Page 1 of 9 123 ... LastLast
Results 1 to 25 of 204
    Nov 2009
    I canít seem to get it up...
    Anything over 100psi just seems like it will split the Carbon rim.
    I hear of people running 120psi and that pressure worries me.
    I once exploded an Easton Havon Carbon rim on a mountain bike and I thought Ebola Gay had dropped Little Boy on my neighborhood!
    Anything more than 100 on my 25mm road tires is too much for my tastes.
    I pump them up every ride and stop at 100, what say you?
    Reputation: velodog's Avatar
    Sep 2007
    I pump my 25's to about 90psi and pinch test till they feel too soft, maybe a week or so. My 42's get around 50psi and are good for at least a month or longer till the handling is affected.
    oops, this is with aluminum rims, no carbon for me.
    Too old to ride plastic
    pmf
    pmf is offline
    1. I don't get carbon rims
    2. Everyone on this site seems obsessed with using huge tires pumped up to 60 psi
    3. I pump my 23mm tires to around 100 psi before almost every ride (they can skate for a day)
    4. What are called 23mm tires these days were 25mm tires 20 years ago
    5. Isn't the whole point of larger tires is that you don't inflate them as much? 125 psi is pretty high pressure. What's wrong with 100 psi? Especially if you're worried about destroying an expensive rim.
    6. Are carbon rims really that fragile?
    Nov 2009
    Quote Originally Posted by pmf View Post
    I guess they arenít until they are.
    Reputation: Akirasho's Avatar
    Quote Originally Posted by factory feel View Post
    At 100, I'm just getting started. Since you never know when your last ride will come, I alway ALWAYS drop Little Boy.
    Banned forever.....or not
    Aug 2002
    I can remember when the Specialized "Turbo" racing clincher came out. It was advertised as a 700x25, but was only 20mm wide.
    Dogbert.
    I>U
    Oct 2013
    I run 25's at 65-70F & 70-75R.... and sometimes skip checking them for the ride so they get lower.
    Really depends on your wt and what kind of roads you ride.
    I used to do a training ride that had pot holes, I filled them up to 115 for every ride, cause you never knew when you were going to hit one.
    BANNED
    Sep 2011
    a guy in our group consumes a lot of coffee and donuts before every ride. He drops a lot of Little Boys during the ride too. Damn
    Sep 2015
    Personally, I would fill them to 130 psi and if they blow, they blow. If they blow and you have name brand carbon wheels, contact the mfr and ask for a warranty set.
    Unfortunately, we don't know just how fragile carbon wheels are because there are never any reports. No follow up.
    Dead man tell no tale...and get no tail too.
    WA outdoor enthusiast
    Mar 2002
    FF - I cannot imagine anyone using a Carbon wheel when a properly inflated tire = 'seems like they will split the Carbon rim'.
    Talk about killing the buzz of a nice ride on a nice bike!!!
    Sep 2007
    What does the rim maker say for max PSI and tire width? What is the condition of the rims?
    Mar 2009
    Carbon wheels, 25mm tires, about 70ish psi... oh and i weigh 132lbs
    2007 IRONHORSE HT
    Road Warrior
    Reputation: n2deep's Avatar
    Mar 2014
    What is the published maximum pressure specified by the manufacturer? Specify rim, rim size-model and manufacturer!!
    Did you splurge on Chinese rims and are now suffering from buyers remorse?
    Nov 2009
    My rims are bontrager aeolus 5's and a set of 3's and another set of Boyds.
    I am asking this in a general way.
    Ever since my easton carbon tried to kill me at 40psi I've been leary.
    Is it worth being right if you end up dead right?
    a real member's member
    Jul 2016
    Quote Originally Posted by 11spd View Post
    Personally, I would fill them to 130 psi.
    at the op's weight, i'd go 140-150.
    Sep 2007
    Oh hell, we're all gonna die, might as well die right.
    Reputation: Lombard's Avatar
    May 2014
    Two important questions:
    1) Why would you use 120PSI unless you are well over 200lbs.?
    2) Why would you buy carbon rims when there are so many excellent and even light weight alloy rims available?
    ďStatistics are like bikinis. What they reveal is suggestive, but what they conceal is vital.Ē -- Aaron Levenstein
    What the what???
    Jul 2009
    Iím well over 200 and 100psi is the most I use for a 25mm rear tire. Donít listen to the charts, OP, trust yourself. Find the sweet spot between a rock hard ride and pinch flats.
    Sent from my iPad using Tapatalk
    The Law of Headwinds states: If the ride out is easy... wait.
    Proud luddite
    Reputation: azpeterb's Avatar
    Jun 2006
    Carbon rims are for girly men. Mine are granite.
    Huge in Japan
    Reputation: craiger_ny's Avatar
    Jun 2014
    You had me at Ebola Gay.
    Interwebs bumpersticker goes here
    May 2014
    Quote Originally Posted by Opus51569 View Post
    And there you have it. My guess is Factory Feel is just trolling again anyway.
    pmf
    pmf is offline
    Because they look cool. That's the only reason I can think of.
    Feb 2002
    That's funny. My tubes (Michelin A1, 70 gm) lose about 2 psi per day. Can you actually see that on your gauge let alone feel that it makes any difference at all in the ride? Doubtful.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Were you tubeless? If so, most manufacturers don't recommend going over 40 psi when running tubeless.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by frdfandc View Post
    Most? 40psi max? Where do you get that from. Never heard of such a thing.
  1. Replies: 18
    Last Post: 05-20-2016, 06:40 AM
  2. Can't seem to get comfortable on my CAAD10
    By msrothwe in forum Bikes, Frames and Forks
    Last Post: 08-20-2015, 06:55 PM
  3. Can't seem to get front derailleur to shift. What do I do?
    By drim in forum Components, Wrenching
    Last Post: 03-08-2014, 12:34 PM
  4. I just can't seem to get the right jersey fit
    By Wood Devil in forum General Cycling Discussion
    Last Post: 07-25-2011, 08:48 PM
  5. I just can't seem to find a happy-medium.
    By biknben in forum Racing, Training, Nutrition, Triathlons
    Last Post: 08-18-2005, 01:51 PM
