Page 9 of 9 FirstFirst ... 789
Results 201 to 204 of 204
  1. #201
    Sep 2015
    Quote Originally Posted by factory feel View Post
    I give you an A+ for effort but I said Rear Derailleur.
    Here is your homework assignment. Review the installation/adjustment PDF manual for presuming what you have which is the earlier gen and then compare it to the PDF adjustment RD for latest gen.
    I believe you will see notable differences.
  2. #202
    Nov 2009
    Quote Originally Posted by 11spd View Post
    Hope this helps...
  3. #203
    Out riding.
    Reputation: 1500SLR's Avatar
    Sep 2018
    For example, the always more finicky front derailleur, early Di2 had two mechanical stop adjustments and more recent Ultegra and DA FD has outboard stop only and inboard stop is adjusted electronically by depressing the junction box adjust mode button and then incrementing adjusting it. Refinements to new Di2 are pretty sweet.
    Follow the bouncing ball.
    https://si.shimano.com/pdfs/dm/DM-R8050-01-ENG.pdf
    This is pretty much how you tune any Di2 bike. If you're trying to manually adjust things without going into tuning mode you've been doing it wrong.
  4. #204
    Sep 2015
    Hope this helps...
    My sense is...you didn't say it... but since you posted the inner/outer stop adjustment from new version of Di2, at least the inboard and outboard limit stop adjustment for the RD is the same for previous versus new Di2. Again, presuming you have previous gen Di2. I am filling in the blanks here...lol.
    FD FWIW is redesigned. Used to be two limiting stops for the FD, now just one.
    Thanks.
  1. Replies: 18
    Last Post: 05-20-2016, 06:40 AM
  2. Can't seem to get comfortable on my CAAD10
    By msrothwe in forum Bikes, Frames and Forks
    Last Post: 08-20-2015, 06:55 PM
  3. Can't seem to get front derailleur to shift. What do I do?
    By drim in forum Components, Wrenching
    Last Post: 03-08-2014, 12:34 PM
  4. I just can't seem to get the right jersey fit
    By Wood Devil in forum General Cycling Discussion
    Last Post: 07-25-2011, 08:48 PM
  5. I just can't seem to find a happy-medium.
    By biknben in forum Racing, Training, Nutrition, Triathlons
    Last Post: 08-18-2005, 01:51 PM
