How strong are the hoods?
Results 1 to 25 of 27
    Jul 2013
    Iíve been riding for years and have never had an issue. Nor have I ever heard of an issue. But the thought is always there...
    Exactly how strong is the mounting mechanism for the hoods? Itís a semi-flexible thin strip of metal looped around the handlebar, maintained in place by mere friction that is created and held by a single screw. The hoods take a lot of force, but the components that hold them in place are small... and if any aspect fails - eg the metal strip, the friction, or the screw - you are in real trouble.
    How much force can the hoods take before one of these small parts fails? How much can one crank on them in sprints or climbs?
    Reputation: Srode's Avatar
    Aug 2012
    The only failures I have were from either crashes or people trying to move them by pushing on the sides without loosening them and those failures were the shifter composite material not the clamping parts.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Reputation: ogre's Avatar
    Dec 2005
    The clamping mechanism is plenty strong for the stresses of cycling, even for gorilla sprinting. However, the clamps can be a collection point for sweat and the clamp and bolt are subject to corrosion, so I would recommend examining yearly. Easy enough to do when you re-tape your bars, which for me is an annual event.
    Oct 2013
    Yield strenght of steel is about 50000p/sq inch. do a calculation.
    I think you can have at it, give it all you got, your going to break before it!
    LET IT GO, Go For It, Hammer Time!
    BANNED
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    More than strong enough. Been this way for oh I don't know... 100 years? I've never heard of one breaking. Have you?
    Tens of thousands of Pro riders have put more stress on them then you ever will.
    Don't worry about it.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Well...yes and no.
    ProTour cyclists are featherweights...even the 'heaviest' ProTour cyclist is still lighter than your average American. Most of these ProTour bike-setups have rider-weight limits on the components that an average American would surpass; titanium pedal spindles are limited to 180lbs many uber-light carbon rims have similar restrictions to name a few.
    That being said...the worry of the OP of the brifters slipping should be nonexistent if they're appropriately torqued and/or have carbon paste applied. IIRC Shimano specs 10Nm thereabouts?
    tlg
    tlg is offline
    May 2011
    Well...yes and no.
    Stress on the hoods isn't merely about the weight of a rider. Rider weight is insignificant. Even if you put half your body weight on the hoods, it's a pittance.
    Torque on the handlebars is what's going to create the highest stresses. And a Pro putting out 1000 watts sprinting up a 15% grade is going to put massive amounts of torque on them.
    I'm confident the OP will not exceed that.
    Quote Originally Posted by Waspinator View Post
    Do you really think someone has conducted a test and can give you an exact figure? Shimano, Sram and Campy probably have. The average Joe on the net, I doubt it.
    My guess is it's a moot point because the bars would go first.
    Jan 2005
    Aren't you in engineering? Or am I remembering wrong? Thought we had a few on the board.
    The worst case stress are probably(?) two different things for ProTour and amateurs...For ProTour riders riding on the most perfect roads in the entire world--it is almost certainly sprints....for Real World riding by average riders where 50% of their body weight on the bars can be 100% of the entire body weight of a ProTour rider---it is Real World roads with potholes and railroad crossings.
    tlg
    tlg is offline
    May 2011
    Yea
    Perfect roads for pro riders is irrelevant. I'm talking about the torque on the handlebars. Force x Distance. Even for a 150# pro, that's a LOT of stress.
    For regular riders, I agree, potholes/tracks are going to create the most stresses. And of course... millions of riders have hit them and not broke their hoods.
    I don't know who puts more stress on shifters but I know this amateur (me) isn't creating what it looks to be on cobbles at top speed with relatively small tires.
    The same shifters are used by pro cross riders.
    Definitely not the case that pro cyclist are only using shifters on perfect roads.
    I have never heard of someone breaking the shifter mount. I cannot recall a post here at RBR where someone broke one. Plenty of busted handlebars, but not the hoods. (other than a crash)
    Dec 2009
    Except you forgot to mention that pro riders have arms like school girls.
    https://www.cyclingweekly.com/news/l...n-video-356762
    Dec 2006
    Quote Originally Posted by DaveG View Post
    Ditto. There's a reason the lever band clamp and the bolt are steel. In over 40 years I've never heard nor seen one break.
