• 01-07-2019
    OV_Dragonman
    Mileage / Wear For SRAM Red 22 Chain
    I've been monitoring the wear on my SRAM Red 22 chain with the Park CC-1 Chain Checker. After 2,700+ miles, I'm still showing just a hair more than .25% chain wear. This is telling me the chain is still basically like a new chain. I did hot wax the chain before putting it on the bike, after cleaning the packing lube off, and I do wipe it down after a dirty road ride, but I've not done anything since.
    Am I measuring the wear properly or is this normal mileage for these chains? I know the chain will eventually wear enough to warrant replacement, and I plan on switching to a Wipperman at that time, but for now, I'm amazed at the mileage I have on this chain.
  • 01-07-2019
    Lombard
    Chain checkers like this can be all over the place in readings.
    Use a ruler. See below how to do this:
    Chains
  • 01-07-2019
    cxwrench
    Post questions like this in the proper section of the forum: Components/Wrenching.
  • 01-07-2019
    OV_Dragonman
    While I do not dispute you can use a ruler, the CC-1 works fine with my other two bike's chains, so I do not think this is a reading error.
  • 01-07-2019
    Lombard
    Quote:
    You might want to check your chains with the CC-1 and then check them with a ruler for comparison. You may be surprised.
  • 01-07-2019
    Fredrico
    Or replace it anyway. Take it off BEFORE it starts elongating and getting loosey goosey. The cogs will also last longer.
    I read TDF mechs change chains every 2000 miles. They claim a set of freewheel gears will last up to 8000 miles on 4 chains, rather than wear down the cogs on one chain to the point where a new chain will skip, and break rider's nuts. :frown2: Of course the gods are torturing their drivetrains a whole lot worse than we mortals. Still, I only get around 3000 miles on SRAM chains before they start to feel rougher after lubing, rather than smoother. That's 90% city and MUT riding, no racing or high power group rides. The hills will do it every time.
    Chains wear out and are replaceable parts, like tires and handlebar tape. If you got the money, luxuriate in that Wipperman. :thumbsup: If all you want is a chain that'll work perfectly for 2000 miles, keep going on SRAM and save some money. Then again, what fun is that? :D
  • 01-07-2019
    cxwrench
    The mechanics I know that work for men's teams change chains out well before 2000mi. I don't even lets the girls chains get that many miles. I never see worn out cassettes on race bikes. Pretty much doesn't happen.
  • 01-07-2019
    Fredrico
    Quote:
    So there ya go! :thumbsup: Well, this was one mech quoted by a magazine 15 years ago, and I believe he changed the chains on the race bikes way sooner than 2000 miles. :D He did mention the distance, though, now I'm not sure in what context.
    Interesting how the cogs last so much longer, huh? What interval would you recommend for moderate club riding? 800-1000 miles?
  • 01-08-2019
    Lombard
    I have to wonder how much money you really save by a 1000 mile replacement. How long do you expect a cassette to last with 1000 mile chain replacements vs. letting the chain and cassette "marry each other" and changing them together at say 8000 miles. Mike T. on these forums gets over 10,000 miles out of his chains.
  • 01-08-2019
    Bremerradkurier
    Back when SRAM chains were still Sachs/Sedisport, you could buy chain in bulk packaging with something like 25 or 50 powerlinks and something like 5000 links of chain in a cardboard box-worked great when I was keeping a fleet of messenger bikes running through wet, miserable North German winters.
    Wippermans were very popular for those running fixed/single gears-their track chains were regularly in use by roidzilla sprinters who came up in the East German era.
  • 01-08-2019
    Kerry Irons
    Chain wear is determined by many factors, so "typical" is meaningless for your specific situation. Clean environment, propoer lube, quality chain, smooth cadence, skilled shifting, and relatively low rider power output can mean very long chain life. Very short chain life can come from some or all of these factors being less than optimum. For me, 2,700 miles would not represent long chain life, but that's me.
    As Lombard has noted, chuck the chain checker and get out a ruler.
  • 01-08-2019
    dir-t
    Quote:
    That's my philosophy for my road bike and commuter too. My road bike is working fine on it's original chain/gears (I'm guessing it's 13 years old with about 8k miles) but I ride that only in nice weather and don't race.
    The commuter is an 8-spd so parts are cheap and, depending how sloppy our winter is and how much I commute, it's less hassle to just assume everything will need replaced together every few years.
    The new 1x11 MTB is a different story. I'll need to settle on a fixed chain replacement interval for that as those cassettes are pricey.
  • 01-08-2019
    Jay Strongbow
    Some people like to maintain good shifting and in my experience that fades when the chain is cooked.
