I need a bigger skullcap!
Printable View
  • 01-04-2008
    DrSmile
    I swear my head is not obscenely humongous (not that one you sickos!), I am NOT a bobblehead, but it seems every skullcap I order is made for midgets. It hurts my head after a while they're so small. I tried Nashbar and Adidas. The Nashbar one is small AND cheap, total waste of $. They all seem to be universally sized, are there any that come in sizes or are pretty big?
  • 01-04-2008
    x-ker
    **breaths in deeply**
    **smiles through clenched teeth**
    **notices that DrSmile is from the states...that would explain it**
    I believe the correct term you are looking for is "touque", not skullcap (sorry, pet peeve).
    That being said, I'm not sure which touque manufacturers make big touques. I always thought that a touque was a "one size fits all" kind of thing. I've also got a bit of a big head, but usually find that any touques I wear will stretch out within a short period of time.
  • 01-04-2008
    lsnfa
    I just ordered one from nashbar. It's a 'deMarchi contour hat' it's called but it is actually skull cap. I ordered it because they actually come in two sizes, sm/m & L/XL or something like that, unlike all the rest of 'one size fit all's. But we'll see.
  • 01-04-2008
    MerlinAma
    I wear 7 1/2" to 7 5/8" hats and have had good luck with headsweats.
    http://www.headsweats.com/
    They have many styles.
  • 01-04-2008
    Cory
    Effing pinheads...I wear an 8-1/8, and...
    I have two that fit my monster head fine--one stripey wool number from Rivendell, not on the Web site anymore but this one http://www.rivbike.com/products/list...product=22-754 is similar. It won't fit under my almost-too-small helmet very well, though. The other is a thin polyester one from REI that's reasonably warm and is undetectable under the helmet.
  • 01-04-2008
    The Flash
    I have a 7 3/4 head and have found that the Headsweats fit pretty well. I keep my hair pretty short as well.....
  • 01-04-2008
    OldRoadGuy
    I'm gonna admit my ignorance... these are to keep your head warm or sweat out of your eyes? Don't they make your head too hot?
  • 01-04-2008
    lsnfa
    How do you measure hat size?
    I have a huge head (in more ways than one) and I'm sure I'm way up there. :blush2:
  • 01-04-2008
    Creakyknees
    I thought a touque was the tall white hat that chefs wear.
    Having googled it, I now know that a touque is what I call a ski cap, and a toque could be either a ski cap or a chef's hat.
    Who says RBR is a waste of time now?
  • 01-05-2008
    24601
    It seems what you are referring to I would call a stocking cap or beanie. I don't think anyone in Texas would have a clue what a touque is! A skullcap, to me, is more of a thin tight fitting cap made from something light and stretchy. Very form fitting, and not at all like a stocking cap.
    Pet peeve of mine when someone thinks a term they use for something like this is universal. How completely pretentious and, well, stupid.
    Just like arguing over pop-soda-coke-cola. Obviously coke is right! When I ask for a coke in Texas, they ask me what kind. I do realize when I visit other places though that I should probably be more specific unless I want a Coca Cola.
  • 01-05-2008
    ARP
    Give Barry Bonds a call
    He might know something or have a source for you.... or not.
  • 01-05-2008
    FatTireFred
    8-1/8??? damn, are you Freddie Rodriguez?
  • 01-05-2008
    DrSmile
    I don't mind the quibbling about proper vocabulary, but all the stores in the USA call them skullcaps so that's what I use... I used to use them just for cycling under my helmet to keep me warm, and I stick with the thermal lined ones, but lately I have been using them also when I go out to run, ie when it's too cold to ride. They do somewhat work to keep sweat out of your eyes although that rarely works for me because I either don't sweat or I sweat buckets.
    I found a post about the Nashbar one stretching out which gives me hope, I'll try to break it in for a few weeks.
  • 01-05-2008
    Touch0Gray
    Quote:
    ok....gonna say this and duck real quick....
    you sure your head just ain't too big?.............................................. ......
  • 01-06-2008
    fishman473
    I have the same problem. My main concern is that the skullcaps don't cover my ears entirely. I have a Descent skull cap which fits a medium sized head well and covers the ears.
    However I sweat a LOT (considerably more then most people) and I find that the Descent cap gets saturated after about an hour, fine if I keep my pace up, but it gets quite chilly if I slow down or stop. So I have started using a Smartwool beanie which looks very similar to the Rivendell beanie. So far it has proven exceedingly comfortable at temperatures between 10 F and 30 F, haven't had a chance to try it at other temps yet.
  • 01-06-2008
    99trek5200
    IIRC hat size is the circumference of your head divided by pi (~3.1417). You need a fabric tape measure to wrap it around your head to determine the circumferance. You might google the issue to make sure I am right.
    If you are looking for warmth, particularly over the ears, I got the following "bucket liner"
    http://www.amazon.com/Arcteryx-Bucke.../dp/B000BCXMDO
    I found one from some military supply place on-line for $20 which included shipping.
    Oh, & I have a big mellon too. My Bell Sweep R has to be adjusted all the way out.
  • 01-06-2008
    ARP
    Another warmth solution I know of
    Clear plastic tape over the front vents of your helmet. Works very well in cold weather and the sweat vents out the rear, eliminates RAM air.
  • 01-06-2008
    Dinosaur
    I wear a skull cap in the winter to keep my ears warm. end of story.
  • 01-06-2008
    Touch0Gray
    Quote:
    hehehehe you could stuff the vents with fiberglass too.....might be a bit itchy though...
    I usually wear a headband to keep the ears warm.....my head doesn't really get cold, but then again I rarely ride if it is under 30 degrees.
  • 01-06-2008
    zooog
    I am still confused op what OP is really looking for......but in the winter a wear 2 different sull caps. PBK makes a house brand that has flaps that cover the ears and when the weather is a bit milder Santa brought me one from The Black Dog Store(martha's vineyard) that is real nice made by Garneau....good luck..:)
  • 01-06-2008
    Touch0Gray
    I got the perfect solution
    how cold again?
  • 01-06-2008
    KWL
    I tried on Gore helmet liners at my LBS a few weeks ago. I usually wear large in just about everything cycling, but the large Gore liner was too big. I ended up buying a medium with a perfect fit. The Gore are designed with nice ear coverage as well.
  • 01-06-2008
    Terex
    I have a Seirus skull cap that I bought at a ski store in colorado. Fits my 7 5/8's head just fine. Can order from Campmor at http://www.campmor.com/webapp/wcs/st...uctId=32420476
    The Headsweats dealies for use in the summer do not fit me. Waay too small.
  • 01-06-2008
    Terex
    Quote:
    I bought a pricey Gore ear warmer band and I can't hear when I wear it. Be careful with anything covering your ears.
  • 01-06-2008
    lsnfa
    7.63
    Thanks.
    RE: Your big melon: it depends on what size Bell Sweep R though.