    Reputation: velodog's Avatar
    Sep 2007
    I'm thinkin' that the OP, Waspinator, ran out of things to worry about.
    Too old to ride plastic
    Mar 2019
    I think it's a good question. I ( almost ) share the same concerns.
    I don't have weight on my hoods as my fit does not promote nor encourage that.
    Rather my weight , if forward weight is needed is more directed to the drops. Never the hoods, and that includes climbing.
    Thats called fit.
    But that steal cinch band that holds the shifters in place on carbon bars is a reasonable concern.
    Maybe a know all sandboxer can give a torque recommendation Huh??
    BTW I see no forward weight on the hoods in the sprint pics posted in this thread.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I've seen shifters move on the bars in minor incidents and there will be cosmetic scrapes for sure, but I've never seen one break this way. Correct clamping force will allow the shifter to be pushed in on the bar rather than anything break.
    Seriously, if you are pondering this, you really have too much spare time and need to ride your bike more.
    "With
    -- DCGriz, RBR.
    tlg
    tlg is offline
    May 2011
    I'm at work so I can't ride my bike.... but I had some time to spare.
    I ran some numbers.
    Applying 1000 lbf on the shiftier creates stresses in the clamp ~15,000 psi. I don't know what material they're using. But Shimano says their band is Plated Steel for Ultegra & Titanium for Dura Ace. Even the most generic steel has a yield of 30,000psi.
    I'd estimate the clamp could easily withstand 2000 lbf on the shifter. Lots of other bad stuff would be going on if you put that much force on it. I'm sure the bars would bend/crack first. (now I gotta find a 3D model of come bars)
    Banned Sock Puppet
    May 2014
    I ran some numbers.
    Spoken like a true engineer.
    "With
    -- DCGriz, RBR.
    tlg
    tlg is offline
    May 2011
    Uh huh
    It's impossible to generate enough force to break the shifter clamp. You'd bend/break the handlebar at the stem waaaaay before that ever happened.
    Waspinator better start a new thread... How strong are the bars?
    Banned Sock Puppet
    May 2014
    What can I say? Dr. Waspy strikes again. Isn't he the guy who ranted that thru axles were horrible and that quick releases were so much better? I vaguely remember a few other crack pot theories from him.
    "With
    -- DCGriz, RBR.
    Apr 2011
    Shouldn't the question be, "How sweaty are you?"? https://forums.roadbikereview.com/co...on-273239.html
    Oct 2013
    I am seriously worried about my crank arms shearing off!
    That can throw you over the bars, which could be a bad thing.
    BANNED
    tlg
    tlg is offline
    May 2011
    Worse..... It can slam your crotch into your top tube
    I love to climb!
    Reputation: Jwiffle's Avatar
    Mar 2005
    See, now I've actually seen people post pictures of that happening. I've never seen a broken hood clamp or anyone ever post a pic of one.
    Stop in at Element Sports. www.elementsport.com
    Get Out! Have Fun!
  1. Perpetual Gummy/ Grimy 105 shifter hoods/ Replacement hoods
    By tjanson in forum Components, Wrenching
    Last Post: 04-20-2008, 08:45 AM
  2. Hands on the hoods
    By pugdog1 in forum General Cycling Discussion
    Last Post: 06-11-2004, 10:19 AM
  3. Big 'Hoods, Little Hands
    By Beantown in forum General Cycling Discussion
    Last Post: 04-26-2004, 12:01 PM
  4. Hoods or Drops????
    By CaliforniaDreaming in forum General Cycling Discussion
    Last Post: 04-10-2004, 06:01 AM
  5. Hand pain while in hoods....any suggestions to make it stop?
    By GirchyGirchy in forum General Cycling Discussion
    Last Post: 02-28-2004, 05:58 AM
