Headlight Options with Very Specific Requirements
Results 1 to 17 of 17
    Witty custom user title
    Reputation: E 12's Avatar
    Jul 2008
    Most of my riding, at least during the week, is at o'dark thirty so I rely on a good headlight. I recently have tired of my Exposure Joystick that has very less than desirable mounting options which is kind of killing it for me. I'm ready for a change/update.
    So here's what I'm after:
    - In the 1000 lumen neighborhood
    - Should be able to last 1.5-2 hours on high setting so I don't have to revert to a lower output because the battery sucks
    - Easy to reach button/controls while hanging under my computer so I can adjust light output if I feel like it
    - Must be mountable under my K-Edge mount via the Go-Pro style prongs. Easy removal is VERY important to me...and hey, I like mounts.
    - Smart features would be cool I guess but not necessarily required
    I've been reading on the Garmin UT800, but being a Garmin there are some complaints. Super short battery life on high (true?), wonky smart features (reverting to daytime flash mode when passing under a streetlight, etc) That said, if you have the UT800 and dig it, I'd like to hear that too.
    Reputation: 9W9W's Avatar
    Apr 2012
    a vote for Bontrager ION RT
    I cycled through some lights so feel I can take a stab at this, since you soliciting comments.
    I owned a few Cygolites for their hot swap battery capabilities which as you can imagine significant extended my strike range at night. I'm anxious enough at my resting state, no need to be at the state line midnight with a battery that's crapping out. Those batteries diminished in power over time and I picked up Bontrager ION light.
    The ION PRO RT is compatible with a few different mounting brackets and I believe at least some are compatible with remote controls (""Connect with Garmin and Bontrager ANT+ devices for always on, battery status, and control") https://www.trekbicyclesuperstore.co...SABEgLx4PD_BwE
    The ION also includes a rear Flare R light and two two work in tandem with remote, IIRC. https://www.trekbicyclesuperstore.co...SABEgJd4fD_BwE
    Battery specs on the ION RT are 1300LM-1.5hrs, 800LM-3hrs, 400LM-6hrs, night flash-26hrs, day flash 22hrs. As you can see you an ride in 800lm mode and burst to 1K in the darkest sections, which is what I do.
    What I like about the ION - aside from its good looks, secure mounting, and compact metal case - are the side amber lights which make me more visible to perpendicular traffic in urban settings. The Rear flare R light also has side amber flashers. It's a nice combo, check it out.
    "That pretty much sums it up. I'm 43 and my max is ~178-180. If that HR chart was mine or Froome's, we'd be on the verge of death. But for you it probably looks like a normal workout." -TLG
    LOLOLOL
    May 2012
    Niterider Lumina with your choice of lumens and AliExpress adapter mount to GoPro prongs.
    https://www.aliexpress.com/item/Bike...27c24c4deMdE4i
    Jul 2012
    I use Light and Motion Urban Lights. They have the GoPro mount that can be used with K-edge. They also have a fast charge version of this light, too. I have the GoPro and helmet mount for my set of lights. I mount the light, along with my computer using This Mount
    Check out the specs on the light:
    https://www.lightandmotion.com/shop/...ing/urban-1000
    Reputation: Srode's Avatar
    Aug 2012
    I use this and very happy with it - I have the version with the bigger battery so I can run about 4 hours on high. It lights up the road about as well as an automobile. https://cygolite.com/product/tridenx-1300-osp/
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Dec 2014
    This and a roll of duct tape
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by ljvb View Post
    At that point, pros just use lasers. Even comes with yoke and mounting:
    https://phantomdynamics.com/kvant-sp...jector-system/
    Oct 2017
    I'll cast another vote for the Bontrager ION/Flare set. They are really good lights. They meet all of your requirements.
    For me, the only downsides are that the front light is a little on the heavy side, and they are not exactly cheap.
    They are built like a tank though, and have excellent battery life.
    Jun 2013
    My Exposure Strada 1200 w/gopro mount:
    Reputation: OldZaskar's Avatar
    Jul 2009
    I just bought my second CygoLite - first one lasted 5 years. Actually, it just needed a battery... which cost 1/2 that of a new light. Any light that works with a GoPro mount/adapter will work.
    I ride in the dark for 90 minutes or so, 3 days/week. On the weekend, I use the same light - in the strobe mode - for 3+ hours.
    https://www.amazon.com/Cygolite-Metr...gateway&sr=8-3
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by OldZaskar View Post
    I love my Cycolite EXCEPT that I find it frustrating that I can't get the swivel mount to sit still in one direction. I tighten the phillips screw underneath and it behaves for awhile, then loosens again.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Aug 2012
    had the same problem, blue loctite fixed it
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Banned Sock Puppet
    May 2014
    Will have to try that.
    "With
    -- DCGriz, RBR.
    May 2015
    Quote Originally Posted by colnagoG60 View Post
    Could you provide info on the GP mount and arm that you used and where you purchased? Never seen the GP mount for an Exposure Lights before.
    Jun 2013
    I ordered the mount from Exposure directly:
    https://exposurelights.com/products/...camera-bracket
    ...bought the arm kit because the Strada didn't have the clearance that I'd like under the Garmin mount I'm using. I have a 100mm stem, but a longer stem (120mm) may not have the same issue. With my setup, I can see the Strada's display through the Garmin mount arms. However with the arm kit, I had to sandpaper down the mount point on the arms, and or the gopro mount which installs on the computer mount, as the fit was a bit tight for some connections...don't remember which ones.
    May 2015
    Awesome, thanks for the response! I bought the Stem Fit Mount and have a similar problem when using the Strada upside down (interferes with the stem). Expensive little buggers when shipped to USA.
    The Exposure Lights are superb though, so it's worth the mounting hassle to me.
    Aug 2012
    Quote Originally Posted by 9W9W View Post
    I wonder if a person could plug in an external battery to charge that while it's in use? Sounds nice, but the battery life would be a bit to short for me.
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
  1. new saddle bag thread, specific requirements
    By jbinbi in forum General Cycling Discussion
    Last Post: 08-08-2013, 12:22 PM
  2. 2 Things and one very, very, very important Item
    By JohnHenry in forum The Lounge
    Last Post: 03-14-2008, 09:52 AM
  3. Rewarding. Very, very, VERY rewarding.
    By KenB in forum The Lounge
    Last Post: 12-09-2006, 03:35 PM
  4. Our house is a very very very fine house
    By thinkcooper in forum The Lounge
    Last Post: 10-22-2005, 02:09 PM
  5. Looking for crankset with specific requirements...
    By Einstruzende in forum Components, Wrenching
    Last Post: 07-05-2005, 10:55 AM
