How many miles are you getting out of DA chains?
Results 1 to 16 of 16
    Aug 2015
    My chainrings have 6,585 miles on them, my cassette has 1,135 miles on it, and my last chain only lasted 1,135 miles until .5 worn. The chain before that lasted 2,070 miles and the chain before that lasted 3,607 miles. As I type this, I guess it's possible my chainrings are worn but that seems low mileage to wear out for a fair weather only bike (I don't even ride on wet pavement much less rain) with religious maintenance.
    Darling of The Lounge
    Reputation: Retro Grouch's Avatar
    Apr 2002
    11-speed?
    Nov 2009
    Who buys dura ace chains?
    Well I have but only when the price was right.
    Feb 2005
    I usually change mine out after 6 months which equates to 2500 - 3000 miles. I recently changed out a front DA 38t chainring after 12000 miles or so. It didn't look worn but the drive train quieted down significantly afterwards. I change cassettes after 3 chains and they are starting to show wear. I lube every 200 miles or every rain ride whichever comes first with Rock n' Roll gold.
    Banned forever.....or not
    Aug 2002
    My 7800 chainrings have 55,290 miles in them. (they are still fine), and my current 7800 chain has 15,500 miles on it (still within .5% =1/16"). Time for a replacement, next year)……...11 speed chains won't last quite as long.
    Dogbert.
    I>U
    Reputation: Oxtox's Avatar
    Aug 2006
    Quote Originally Posted by MR_GRUMPY View Post
    similar to my mileages...
    7800 DA rings have 58K miles, DA cassette has ~30K, KMC chain has 10.8K.
    will probably do a big overhaul on New Year's Day...going to install new big ring, chain, pedals, saddle, bar tape. everything will be all fresh and pretty...
    Aug 2015
    11 speed Dura Ace
    I usually get 2-2.5k miles per chain so I got a little spooked ruining one at 1k miles
    I lube/wipe down (Rock n roll gold) every 80-100 miles. I’m a strong rider but I’m religious with maintenance.
    Oct 2018
    When checking chain wear do you take one sample reading or multiple readings? Sometimes I find some variations in readings so I take several to get a feel of the true wear.
    Aug 2015
    Quote Originally Posted by factory feel View Post
    Whenever they're on sale I buy several. The difference between Ultegra and DA chains is maybe $3-5/ea.
    Oct 2018
    The Dura Ace chain now comes with one quick link. I’m not sure if Ultegra does or not. Dura Ace is also lighter in weight.
    Reputation: Srode's Avatar
    Aug 2012
    About 5000 miles before I change it - I could go longer based on pin to pin measurement but they start to make a bit more noise than I like around then. I get them when they are discounted heavily.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Anywhere between 1 and 3 thousand depending on rain and how much gravel riding I do.
    Aug 2015
    Quote Originally Posted by pdlpsher View Post
    Yes, I take 2-3 readings. I use the Park tool that drops in if the chain is .5 worn. I had to push a little bit to get it to go in but that just means I'm a couple hundred miles away from it falling in with no pressure.
    Oct 2018
    I wonder if there’s a quality issue with the chain you got. Meaning they are slightly longer than the spec. when new. I also use DA chains and get at least 2,500 miles before 0.5% with a Park tool. Next time before you install a new chain, measure the wear. I see 0.25% on a new DA chain. A new KMC chain shows slightly less than 0.25%.
    Feb 2002
    Quote Originally Posted by thisisthebeave View Post
    Go back and check how much the chain actually elongated. Use a ruler and measure at least 12" (worn out = 1/16" elongation over 12 " = 0.5%). I'm wondering if your chain checker is giving you bad results. They are notoriously innacurate.
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    It sounds like you are replacing your chains earlier than you need to. What are you using to measure? That Park Tool chain wear meter can give multiple erroneous readings. New chains often read 0.5 right out of the box!
    Use a ruler. They don't lie.
  1. How many miles are to many miles?
    By hikertoo in forum General Cycling Discussion
    Last Post: 01-01-2011, 01:08 AM
  2. How many miles is too many miles on an AL frame?
    By Coolpick87 in forum Bikes, Frames and Forks
    Last Post: 09-09-2010, 08:27 AM
  3. Carbon fiber frame - how many miles is too many?
    By shredjim in forum Bikes, Frames and Forks
    Last Post: 05-23-2010, 01:42 PM
  4. How many miles is too many?
    By rdbike in forum Racing, Training, Nutrition, Triathlons
    Last Post: 12-18-2007, 10:16 AM
  5. San Diego Commute 15 miles, 17 miles or 40 miles
    By comuter in forum Commuting, Touring and Ride Reports
    Last Post: 05-03-2007, 02:02 PM
