Results 1 to 16 of 16
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    McLain Rollers replacement belts?
    So, I have a 25-30 year old set of McLain rollers, and today the rear (fan) belt broke. Anyone have tips for finding a replacement, maybe something from another manufacturer? The belt is 7.5” or so long, measured from the center of the roller bolt to the center of the fan mounting bolt.
    Thanks in advance!
    acg
    acg is offline
    Feb 2011
    Quote Originally Posted by rideit View Post
    Thanks in advance!
    The belts for the Kreitler rollers may work:
    https://www.kreitler.com/spareparts/
    Merlin Extralight Campy
    Airborne Lancaster XTR
    Planet X Uncle John Campy
    Dec 2006
    I had a friend who successfully shortened the length of a tubular roller belt, Kreitler or equivalent, for a mutual friend.
    He cut it to length and butt spliced the ends together with adhesive. After the adhesive cured, he used a razor blade to shave the joint smooth.
    If you want the name of the adhesive, let me know and I'll ask my friend.
    Feb 2005
    Quote Originally Posted by Peter P. View Post
    That would be great, I can’t imagine what adhesive would be strong enough for this. I am striking out with the manufacturer...
    Dec 2006
    Give me a day or two to hear back from my friend.
    gazing from the shadows
    Jan 2003
    Thanks in advance!
    If you want to search for belts, you will want to use the circumference, not the center to center distance. Because the diameter of the pulleys makes a difference.
    Fixing it might not work, given the age you might have some rot going on. Glue might work, or you can try this method, since you won't have much to lose: https://youtu.be/fwOAD41JWG0 uses an iron to melt it together. If not, you might get a longer roller belt and try to cut it to size and melt it together, depending on if the belt is similar width.
    I would start with seeing if a Kreitler belt will work, as acg suggested. But find the circumference of your old one as your first step. Which is easy to do accurately, given it is broken.
    Feb 2005
    The old one is 24”. It is not the long belt that goes between the front and rear rollers (which is much thinner), but the rear one that connects to the wind resistance fan unit.
    Feb 2002
    If it is the typicall "tubular belt" rather than a flat belt, you might try searching for O-rings of that length. Then you'll need to sort through the materials to get a tough one - polyurethane is what you need, I think.
    Dec 2006
    I made a mistake-my friend did NOT use adhesive to join the ends of the belt together. He told me he heated the ends with a propane torch and pushed them together. He ended up with a raised ring at the junction, which he removed with a belt sander.
    Dec 2006
    If your belt is a similar diameter, you could buy a Kreitler belt and modify it as above.
    In fact, if you buy a regular Kreitler belt, you'd have enough length to practice or make mistakes and still result in a usable belt. Use the hot iron method mentioned above and you won't need a propane torch or a belt sander, which not all people have.
    Reputation: Oxtox's Avatar
    Aug 2006
    you might want to see if these folks could help you...their stock of o-rings is impressive.
    O-ring Kits | Austin TX
    Reputation: Akirasho's Avatar
    Quote Originally Posted by Oxtox View Post
    there is a filthy filthy joke in there somewhere,
    .. and I'm hoping that one of you will follow thru.
    Feb 2005
    I actually got one from, get this...the manufacturer!
    Nov 2014
    I know Al Kreitler (rip) used to "weld" belt ends together as a complementary service. I'm still using one, but probably just jinxed myself. No idea how he "welded" them but I can imagine something like a ski base extruder might do.
    Occam's Razor.
    Feb 2005
    Quote Originally Posted by Akirasho View Post
    Occam's Razor.
    It took a bit of sleuthing. They now make mostly wheelchair rollers that use this short belt, I think that’s way cool.
  1. cell phones and chastity belts
    By gutfiddle in forum The Lounge
    Last Post: 06-23-2010, 08:41 AM
  2. seat belts
    By Touch0Gray in forum The Lounge
    Last Post: 06-17-2009, 11:29 AM
  3. Mclain Rollers--Any experiences?
    By jlgoodin78 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 12-24-2008, 03:32 PM
  4. Replacement Belts for Rollers
    By juan antonio in forum Components, Wrenching
    Last Post: 02-29-2004, 04:39 PM
  5. Kreitler belts
    Last Post: 02-16-2004, 12:49 AM