    And you know the chain touches the chainrings too, right? So if you do an economic analysis it's not just the cassette subject to shorter life.
  • 01-08-2019
    Lombard
    You point is well taken here. However, considering there are more teeth on chainrings, load will be spread out and they will wear less quickly. And even when they do wear, because there is a more even load due to more teeth, you will be less likely to have shifting problems like ghost shifting.
    Of course you could argue that you spend much more time in a single chainring than a single cog, so it evens out, right? But somehow cassettes always wear out much faster than cranksets.
  • 01-08-2019
    Jay Strongbow
    What does wearing out slower than cassettes have to do with this? The topic at hand is wearing things out quicker than they would have if you replaced a chain. And chainrings will wear out quicker with a fried chain. The fact they wear out slower than cassettes is irrelevant to that.
  • 01-08-2019
    Lombard
    My point was this:
    1) Worn chainrings won't cause shifting issues (unless they are really worn) as easily as worn cassette cogs will.
    2) By the time your chainrings wear out to where they will cause shifting issues, how many chains will you have gone through if you change your chain sooner vs. later?
    Dollars and cents (and sense), what will the cost be one way vs. the other? See below for cost of items in question:
    https://www.jensonusa.com/shimano-cn...CABEgK-tvD_BwE
    https://www.jensonusa.com/Shimano-105-CS-R7000-Cassette
    https://www.starbike.com/en/shimano-...utPD_BwE#23473
    So cost wise, two chains equals one cassette. Six chains is greater than one crankset.
  • 01-08-2019
    Bremerradkurier
    My point was this:
    Craigslisting the brifters, brakes, and derailleurs from a UK sourced groupset at roughly $400 would almost be the moneyball move if your rings, chain, and cassette are all toasted.
    https://www.merlincycles.com/shimano...et-118524.html
  • 01-08-2019
    cxwrench
    Arrgggghhhhhh...shifters!!!
  • 01-09-2019
    Trek_5200
    chain wear will depend on maintenance and riding habits. i'm not on sram but i'm on a new chain every 2k. riders that do more even and flat riding seem to get more use
  • 01-09-2019
    Fredrico
    Quote:
    Yep. In the rollings hills around the Potomac River, the chain wears out on the climbing gears. Maybe that's a good enough reason to have a bunch of them. :D
  • 01-10-2019
    OV_Dragonman
    Let's keep things simple and stick to chain discussion only!
    I don't necessarily subscribe to changing out a chain after a fixed amount of mileage / kilometers, be it 1000 mi / 1600 km, 2000 mi / 3200km, or whatever, but yes, I see the merit in replacing the chain before it actually wears out. To that end, SRAM suggests 0.50% is when a chain is worn out, so I will probably go with replacing it when it nears 0.35% to 0.40% chain wear.
    The reasons I don't subscribe to a fixed mileage basis is: 1) those teams mentioned are factory sponsored, but I have to pay for the chains, 2) being retired, I do need to curb some expenditures, and 3) we all ride in different conditions.
    When I lived in the Pittsburgh area, I rode primarily on the Montour or Great Allegheney Passage trails and they were surfaced with crushed limestone. I regularly cleaned my drivetrain and yet I was barely able to get 1500 mi / 2400 km from a chain. The dirt from the trail was a finely powdered, invasive, abrasive grit. You don't want to know what it was like if it rained! Now I live in the Tucson area and ride on nicely paved roads or fully paved bikeways, and the weather is much drier.
    I appreciate the advice on measuring the chain with a ruler, but that's not going to happen any time soon as I just waxed the chain and I do not want to have to replace the connecting link again . . . and that's a separate discussion!
  • 01-10-2019
    OV_Dragonman
    Quote:
    Well, that is certainly encouraging! While I am working on getting more power out, the rest of your rider / riding description fits my situation.
  • 01-10-2019
    OV_Dragonman
    What difference does the sex of the rider have to do with it? ALL riders deserve well maintained bikes, especially if they race!
  • 01-10-2019
    Lombard
    If you use the Park CC-1, a new chain registers 0.50% from the get go. Another reason to use a ruler.
    You do not need to remove the chain to measure it with a ruler. Did you read the article I linked to before?
    Chains
  • 01-10-2019
    Kerry Irons
    I appreciate the advice on measuring the chain with a ruler, but that's not going to happen any time soon as I just waxed the chain and I do not want to have to replace the connecting link again.
    Your tunnel vision is impressive indeed. No offense, but has it occurred to you that you can simply lay the ruler alongside the chain and measure the distance from pin to pin? 0.5% elongation is 1/16" over 24 links (12" original chain length).
