.
    Thankfully we have members here who truly know what's important.
    Oh, and I never use exclamation points.
  19. #69
    Jun 2008
    It's a bit like the past. It's getting harder and harder to predict history. It makes you wonder if the same folks are the ones revising both.
  20. #70
    Reputation: AndreSF's Avatar
    Sep 2013
    I live in hilly San Francisco and almost exclusively use the front brake. I have way more control with that. When I need to stop more quickly than a controlled front brake application will allow, I'll employ the rear brake. This pretty much only happens on the steepest descents. I never use the back brake in a turn. That's asking for a rear wheel skid. If you're bombing the hill, you gotta slow it down before you're in the turn anyway. Same for both disc and rim brakes.
    Pop a wheelie!
    Icicle Bay a.k.a. Beetlebaum - Black Cat Disc Roadie
    Tang (CX) - 198? Curtlo Cyclocross (she's heavy, but she's mine)
  21. #71
    Quote Originally Posted by AndreSF View Post
    Not always true...as with anything it's all about control.
  22. #72
    Jun 2008
    Jeez, not you too? I'm a little shocked!
    Has your life become so boring that you have nothing better to do than critique punctuation on internet forums (notice the period rather than a question mark). Have you never been in a hurry and made spelling errors or used your instead of you're in a moment of haste.
    Consider that these are not be thesis level premises being espoused/spewed here on RBR. For many, this is something we do to piss away time between important matters. If we can help someone with a problem, question, or misinformation and not use more than a few minutes, we throw a response together.
    Does RBR have so many contributors that we can afford to piss folks off with petty bullsh!t?
  23. #73
    Obviously I don't care if I piss off someone that didn't pay attention from 1st thru 8th grade. I guess we'll both just have to deal with it.
  24. #74
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Consider that these are not be thesis level premises...."
    There should be a hyphen between "thesis" and "level," i.e., "thesis-level," to denote that the phrase modifies "premises" as a compound modifier (cf. https://www.grammarly.com/blog/hyphen/).
    I can certainly make clear what you meant, but think of RBR's foreign readers, many of whom may not be reading in their native language, and who might be confused by your gibberish.
    Word.
    Donald Trump has never had a wife he didn't cheat on.
    "Oh my god. This is terrible. This is the end of my presidency. I’m f—d.”
  25. #75
    Jun 2008
    Quote Originally Posted by xxl View Post
    Word.
    Well help me out. Is it kiss-my-ass or kiss my ass?
  1. Disc Front Brake / Rim Caliper Rear Brake Experiment
    By mrwirey in forum General Cycling Discussion
    Last Post: 02-20-2016, 04:08 AM
  2. Right front brake, left front brake?
    By tihsepa in forum Components, Wrenching
    Last Post: 03-20-2014, 10:45 AM
  3. Why is it front brake is stronger than rear brake?
    By nolight in forum General Cycling Discussion
    Last Post: 01-08-2013, 07:50 PM
  4. Front Brake vs. Rear....Which is Which????
    By bowler1 in forum General Cycling Discussion
    Last Post: 03-08-2007, 09:11 AM
  5. Rear Brake as Front Brake?
    By HillMan in forum Fixed/Single Speed
    Last Post: 05-12-2006, 08:32 AM
