How much mileage is "high" mileage?
Results 1 to 5 of 5
    Jul 2003
    I am looking at purchasing a 2000 Cannondale R1000. The bike has 5,000 miles. I don't ride very much, so that seems like a lot of miles. Is it? How does the mileage effect the frame? The rear hub has been re-built.
    Any information would be greatly appreciated.
    John
    May 2003
    Quote Originally Posted by justice29
    I still have my first good bike, a (real, pre-Trek) Klein, that has more than 50k miles on it. Still rides fine and the paint looks new. Unless the frame has been seriously crashed, 5k is nothing. Inspect the frame well though. Look for anything that would indicate cracking around the welds.
    Nov 2001
    5000 miles is not much for the frame...
    you may need to replace a chain or a cassette, or brake pads..
    but that's how long it take to become "one with the bike"
    Feb 2002
    I know "high mileage" when I see it
    1200 miles per season is NOT high mileage. I have a bike that is two years older than this, and it has 60K miles on it. Most would consider that high mileage. In 5K miles with good components, it is possible that nothing on this bike has worn out other than tires. The most that would be worn would be chain and cassette (plus tires). It's likely time to overhaul the hubs, clean and lube the brakes. BB, headset, cables, and derailleurs, but that's it. I would not consider this a cream puff, but it's pretty close.
    hi, I'm Larry
    Reputation: bimini's Avatar
    Jul 2003
    Depends on how the miles were put on
    If some of the miles were on wet sandy roads, the sand can wear out the drive train real fast. Look at the chainrings. There will be some wear but if they have a sharks tooth look to them, they will need to be replaced. Remove the chain and spin the cranks should spin smoothly. Turn them over by hand and it should feel smooth. Remove the chain and measure it. On a new chain the pins will line up perfectly at the one foot mark. If they line up at 12 1/8" or more then the chain needs replace. If it is a lot more than 1/8" then the cassette probably needs replaced. Ask the seller if the chain has ever been replaced. It the answer is no and there is no more than a 1/16" stretch in the chain, I would assume the drivetrain is in great shape.
    Remove the wheels and spin the wheel while holding the hubs. It should feel very smooth, if there is any roughness at all, assume the worse (the hub needs to be replaced).
    I ride on wet sandy roads at time, I clean the drive train up after, but it takes it's toll. I find I need to replace the drive train about once a year (7-8K miles)
    John
  1. May mileage report...
    By biknben in forum General Cycling Discussion
    Last Post: 06-03-2004, 03:46 PM
  2. Chain mileage? (and other chain queries)
    By TrevorInSoCal in forum Fixed/Single Speed
    Last Post: 05-18-2004, 08:50 AM
  3. What!? No monthly mileage thread??
    By OwenMeany in forum General Cycling Discussion
    Last Post: 05-03-2004, 04:59 PM
  4. Lightweight wheelset for daily mileage??
    By 10kman in forum Wheels and Tires
    Last Post: 03-30-2004, 08:27 AM
  5. feb/ytd mileage? and, a question
    By haiku d'etat in forum General Cycling Discussion
    Last Post: 03-03-2004, 03:28 PM
