Help! brake squeal question
Results 1 to 4 of 4
    Jun 2003
    I just mounted my new wheelset today and they were squealing horribly. The rims are OP ceramics and the brake pads are kool stops (Zero Gravity brakes). I had no problems with the old set of OP ceramic rims they are replacing or the machined walled rims I used for several rides while waiting on the new wheelset.
    The front stopped squealing after a couple of hard brakings on a nearby hilly street, the back quieted some but not completely. I would like to ride the wheelset Sat. morning, but do not want to annoy rest of LBS ride members.
    Am I correct in assuming the back squeal will also go away with a few more hard brakes?Are there any sugestions to help the situation?
    Thanks for the input, Tim
    Nov 2003
    Toe in the pads? (nm)
    Jun 2003
    I believe toe in is fine, but I will double check. Brake set up was not changed,only new wheelset. And yes the pads are made for ceramics. And as I mentioned, two previous wheelsets did not have squeal. I was wondering if this is common with new ceramic sidewalls or if there are any "secrets" I have not heard. Thanks. Tim
    Nov 2002
    I built a front wheel with an OP ceramic rim recently, and I have Kool Stop ceramic brake pads. It squealed like crazy, but I've ridden maybe 100 miles since then and it's gotten much better. I think it might even go away completely, but only time will tell. I have a cross bike with cantis, so my squealing problems are compounded.
    I also have an older ceramic rear rim that feels much smoother and doesn't squeal at all. On the new wheel, the rough ceramic texturing seems to be smoothing out a bit, as the brake pad residue fills it in. Keith Bontrager talks about this in one of of Lennard Zinn's tech columns:
    http://www.insidetri.com/train/bike/...es/1505.0.html
    Supposedly, the squealing will go away and braking will improve as the braking surface texture gets filled in with debris.
    I've found that toeing in the pads helps a little, but doesn't get to the root of the problem. The brakes will still squeal just the same once you squeeze the brake lever hard enough, but "hard enough" is higher with more toe. So it doesn't solve the problem when you brake hard. Right now, my pads are worn flat and yet the squeal has slowly gone away.
    If all else fails, I'd try new brakes... I think squealing usually is the result of a resonance, which can be disturbed by small changes. Good luck!
  1. singlespeeds: front brake only?
    By weiwentg in forum Fixed/Single Speed
    Last Post: 05-20-2004, 07:37 AM
  2. Big 'Hoods, Little Hands
    By Beantown in forum General Cycling Discussion
    Last Post: 04-26-2004, 12:01 PM
  3. Commuter brake question
    By Money D in forum Components, Wrenching
    Last Post: 04-07-2004, 05:22 PM
  4. True Temper Alpha Q brake bosses too long?
    By 1speed_Mike in forum Cyclocross
    Last Post: 03-26-2004, 03:53 PM
  5. dumb question about cantilever brake and road forks
    By sinican in forum Components, Wrenching
    Last Post: 03-19-2004, 08:33 PM
