The Importance of Facing
Results 1 to 8 of 8
    Apr 2002
    Apr 2011
    What is the rate of bicycle frame / parts damage or premature wear due to not having the high-precision mounting face?
    MDM
    MDM is offline
    Jun 2020
    I've got mixed feelings about the need to do this. I hesitate to cut on/remove material from a frame unnecessarily, I don't have these expensive tools, and wonder why the frame manufacturer doesn't do all of this.
    Feb 2002
    Quote Originally Posted by MDM View Post
    This has been an issue for decades, though it is much less of a problem than it used to be. Decades ago the tolerances on BBs were not that tight for many brands and so bearing, axle, and cup wear were pretty much accepted. Poor BB facing contributed to the problem. Over time, things have gotten much better but that doesn't mean that some brands and perhaps just the odd frame that slips past the quality checks don't show up as issues. With the possible exception of my first "good" bike I bought in 1969, I've never had a frame that needed facing. They came properly done from the builder. But these were all high-end bikes or custom built frames. I've heard many stories over the years of poorly faced BBs, including several reports on this forum.
    Apr 2002
    I don't think that facing is much of an issue with cartridge bottom brackets. My last quality frame was bought about 19 years ago. Columbus SLX tubing. I fear that I will have a problem if I ever want to remove the bottom bracket. Years ago I tried to remove the bottom bracket because I mistakingly thought it was defective. There was play in it. I could not unscrew it all the way. I just tightened it up, and have not had an issue since. I am tempted to buy a threading and a facing tool, but I cannot justify the cost for a one time use.
    Reputation: velodog's Avatar
    Sep 2007
    With mass production probably because time=money. Independent builders most likely do it as a matter of course.
    Too old to ride plastic
    Feb 2002
    Quote Originally Posted by daniell View Post
    If the BB faces are not parallel to each other, then that applies a torque on the system, whether it be a cartridge or not. There are many different types of BB systems now and none of them work "better" when the BB shell faces are not square.
    Sep 2007
    A Phil Wood square taper BB probably doesn't care, one way or the other.
    https://phil-wood-co.myshopify.com/c...ottom-brackets
  1. importance of carbon frame, if fork/stays are carbon?
    By Philbert in forum Components, Wrenching
    Last Post: 05-16-2004, 06:28 PM
  2. Frame size panic ~ importance of standover?
    By Vegancx in forum Cyclocross
    Last Post: 04-30-2004, 01:21 PM
  3. Importance of lightweight shoes? (Rocket7)
    By ElDuderino in forum General Cycling Discussion
    Last Post: 03-19-2004, 07:01 AM
  4. Topic of greatest importance
    By Flip Flash in forum The Lounge
    Last Post: 03-15-2004, 06:23 AM
  5. New to track. or Importance of angles?
    By daneil in forum Fixed/Single Speed
    Last Post: 03-12-2004, 06:39 PM
