Are Marks (indent) on carbon fork from spacers normal? - Page 3
Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
  1. #51
    Sep 2015
    Quote Originally Posted by sheepherder View Post
    Hope these pics are a little better. The FSA compression plug in the pick is how Cannondale wants it. I don't think it was installed correctly when the bike was built but I adjusted it when I learned about them a few years back. The other plug is longer then I thought. The length brings it right to the top bearing. I'm open to using any compression plug, even a different one from what I have.
    I'm not a power full guy. 175 lbs 6 feet tall. I don't race, just love cycling. This bike is now gonna be used in the fall and my travel bike. I like taking my bike with me when I go on vacation (if possible). Stem is 100 mm and I still have all the stock spacers under the stem. 30 mm or so.
    I wouldn't mind on recommendation if those compression plugs arnt right. I just bought a new bike, another Cannondale. It's gonna be the bike I use mostly in the summer and would like to avoid any issues with it. It's a supersix so it's practically the same setup as this bike.
    Thanks for all the help. All you guys been awesome.
    OP,
    Great pics and see it a lot better. Looks like carbon now.
    Groove size and depth are a non issue. Felt that way before and new pics confirm it.
    As Cx said, deep version of the compression plug is what the doctor ordered...all the way down to top bearing from top of steerer is very robust support of the entire steerer above the bearing.
    Your size and weight are non threatening to steerer failure. You and I are close to the same size and neither of us are gorilla's to break handlebars or steerers when sprinting out of the saddle.
    Ride it in good faith. Remember, if you want to change the stress concentration away from the groove, simple change the stack height by 3mm or so lower which will move the groove under the stem clamp. Btw, this is not necessary based upon your pic and all you describe.
  2. #52
    Out riding.
    Reputation: 1500SLR's Avatar
    Sep 2018
    It's a carbon steerer full carbon fork.
    I had someone look at it and said it's fine. I'll just keep an eye on it.
    I've usually tightened to the upper limits. I probably should just tighten to what's needed. Should thr spacers below the stem be easily turned after everything is on correctly?
    Buy a torque wrench you silly person
    Without a torque wrench on carbon component you're an accident waiting to happen
  3. #53
    Mar 2012
    Quote Originally Posted by 11spd View Post
    OP,
    Sorry to bother you again but can I ask what is that glossy layer on the outside of the steerer?
    I'm probably just getting paranoid but I uploaded pics from my new bikes steerer. Right where my finger is you can feel a slight unevenness. Like to material raises a bit. You cant see it. It starts at the top of the steerer and only goes 1 cm down. Then the steerer is smooth all the way down. It's a brand new bike. I'm just probably paranoid but I have been inspecting my stuff which is good. I just thought the steerer should be perfectly round. It's right at the edge where that line is. I know the pic probably sucks but that line goes all the way down the steerer. Like it's wrapped around the carbon and that's were it meets.
  4. #54
    Mar 2012
    Got a brand new caad13 and it has scoring right where the bottom of the stem is. Just like the pics but not that bad.
    Would you accept the bike. It's supposed to be brand new. It was boxed and built and given to me.
  5. #55
    'brifter' is a lame word.
    Yes..
    I work for some bike racers
    and a bunch of skateboards
  6. #56
    Mar 2012
    Yes..
    You see this on new bikes?
    Thanks
  7. #57
    Thanks
    It happens.
  1. axle indent in horizontal dropout
    By PoorCyclist in forum Fixed/Single Speed
    Last Post: 06-18-2014, 10:59 AM
  2. "indent" tag no longer formats correctly
    By Fredke in forum SiteFeedback/Issues
    Last Post: 08-14-2012, 10:10 AM
  3. How Normal/Abby Normal Is This?
    By Akirasho in forum General Cycling Discussion
    Last Post: 04-18-2011, 09:07 AM
  4. Replies: 2
    Last Post: 07-14-2008, 07:43 PM
  5. spacers for OS levers on normal handlebartop?
    By nick2ny in forum Cyclocross
    Last Post: 04-01-2008, 04:07 AM
